Old 11-14-2012, 11:05 PM   #511
Trader Rating: 20 (100%+)
Originally Posted by Fred Hubbard View Post
I don't understand the point of your question about how this would apply to the rear of the car because arm sweep doesn't apply. Let me ask if you understand the effect of running less rear toe?
Yes I understand toe in the rear. I think I said it wrong in a confusing way.
#68774 - PIVOT BLOCK RF (+0.5 DEGREES)
#68775 - PIVOT BLOCK RF (+1.0 DEGREES)
These blocks are RF, rear front? or I am wrong and these blocks dont go in the rear end of the car. I assume they are wider blocks and am wondering what they do
goots is offline   Reply With Quote
Old 11-15-2012, 06:31 AM   #512
They are wider blocks for the front end of the TCX, they do fit the front of the TCXX and would slightly stiffen up the front of the chassis (flex wise) because the screw mount holes are further apart, as well as make geometry changes.
I don't think they fit the rear because they would foul the rear belt.
cyclonetog is offline   Reply With Quote
Old 11-15-2012, 10:39 AM   #513
Trader Rating: 16 (100%+)
They have differnt blocks for the rear but mount to the same outer holes.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-15-2012, 01:43 PM   #514
I know.
Old 11-15-2012, 09:23 PM   #515
Thanks for some info guys about the blocks. Havnt seen any info on them previously
Old 11-17-2012, 05:29 PM   #516
Dog Bone's Avatar
Has anyone noticed that the kit servo saver isn't very 'stiff'.
Our top racer at our track test drove my car, and commented that it's wandering down the straight, and is somewhat sluggish when entering a corner, then all of a sudden it has a lot of steering.
We looked at the car, and determined that the servo-saver has quite a bit of give. With the car and radio turned on, you can quite easily move the steering rack - my guess is that when entering a corner, the SS is initially 'saving' rather than letting the wheels turn, but when it reaches it's maximum 'give', the wheels bite, and all of sudden you get a ton of steering...
I've put in an aluminum servo horn to see if this resolves the problem, but I would not, for obvious reasons, run this regularly.
Has anyone replaced the kit servo-saver with anything else? I see that there's an X-ray servo saver that's classed as 'stiff', and has four inner springs rather than three. The length of the arm seems to be shorter than the kit servo saver; it looks like the SS that came with the TCX...I do have two of those, and I may try those as a replacement as well..
Ken Miller
T4 2014, 10r5.1 (F/S), 12r5.2 (F/S)
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 11-17-2012, 05:43 PM   #517
b_recliner's Avatar
Trader Rating: 22 (100%+)
I use the tamiya servo saver with a 3racing purple horn that has a hole at the same length out as stock. The horn is also anodized purple too so that's a plus. No worries whatsoever with this combination.
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 11-17-2012, 06:18 PM   #518
Dog Bone's Avatar
Can you give me a part number? I'm familiar with some of the Tamiya SS's, but I'm not aware of one that let's you add an aluminum horn...
Ken Miller
CRC Xti WC/GenX-10
Old 11-17-2012, 06:34 PM   #519
Been also running 3racing horn with tamiya high torque servo saver. You could always stiffen up your saver if you add another ring
Old 11-17-2012, 10:39 PM   #520
Dog Bone's Avatar
Again, part numbers would be really useful.
Ken Miller
CRC Xti WC/GenX-10
Old 11-18-2012, 05:59 AM   #521
b_recliner's Avatar
Tamiya 51000 high torque servo saver
3racing purple tamiya style horn 3RAC-HTS30/PU
different length purple tamiya style horn 3RAC-HTS3018/PU
Any "tamiya style" servo horn will fit the servo saver. I use the 3 racing ones because they are purple and therefore shave roughly .1 off the lap times, plus they are of excellent quality.
Old 11-23-2012, 07:37 PM   #522
Quick question. Almost done building my TCXX, but I can't find this part. Looked on every sprue + bag and did a parts search on hotbodies.com which actually comes up with a different part.
Yukie is offline   Reply With Quote
Old 11-23-2012, 07:48 PM   #523
Fred Hubbard's Avatar
The part number is for graphite bumper brace but the shim is 3mm X 4mm. Give a call to the office on Monday if you still can't find it.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 11-23-2012, 09:35 PM   #524
Thanks for the help Fred. BTW, the aluminum hubs that I couldn't find before, I was able to find them. I'm sure I'll be able to find these shims too, I probably just have to look harder. BTW are these aluminum or plastic shims, so I have a better idea of what I'm looking for.
Old 11-24-2012, 01:15 AM   #525
Purple aluminium.
dvaid852456 is offline   Reply With Quote
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
SEO by vBSEO 3.5.0
