Old 02-08-2013, 08:59 PM   #736
Trader Rating: 20 (100%+)
Originally Posted by mxgregg View Post
Just got my TCXX. Going to run a 17.5. What size pinion shoud I start with? Comming from off road and not sure where to start. Mid size carpet track.
a 94t spur should give you good amount of FDR range to play with
goots is offline   Reply With Quote
Old 02-09-2013, 09:53 AM   #737
jag88's Avatar
Fred Hubbard
When you say " inside outer hole on arm for sway bar (wide) " what does that mean ?
Thanks.
jag88 is offline   Reply With Quote
Old 02-09-2013, 11:03 AM   #738
Originally Posted by jag88 View Post
I'm looking at Hara's worlds setup and I'm trying to figure out which hole he used on the rear Tamiya upright. Can anybody help ?
Thanks.
Outer hole on tamiya hubs.
We will have test sessions before/after TITC in Thailand this month. We should be able to release some option parts for the tcxx to improve the performance even better! Stay tuned..
Hi-LowBlow is offline   Reply With Quote
Old 02-09-2013, 11:08 AM   #739
Dog Bone's Avatar
How about we concentrate on getting the base parts back into the pipeline first?
Supply of spare parts from HP/HPI has been, to be blunt, absolutely terrible in the last couple of months.
Ken Miller
T4 2014, 10r5.1 (F/S), 12r5.2 (F/S)
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 02-09-2013, 01:52 PM   #740
jag88's Avatar
... short shocks with new towers would be cool (and springs, of course) ... lol
Old 02-09-2013, 09:22 PM   #741
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
Default motor mount
i'm not sure if it's been asked.
which motor mount is the preferred option?
pro's & cons please.
trying to decide what final parts will get placed on my ride for next week.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 02-10-2013, 09:02 AM   #742
I prefer the TCX motor mount on carpet or tight tracks as the motor is around 2mm further inboard than the tcxx motor mount and I think having the weight further inboard allows the car to roll faster
On big outdoor tracks the TCXX mount works well.
A lot of the competitor cars on the market seem to have their motor really inboard lately so I think running the TCX motor mount isn't really ever going to be a bad decision
Stef
Stefan-Hpi Uk is offline   Reply With Quote
Old 02-10-2013, 09:53 AM   #743
Nipple's Avatar
Sorry, not sure if this has been asked before, but what is the biggest pinion I can use with the TCXX stock motor mount and 115T spur?
Thanks.
Nipple is offline   Reply With Quote
Old 02-10-2013, 03:06 PM   #744
Fred Hubbard's Avatar
Fred Hubbard
Thanks.
On the rear arms you have 5 holes for different shock positions since our arm are reversibe. Standard setup calls for using the middle hole (#3). On the opposite side of #3 we use #4 when we use the wide sway bar. So essentially holes 2 and 4 are outside of the molded ball for using the short sway bar, so #4 is inside to #2 but outside of the molded ball for sway bars hence "inside-outer."
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 02-12-2013, 02:41 AM   #745
ali_g's Avatar
anyone tried to use 1.0 split blocks and reverse it to be -1.0 as r/f block?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 02-12-2013, 09:35 PM   #746
just got a couple new split blocks for my car. How do I know its in the right direction? all I see on the blocks is a reference dot. Which way should it be? Dot on the inside or outside? Thanks
Old 02-14-2013, 07:23 AM   #747
ali_g's Avatar
i built mine with the dots outside. Am i right?
☆ JU.C RACING ☆
Old 02-14-2013, 09:35 AM   #748
Hi ali_g,
Yes what you did is the right way.
Thanks!
Old 02-14-2013, 05:04 PM   #749
Hi chaps,
Just thought I'd add my pennies worth about this car. I just purchased the HB TCXX and ran for the first time tonight, coming from the xray T4. Although its not quite there yet in laptime, its lovely to drive. (This is on a tight medium-high grip carpet track). Good steering and very consistent car. Went away from stock and changed the front wheelbase by swapping round the shims from .75mm/2mm to 2mm/.75mm and changed shock positions to 3 front 2 rear with speed 6 body. Can't fault the handling, it just needs freeing up some.
Can anyone give me a bit of advice to get the car to generally glide a bit more, rather than stick? - I will be adding tamiya DCJs also, which should help!
Thank you.
maxg123456 is offline   Reply With Quote
Old 02-14-2013, 09:35 PM   #750
Trader Rating: 3 (80%+)
Originally Posted by maxg123456 View Post
Hi chaps,
Thank you.
just curious,whats wrong with the HB DCJ'S ? I see lots of people posting that they are using the tamiya's.
traitor is offline   Reply With Quote
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
SEO by vBSEO 3.5.0
