Old 04-11-2013, 12:08 PM   #961
Airwave's Avatar
Originally Posted by mxgregg View Post
So I can run the tamiya spool up front?
Don't forget about the Roche spool, I used that with Tamiya 46mm dogbones
Airwave is offline   Reply With Quote
Old 04-11-2013, 12:38 PM   #962
mxgregg's Avatar
Trader Rating: 32 (100%+)
Thanks Man! Whats the advantage of the Roche spool over the stock HB spool setup?
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 04-11-2013, 10:27 PM   #963
ali_g's Avatar
Originally Posted by AGNO View Post
Yes, I Use on high grip carpet surface, work very well.
using 0.75mm spacers will get you more roll and grip? is it required on a high grip surface?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 04-11-2013, 11:29 PM   #964
I've been running the Roche/tamiya setup for over 18 months and not one issue with it. Oh and I do bump into a lot things
markrobinson is offline   Reply With Quote
Old 04-12-2013, 01:31 AM   #965
AGNO's Avatar
Yes, with low roll center we have more roll, but the handling is more predictable.
High roll center, on high bite carpet, makes driving very nervous and unpredictable the roll over.
At least, it worked for me.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 04-12-2013, 02:46 AM   #966
Nuno Gancho's Avatar
when all the options will be on the market.
Nuno Gancho is offline   Reply With Quote
Old 04-12-2013, 09:10 AM   #967
EvaldasD's Avatar
Hi. Bought my TCXX today! I noticed that main chassis has a slightly different cut-out than in official HB pictures. My chassis has straight motor cooling holes, not one big hole that is shown and some triangles near the chassis center are missing. Is that normal ?
Sorry, can't add photos yet
EvaldasD is offline   Reply With Quote
Old 04-12-2013, 10:37 AM   #968
That is the optionial HB chassis See link http://www.redrc.net/2012/12/hb-tcxx...ssis-top-deck/
HD Racer is offline   Reply With Quote
Old 04-12-2013, 10:47 AM   #969
EvaldasD's Avatar
Here is photo of mine
www(dot)evaldasdzialtuvas.lt/rcm/IMG_0529.png
And here is official HB photo
www(dot)hpieurope.com/graphics/kits/kitpages/68299/under-side-chassis.jpg
Few small changes.
Old 04-12-2013, 12:28 PM   #970
Few small changes.
this is a link to HB Europe showing the stock TCXX chassis
http://www.hpieurope.com/piw.php?lang=en&partNo=68296
The picture of the chassis in the bag is the HB TCX not TCXX
Old 04-12-2013, 01:29 PM   #971
EvaldasD's Avatar
Thanks mate, now it's all clear.
Old 04-12-2013, 01:34 PM   #972
Glad I could help!
Old 04-15-2013, 05:56 AM   #973
M3Roc's Avatar
Trader Rating: 108 (100%+)
I finished building my TCXX last night and right away I noticed that the rear diff is leaking from both the grub screw and the four screws that keep it together. Is there anything I can do to make it not leak or could I replace it with a ball diff?
☆ What a wicked web we weave, when first we practice to deceive. ☆
☆ Wolves don't lose sleep over the opinions of sheep. ☆
☆ Life never favored weakness, Only the strong survive. ☆
M3Roc is offline   Reply With Quote
Old 04-15-2013, 06:16 AM   #974
When I built mine, I left the grub screw out until the 4 main screws were in and tight. The grub screw hole acts as an overflow. After the excess oil had drained and the grub screw put in its place, no further oil leaked out.
I've not suffered from any leaks in the 4 months that I've been using the car.
THancock is offline   Reply With Quote
Old 04-15-2013, 07:14 AM   #975
M3Roc's Avatar
Ok the problem here may be then that I overfilled the diff. I was advised by another user that I should fill the diff until the oil is half way up the gears. Is this the incorrect way? Forgive my ignorance, this is my first time building a kit like this.
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
