Like Tree1Likes
Old 11-24-2012, 12:52 PM   #526
Thanks David. I used the plastic bumper brace instead of the graphite because using just those shims still left a gap when using the graphite one. I'm assuming you have some left over shims to fill that gap with when using the graphite brace?
Yukie is offline   Reply With Quote
Old 11-24-2012, 01:00 PM   #527
CristianTabush's Avatar
Shameless plug here. I can't post links because we have not yet become a forum sponsor, however, we are waiting for a response on our inquiry as to how to proceed.
We have started fully supporting the TCXX at our shop. The remaining parts for the TCXX should be in stock by the end of the week, however we have a ton of items in stock as well. If you guys need anything for it, part ideas or requests, let me know and we will look into it. Our plan is to start making a few products for the TCXX, namely spool cups and DCJ's.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-24-2012, 05:18 PM   #528
Another noob question. Is what comes with the kit as far as steering servo components all I need? Someone at the track suggested I get a servo saver, but isn't what comes with the kit a servo saver?
Old 11-24-2012, 06:57 PM   #529
Dog Bone's Avatar
If you can call it that - the supplied servo saver is quite 'savey' :-) Others have replaced theirs with the Tamiya servo saver + the 3 racing horn. I've done something similar, and the Tamiya version works *much* better.
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 11-24-2012, 11:54 PM   #530
Thank you for the advice Dogbone. So the stock servo saver isn't good? If so, could you provide the specific servo saver / horn (the exact part number) that most people are using? I have a Savox 4096 digitial servo, if that matters.
Old 11-25-2012, 11:20 AM   #531
outtafocus's Avatar
Look one page back.
www.rcdepot.ca-Hobbywing-Tekno-TLR-Brass Knuckle Brush Worx
outtafocus is offline   Reply With Quote
Old 11-25-2012, 01:56 PM   #532
Originally Posted by outtafocus View Post
Look one page back.
Oops sorry didn't see that. Thank you.
Old 11-25-2012, 09:23 PM   #533
Texco's Avatar
Hi all,
Is anyone having problems with getting the right rear end to the correct degrees?
I'm using the standard setup R/F 0 Degrees and R/R 3 Degrees but when I put it on my setup station left side is 3 Deg and Right is 2 Deg? I have swap everything over and always the same results.. I even put a rear 0 deg pivot block and the left side was 0 but the right was out by 1 deg again?
Any ideas?
thanks for your time.
Texco is offline   Reply With Quote
Old 11-26-2012, 05:38 AM   #534
Dog Bone's Avatar
I haven't had any issues - I did measure the backend, and L/R were both 3deg.
Is it possible your setup station is off?
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Old 11-26-2012, 12:06 PM   #535
Texco's Avatar
Nah you can see the the difference from left and right... you can just see it's out.
Old 11-26-2012, 02:26 PM   #536
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Its your hubs, HB had this issue with the cyclone through to the TCX. Alloy hubs is a fix or try another set of hubs.
It doesn't effect the car as much as you would think
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 11-26-2012, 02:55 PM   #537
b_recliner's Avatar
Trader Rating: 22 (100%+)
yep, hubs. i put the aluminum ones on and the reading is dead on 3 on a hudy setup station.
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 11-26-2012, 03:29 PM   #538
Send a message via Skype™ to JordanC
Alex, why are you here??? Thinking about the change
Re: toe reading. I noticed something similar when I was playing with different toe blocks. In the end I didn't worry about it becuase I have one of the new HUDY toe guages, I borrow one of the old etched guages from a friend and It was perfect. seems they don't all read exactly the same.
JordanC is offline   Reply With Quote
Old 11-26-2012, 03:32 PM   #539
Look one page back.
If you aren't driving on boarded tracks, using a servo horn is usually safe enough. It also guarantees there's no moment in the "saver" and generally is a little more responsive.
Old 11-26-2012, 08:12 PM   #540
Texco's Avatar
Thanks mate it worked! Changed different brand uprights and now everything is equal..
Shame on HB! Hahaha
Thanks for the ppl who replied.
Todd
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
