Old 06-03-2013, 12:20 AM   #1141
Korey Harbke's Avatar
Originally Posted by HD Racer View Post
Korey, What wt oil would you recommend for a tight low grip parking lot track using the 6 hole HB pistons?
I'm currently working on that. I'll get back to ya .
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-03-2013, 08:08 AM   #1142
jag88's Avatar
Originally Posted by jag88 View Post
I found some shock shafts in my parts box which I believe are the ver. 2 shafts. They have an extra groove for the snap ring that holds the piston in a lower position. I don't see any mention of these on any of the setup sheets. My guess is that the lower piston gives more pack and would be used in a low bite condition (?). Does anybody have any experience with these ?
Thanks.
Hiro, Korey or Fred (or anyone) have you tried the Ver2 shock shafts ?
Thanks.
jag88 is offline   Reply With Quote
Old 06-03-2013, 09:52 AM   #1143
Thanks.
jag88,
Yes, i have. But we almost always used the upper slot for ideal amount of down travel.
Thank you.
Hi-LowBlow is offline   Reply With Quote
Old 06-04-2013, 10:23 AM   #1144
mxgregg's Avatar
Trader Rating: 32 (100%+)
I just got the Tamiya 6 hole pistons and going to try 90wt at Norcal.
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 06-04-2013, 12:21 PM   #1145
jag88's Avatar
Does HPI make an optional motor mount for the TCXX ? I thought I saw one that pushes the motor outboard some amount so that it puts a little more roll in the car.
I found a heavy duty mount but I'm not sure it's the same ...
Thanks.
Old 06-04-2013, 12:36 PM   #1146
Fred Hubbard's Avatar
Thanks.
We don't make an optional one but we often use the TCX mount to get more roll and make the car drive more fluid. If you do use the TCX mount then you must use shims to raise it up and the same shim height under the top deck as well. I use anywhere from 1mm to 1.5mm.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 06-04-2013, 04:38 PM   #1147
Well, it's not like "must" for raising the mount up. We adjust the height from 0-1.0mm max when we need, but we do it for both TCXX mount and TCX mount. Most of the time, the TCXX mount with no shims under it is ideal, but sometimes it works better with raised up some.
The TCX mount is nice because you can adjust the motor position sideway by adding/removing shim(s) between motor and motor mount too. Only down side on the TCX motor mount is that we have to remove the top deck when we change motor/pinion gear for stock racing. (no vertical motor screw holes)
Thanks.
Old 06-04-2013, 05:38 PM   #1148
jag88's Avatar
What motor mount is this ? It's part #68837
Thanks.
Old 06-04-2013, 07:41 PM   #1149
Trader Rating: 20 (100%+)
looks to be the XX mount
goots is offline   Reply With Quote
Old 06-04-2013, 07:56 PM   #1150
jag88's Avatar
yep, your right. I just down loaded the manual. Should of done that before I posted ...
Old 06-04-2013, 09:56 PM   #1151
Trader Rating: 17 (100%+)
Try 68717
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 06-06-2013, 11:35 AM   #1152
Parts are slowy starting to roll into GP/Hobbico/Tower Hobbies. You can use the links below to search for what you need. TCX/TCXX graphite arms (67717) should be in by July.
TCXX specific parts
All HB division specific parts
Old 06-06-2013, 03:25 PM   #1153
Thanks for the heads upFred! that is a sight for sore eyes!!!
HD Racer is offline   Reply With Quote
Old 06-06-2013, 03:38 PM   #1154
My pleasure. Thanks to you all for being patient and sticking with us
Old 06-06-2013, 05:54 PM   #1155
Thanks for checking the status Fred!
Man, you are making us here at HPI look bad. (just kidding) But seriously, you are helping people much better than we should do. LOL
Thanks Fred for your great support for HPI!!
Best regards,
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
