Old 04-07-2013, 09:32 PM   #931
STLNLST's Avatar
Trader Rating: 19 (100%+)
Didn't sign up as Fred or Korey and maybe that's why I only got 5th
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-07-2013, 09:37 PM   #932
bigz's Avatar
Originally Posted by Korey Harbke View Post
I haven't run the no cut out chassis yet since they haven't been easily accessible, but Fred and Hiro really like them. It's a tiny bit stiffer and makes the car more consistent and predictable.
Whenever you have cutouts in a carbon laminate, it makes it a lot more susceptible to defects and overall mechanical property fluctuations due to discontinuous fibers. That is a major reason why I feel Fred comments how it makes the car less sensitive to environmental changes. The car will change less throughout the day.
thanks Korey. i guess the no cut chassis is the one for me. i've been having difficulties with the traction of my tcx before. it handles fine in medium grip but when the traction comes in during the finals i tend to roll a lot. had this solved by using the smokem chassis. no cut chassis it is.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 04-08-2013, 11:55 AM   #933
Is it possible to rebuild the Hotbodies DCJ? I dont see part references for that...
CoCoLapin is offline   Reply With Quote
Old 04-08-2013, 10:35 PM   #934
Korey Harbke's Avatar
Nope. Its a one shot deal.
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-09-2013, 01:15 AM   #935
WOW! I had my first outdoor race with the TCXX today and smashed my PB by 13.5 seconds! The TCXX was very different to drive compared to my previous car, the WCE Cyclone (converted to Exotek HBX).
The TCXX was so much smoother, calmer and easier to drive. Once I got used to using full lock for the slow tight corners, something that I never needed to do with the Cyclone as it always had too much steering, I was 0.8 seconds a lap quicker on my average lap times!
The only issue I had was with the front right drive shaft bending after a fairly major crash and roll in the first final. I have ordered a set of the steel drive shafts and TCX POM spool outdrives. Will the extra weight of the steel drive shafts at the front have a significant effect on acceleration? I also have set of TIR Titanium Pro 4 MiP drive shafts that I might try as a comparison.
For it's first outing I am seriously impressed! I can't wait to run on my local track and chase down that elusive 19 lapper. Well done HB!
dvaid852456 is offline   Reply With Quote
Old 04-09-2013, 01:49 AM   #936
Robert_K's Avatar
So, with the 2012 Worlds people where trying shocks with 6 holes and heavier oil, cause Hara did this. Are you guy's still running this, or did you go back to the normal 3/4 holes and arround 500CST?
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 04-09-2013, 08:48 AM   #937
Regards Robert
Yes we do. It's always nice to have as an option for shock setups. We are still testing those new shocks that were used at the TITC 2013 but we still haven't tried the 6hole piston setups with them yet. It should be interesting to try the setup with them too.
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 04-09-2013, 08:49 AM   #938
That is very nice to hear the car is working well for you! Please keep us updated.
Old 04-09-2013, 10:27 AM   #939
Thanks,
You can send me a free set and I'll be happy to test them for you! (Can't blame a guy for trying) LOL
HD Racer is offline   Reply With Quote
Old 04-09-2013, 04:27 PM   #940
mxgregg's Avatar
Trader Rating: 32 (100%+)
I bought a used tcxx and broke a front axle cup. I believe it has after market dcj's. I bought new #68840 cups and they are to tight and the axle dog bone won't fit. Is there another part that will accept a larger axle or dcj?
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 04-09-2013, 06:10 PM   #941
Originally Posted by mxgregg View Post
I bought a used tcxx and broke a front axle cup. I believe it has after market dcj's. I bought new #68840 cups and they are to tight and the axle bog bone wont fit. Is there another part that will accept a larger axle or dcj?
Hi
I use the spec-r dobbel joint for the tamiya 417, you just need shave very little of the c-hub , else Its a direct fit
HB-forever is offline   Reply With Quote
Old 04-09-2013, 06:37 PM   #942
mxgregg's Avatar
Originally Posted by HB-forever View Post
Hi
I want to replace the axle cups not the dcj's.
Old 04-09-2013, 06:51 PM   #943
ShaunMac's Avatar
The #68840 cups are designed to accept 2mm pins. The older HB DCJ's had larger 2.4mm pins. The newer #68823 DCJ's have a smaller 2mm pin. You could use #68769 steel long cups that were released for the TCX. These cups have a larger slot. They are available in a #68770 POM version as well.
Since the DCJ's aren't cheap. I run a locked gear diff or a putty gear diff in the front so I can use blades to help keep drivetrain wear to a minimum and keep things as smooth as possible longer.
ShaunMac is offline   Reply With Quote
Old 04-09-2013, 07:09 PM   #944
mxgregg's Avatar
No kidding new dcj's are $90. No one seems to have the optional cups in stock. Any ideas?
[QUOTE=ShaunMac;12028966]The #68840 cups are designed to accept 2mm pins. The older HB DCJ's had larger 2.4mm pins. The newer #68823 DCJ's have a smaller 2mm pin. You could use #68769 steel long cups that were released for the TCX. These cups have a larger slot. They are available in a #68770 POM version as well.
Since the DCJ's aren't cheap. I run a locked gear diff or a putty gear diff in the front so I can use blades to help keep drivetrain wear to a minimum and keep things as smooth as possible longer.[/Qkidding. New dcj's
Old 04-09-2013, 07:41 PM   #945
ShaunMac's Avatar
You could get a gear diff for the front or wait for someone to have the cups you need in stock. If it's like a lot of other HB parts you could be waiting a long time. That's why I went away from the HB spool. I couldn't get replacement cups when I needed them.
I currently have a converted Spec-R diff up front and the HB in the rear.
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
