Old 05-23-2013, 01:27 PM   #1096
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by ali_g View Post
Dirtydog, what shock towers are you using? Arrowmax?
They are custom made (lowered by 5.5mm) with same shock angles as the kit. I believe they are similar to the arrowmax ones.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 05-26-2013, 05:55 AM   #1097
ali_g's Avatar
Dirtydog hows your testing?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 05-26-2013, 12:57 PM   #1098
Hi,
I had a mixed weekend. The testing went well. I tried lots as I got to the track early and the club had resurfaced the track (using a product called Boral Top Coat) The grip levels were consistent across the entire track and decent.
The Serpent shocks (3x1.1 piston with 388cst and HPI Silver springs) were over gripped (no rotation and stopping mid corner) and also noticed it bouncing everywhere. (track is very bumpy) Next tried HPI Blue all round. It bounced more, so I thought it was too soft and went heavier in oil. Tried 425cst next and it was a move in the right direction. I then went to Yokomo Pink frt and Blue rr spring. It was better again.
I ran out of time to do more testing (wanted to try heavier oil - 475cst with 3x1.2) and also TShox.
On this track (mega bumpy and decent grip - lots of hair pins) I am not as convinced the short shocks were the way to go, but need further testing with correct shock setup to know. On the other track I race at (lots of on power high speed turns) I felt the shorter shocks were an advantage in those sections)
As I said, I have short Tshox, Serpent Shocks and CSO shocks. In quality and build I would rate them that way. The quality and build of my Tshox are excellent. No leaks, build easy and perform well. The Serpent shocks build easy, but need optional clear oring. They also leak and need rebuilding more often had air in shocks after 4 runs) The CSO shocks are junk. The piston does not fit in the body of the shock properly. It binds badly. (even with light sanding).
Leonard.
Old 05-26-2013, 10:57 PM   #1099
IN10CT's Avatar
Anyone finding that the front drive shafts bend easy? If so, what alternatives are there out there that can fit in the tcxx, apart from installing dcjs
Cheers,
Chris
IN10CT is offline   Reply With Quote
Old 05-26-2013, 11:18 PM   #1100
Trader Rating: 20 (100%+)
Cheers,
Chris
thin steel axle upfront maybe?
does anyone know the part numbers for the spool and steel outdrives to use the old thicker style axles?
goots is offline   Reply With Quote
Old 05-27-2013, 12:30 AM   #1101
IN10CT's Avatar
Thanks, but the thin ones look way too thin to go in the front. I have an old cyclone that have steel ones at the front, which are thicker. Would probably give them a go if they can fit..
Old 05-27-2013, 02:12 AM   #1102
Cheers,
Chris
Tamiya 44mm DCJ are a direct fit (just use 5x10x3mm bearing on inside of spindle.
Old 05-27-2013, 07:02 AM   #1103
AGNO's Avatar
Cheers,
Chris
Use 46mm spec-R DCJ V.2 , they are awesome, very smooth and strong, for to be use however require the use of spool outdrive TCX, steel or POM (#61087-#68769-#68770)
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 05-27-2013, 08:31 AM   #1104
STLNLST's Avatar
Trader Rating: 19 (100%+)
Big thanks to Hiro for all the help at the Reedy race this weekend. We got the car rocking and had a chance to make the A main but fell a bit short. This was most likely my last on road race and Hiro made it a memorable one.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-28-2013, 08:08 AM   #1105
mxgregg's Avatar
Trader Rating: 32 (100%+)
How come you are not racing on road anymore?
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 05-28-2013, 08:56 AM   #1106
Trader Rating: 17 (100%+)
Because he likes DIRT under his fingernails...
LOL
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-28-2013, 09:20 AM   #1107
mxgregg's Avatar
Haha I like dirt too but why not race both?
LOL
Old 05-28-2013, 10:18 AM   #1108
He's like me. Too broke to do both!
LOL
Old 05-28-2013, 10:20 AM   #1109
mxgregg's Avatar
I sure get that!
LOL
Old 05-28-2013, 11:39 AM   #1110
STLNLST's Avatar
On road priced itself out of many racers budget. Off road has a much better turnout and is easier on the wallet.
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
