Old 07-14-2013, 10:09 PM   #1246
tc3 racer sc's Avatar
Default Do the steering rack suppose to sit down on the post all the way down
Do the steering rack suppose to sit very flat on the post getting a tight snug and also I'm not getting clearance ball stud on top of steering rack not clearing the top upper deck on bottom I love the hotbodies cars but one giving me fits instruction not done where you can understand and go some guess work into it like the gear diff how to set the pin inside or place it right just hot right now
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 07-14-2013, 10:23 PM   #1247
Trader Rating: 20 (100%+)
what?
goots is offline   Reply With Quote
Old 07-15-2013, 10:21 AM   #1248
Originally Posted by goots View Post
that setup sheet has missing info. Its pretty much blank
File transfer fixed, sorry for the missing info, it should work now. JJ's setup at the AOC Round 2 in Melbourne, Australia, on carpet.
http://www.jjwangracing.com/setup-sheets-electric/
rwang is offline   Reply With Quote
Old 07-16-2013, 03:54 AM   #1249
either the car was really aggressive or the track had extreme high traction. Is there any notes how the the car felt/drived?
4k oil rear diff and the rear RF block has been widened...
Old 07-17-2013, 08:46 AM   #1250
I guess I will not get an answer to my question
Old 07-17-2013, 08:54 AM   #1251
I think we don't understand what you are meaning
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 07-17-2013, 09:01 AM   #1252
mxgregg's Avatar
Trader Rating: 32 (100%+)
x2. maybe post a picture?
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 07-17-2013, 09:49 AM   #1253
Trader Rating: 16 (100%+)
For the gear diff I use a pair of tweezers to place the pin.
I don't understand about the steering rack. Can you explain further?
Art
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 07-19-2013, 06:47 AM   #1254
Art
my steering arms not setting on down on the post all the way down and the servo ball stud not clearing the upper deck because it
Old 07-19-2013, 08:49 PM   #1255
The steering posts is not suppose to sit flush with the bottom deck. I built a friends tcxx with a 1.5 washer instead of the kit 2mm on the center steering crank to clear the top deck.
Old 07-20-2013, 11:02 AM   #1256
thxs for info
Old 07-21-2013, 11:30 PM   #1257
Hey this is JJ,
The track had good traction but we had to use tire warmers due to the fact that the air temp was cold. Well actually my rear end was shortened not widened but still had 3 degree rear toe
JJwang is offline   Reply With Quote
Old 07-22-2013, 06:50 AM   #1258
mxgregg's Avatar
Fred or Korey,
Should I be setting my ride height with the droop screws or by shock spring tension? I was told by a local racer to not use the droop screws because I needed some down travel for better weight transfer from the front to rear for more traction exiting corners.
Old 07-22-2013, 07:50 AM   #1259
Nipple's Avatar
Originally Posted by JJwang View Post
Hey this is JJ,
Hi JJ, are you guys joining the AOC race at Thailand?
Nipple is offline   Reply With Quote
Old 07-22-2013, 08:13 AM   #1260
Fred Hubbard's Avatar
Originally Posted by mxgregg View Post
Fred or Korey,
Use the shock spring tensioner to set your ride height.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
SEO by vBSEO 3.5.0
