Like Tree1Likes
Old 04-28-2013, 01:55 PM   #1006
EvaldasD's Avatar
Originally Posted by EvaldasD View Post
What is the main difference and for what situation should be used those new v2 front spindles ?
EvaldasD is offline   Reply With Quote
Old 04-28-2013, 05:18 PM   #1007
ShaunMac's Avatar
Are the V2 blocks the ones with the third hole spaced a bit more outside and back than the standard kit blocks?
Like these?
ShaunMac is offline   Reply With Quote
Old 04-28-2013, 05:29 PM   #1008
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Like these?
Yep. They are only a new part. So might take some to filter out to all the HB stockists. The part number is HB68489.
HTH
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 04-28-2013, 08:39 PM   #1009
M3Armand's Avatar
Can anyone answer what the new V2 spindle blocks are for? i.e. - why did they change it again?
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 04-28-2013, 08:43 PM   #1010
Trader Rating: 20 (100%+)
forget about the spindles. I want the new towers and short shocks used at the TITC
goots is offline   Reply With Quote
Old 04-28-2013, 10:19 PM   #1011
Korey Harbke's Avatar
I know they look like they move it further out than the TCXX blocks, but they are in between the OLD OLD steering blocks and the TCXX blocks. The new V2 blocks are a modified version of the original blocks from the Cyclone and TCX.
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-28-2013, 10:40 PM   #1012
Suspended
Originally Posted by i am cornholio View Post
does anyone have a good setup for 17.5 at norcal hobbies..or tamiya
ok then...good talk
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 04-28-2013, 10:51 PM   #1013
Suspended
Originally Posted by Korey Harbke View Post
Probably the main reason you won't be seeing much on Hara's setup is because of a few key prototype parts that were on the car. A lot of people don't realize the difference some of these can make to what the overall setup should be, so they aren't posted. If you need a solid setup, I'm sure one of us can help you out though.
-Korey
still waiting
Old 04-28-2013, 11:48 PM   #1014
Originally Posted by ali_g View Post
Fred, care to share your setup for carpet?
I know I'm not Fred... but I'd like to consider myself as a credible source as well .
Front:
Spring: Yokomo Pink
Oil: Much More 500
Piston: Kit 1.1mm 3 hole
Shock Length: 63.5mm
Camber: 1.5 deg
Caster: 4 deg
Toe: 0
Droop: 9.5-10.00mm
Swaybar: 1.4mm, 1mm gap on links
Shock Position: #3 on tower, #2 on arm
Camber link: Short, w/2mm under the inner pivot
Ackerman: 2.5mm on steering rack, #3 hole on V2 steering block
Suspension blocks: FF=1.5 deg, FR= solid +1.5
Shims under suspension blocks: FF= 1.0mm, FR=1.0mm
Wheelbase: 1.25 behind arm, 1.5 in front
Front Drive: Spool, Long POM outdrives, 46mm driveshafts (Tamiya for 2mm pin)
Rear:
Spring: Yokomo Pink
Oil: Much More 500
Shock Length: 64.0mm
Camber: 1.5 deg
Toe: 3 deg
Droop: 9.5mm
Swaybar: Narrow 1.2mm, 1mm gap on links
Shock Position: #3 on tower, #3 on arm
Camber link: Short on bulkhead, short on hub carrier, w/1.5mm under the inner and outer pivot.
Suspension blocks: RF: Solid 0, RR, 3 deg
Wheelbase: 2mm in front of arm, .7 behind it. 1.5 in front of rear hub, 1.25 behind it.
Gear Diff: AE 35wt shock oil. (orings are swelled a bit, you might need to run thicker if stability/forward bite issues come up).
Body: LW Mazdaspeed 6
Wing: LW HB from Subaru Type C
I think that's everything... Let me know if you have any questions.
-Korey
Old 04-28-2013, 11:56 PM   #1015
still waiting
Sorry to keep you waiting. Since I live in continuously rainy Washington state, I don't get to run asphalt very much (or see sunlight... I was very confused as to what the bright ball in the sky was last time I visited California).
I do know a Norcal local that always has a solid 17.5 setup on his HB cars, and he goes by "Advil" on these forums. I would contact him and see if he has a solid starting point for you specific for Norcal Raceway in the 17.5 class.
Sorry I couldn't be as much direct help.
-Korey
Old 04-29-2013, 04:09 AM   #1016
ali_g's Avatar
Front:
Spring: Yokomo Pink
Oil: Much More 500
Camber: 1.5 deg
Caster: 4 deg
Toe: 0
Droop: 9.5-10.00mm
Rear:
Spring: Yokomo Pink
Oil: Much More 500
Camber: 1.5 deg
Toe: 3 deg
Droop: 9.5mm
-Korey
Do you normally run a light oil for gear diff on carpet tracks?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 04-29-2013, 09:23 AM   #1017
Trader Rating: 17 (100%+)
ok then...good talk
Sorry, didn't look here recently...
-Korey
Slacker!
Here is what I have as of yesterday.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 04-29-2013, 10:51 AM   #1018
Suspended
thx advil...are you using tcx motor mount or tcxx one..and are you using all the top deck screws..sorry to be such a pain..
Old 04-29-2013, 12:46 PM   #1019
I am using the stock TCXX motor mount. On the setup sheet the top deck screws that are filled in with black should be blank. I don't know why it did that when I converted the .pdf to .jpg for posting. I do have a 2mm top deck on order...next weekend we will see if it works.
Art
Old 04-29-2013, 01:05 PM   #1020
Suspended
Art
thx ..you going to the speedtech race at tamiya?? and i assume you will be at the reedy race..i will look for you ..thx again
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
