Old 05-08-2013, 08:10 AM   #1051
Does anyone know if the 'ROCHE' on the Roche TCXX servo mount is a sticker or etched on?
Also is it only attached by 1 screw or do you have to drill an additional hole?
Or does it use the centerline hole just to the rear of the original servo mount hole?
cheers
David
dvaid852456 is online now   Reply With Quote
Old 05-08-2013, 11:04 AM   #1052
It is etched on and attached by 2 very close screws.
I have one and it is not a good buy, in case of crash or touch with other car, there is a chance the mount move and your car will no go straight anymore.
CoCoLapin is offline   Reply With Quote
Old 05-08-2013, 05:41 PM   #1053
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
cheers
David
The Roche servo mount as mentioned is laser etched. It uses the same 2 servo mount screw holes as the kit. Please use 3x6mm screws to hold it in place and use loctite. There will be no chance of moving or screws bending after crash.
I have been testing both the Roche and Smokem floating servo mounts with the same result.......both good. Just Smokem one needs Smokem floating mount as the screw holes on the mount are inline and not offset like the kit or Roche one.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 05-09-2013, 02:30 AM   #1054
Excellent, thanks for the info. My servo mount is in the post and on the way
Old 05-09-2013, 09:37 AM   #1055
Suspended
two holes..the stock only uses one hole per mount
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 05-09-2013, 10:11 AM   #1056
Airwave's Avatar
Obviously, but you can't prevent a single-point support to rotate without fixing it with two screws...
Airwave is offline   Reply With Quote
Old 05-13-2013, 06:40 AM   #1057
I was racing my TCXX at the weekend on a low grip asphalt track. The car was okay entering the corner, slightly loose mid corner and was suffering severe oversteer on the corner exit.
I have never been sure on the effect of standing up or laying down shocks, but after a bit of reading I tried standing up the rear shocks, changing from position 4 to position 6. This seemed to do the trick and the rear of the car was much better on corner exit.
Has anyone else found standing the rear shocks up on the TCXX increases rear grip, at least on corner exit?
Old 05-13-2013, 07:30 AM   #1058
rosko's Avatar
Leaning in rear shocks will let the car rotate into the corner better. Standing the rear more upright makes the car drive more square so the car will not rotate into the corner as hard giving you the feeling of more rear traction but go to far either way and your rear end will be loose.
rosko is offline   Reply With Quote
Old 05-13-2013, 11:44 AM   #1059
Dog Bone's Avatar
Boy, the parts are just streaming into the hobby stores
Arms won't be available at Tower until late July. I know I've complained about this before, but this distributor change was not handled very well.
Because of this, I'm seriously thinking of switching to another chassis come fall when we start racing again. I've been a loyal HB TC owner since I started racing about 5 years ago, but I don't want to be in the situation I was at the end of our on-road season where I had *no* spare arms.
Sorry for whining, but I'm bit tired of the perpetual shortage of parts for HB TC's.
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 05-13-2013, 12:15 PM   #1060
mxgregg's Avatar
Trader Rating: 32 (100%+)
It is pretty frustrating for sure.
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 05-13-2013, 01:25 PM   #1061
M3Armand's Avatar
I can sell you these:
4 HPI31420 rear arms
6 HBS67717 rear arms
7 HPI73507 rear hub set
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 05-14-2013, 05:56 AM   #1062
Dog Bone's Avatar
Unfortunately, when you break arms, it's almost always the front arms. I also have lots of rear arms, not to mention a lot of rear hubs
But that's not really the point -we need these parts back in the supply chain. And pronto, or HB will start to loose customers.
Ah well. Enough whining from me.
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Old 05-14-2013, 06:34 AM   #1063
M3Armand's Avatar
Yes, I know how you feel... It's sad that I've broken "at least" 7 or 8 front arms and maybe 2 rear arms. This explains why I have so many rear arms and rear hubs. Having said that, I stocked up and found that the HPI 31420 "High Traction Arms" have not broken (yet) and I cannot tell the difference in performance vs. the original graphite arms. Just as a note, my laptimes are pretty consistent and I rarely hit anything unless I am the one "nudged" to a wall or corner by another car.
So my suggestion is to stock up on the HPI 31420. It's a direct fit and also comes with 2 front and 2 rear arms vs. the 1 and 1 for the graphite parts...
Lastly, when it's cold (and it's cold here in Boston), the graphite arms seem to break just by breathing on them...
Old 05-14-2013, 06:56 AM   #1064
vctr1's Avatar
Trader Rating: 14 (100%+)
make me an offer...brand new TCXX
HB TCXX new car
VSpeed Racing / FG SUPPLY
www.vspeedracing.com
www.fgsupply.com
www.vsmodelsport.com
vctr1 is offline   Reply With Quote
Old 05-14-2013, 08:26 AM   #1065
jag88's Avatar
HB TCXX new car
vctr1, you have PM.
jag88 is offline   Reply With Quote
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
