Old 11-12-2012, 01:16 AM   #496
Hi just after abit of quick advice, I would search if my phone would alow. If I buy 68833 gear diff set. To run in the front on my tcx with specR v2 dcj drive shafts. Will that work or will I need different outdrives? If so what outdrives will I need. Thanks.
bob33 is offline   Reply With Quote
Old 11-12-2012, 02:12 AM   #497
Trader Rating: 20 (100%+)
Originally Posted by Fred Hubbard View Post
All,
That DCJ is pre TCXX and has a 2.3mm pin and its driveshaft is wider and require any of these outdrives:
67699 DCJ Drive Shaft Set (1pc)
68770 SOLID AXLE LONG CUP (POM/2pcs
68769 SOLID AXLE LONG CUP (STEEL/2pcs)
61333 DIFF CUP JOINT ADAPTER/2PCS ***2.3mm pin***
Here are the part numbers developed for the 2mm pinned DCJ along with its outdrive options:
68823 DCJ Drive Shaft (44mm/2mm Drive Pin/1pc) ***Thinner driveshaft like the TCXX kit steel drive shafts***
68840 SPOOL OUT DRIVE SET (STEEL/TCXX) ***2mm pin***
68841 SPOOL OUT DRIVE SET (POM/TCXX) ***2mm pin***
68289 GEAR DIFF OUT DRIVE SET (FRONT/STEEL/2pcs) ***2mm pin***
68822 DRIVE SHAFT BLADE SET (POM/2mm Drive Pin Hole)
68821 LW STEEL UNIVERSAL DRIVE SHAFT 44mm (2mm Drive Pin)
68836 DRIVE SHAFT BLADE SET (GEAR DIFF) ***has both blades for 2mm and 2.3mm pin***
68278 GEAR DIFF OUT DRIVE SET (ALUMINUM/2pcs) ***We use these in our rear Gear Diffs only and you must use a blade***
EDIT: Alot of the new parts are not on the website yet but are in stock.
goots is offline   Reply With Quote
Old 11-12-2012, 02:20 AM   #498
Thanks. I had seen that but in my head I thourt I'd have 2.3mm pin on my tcx. So won't need them for 2.0mm pin.
Old 11-12-2012, 06:36 AM   #499
Fred Hubbard's Avatar
Originally Posted by Airwave View Post
Hey guys, nothing new about a floating servo support?
Sorry about the spur gear, it was a picture of Robinson for my Awesomatix...
This is the item mounted on my TCXX:
Nothing yet.
Originally Posted by zozo View Post
Why many used
Tamiya Rear Uprights #51333 ?
TCXX Cut-Out/2.25mm ?
the origin chassis is not good : Cry:
Thank you
They are all optional parts and not necessities. This is a common occurence amongst all cars, them using other parts from other cars. Just like Tamiya and Yokomo drivers use our springs on their cars. Look here to understand the 2.25mm option chassis
It stands to reason that the pin on the Spec-R is 2.3mm and if so then you will need to use our 2.4mm blade with with the outdrives included with the gear diff. The gear diff comes with both 2.0mm and 2.4mm blades. The easiest way to know for the sure the pin size is to measure it with calipers.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 11-12-2012, 06:41 AM   #500
Thanks fred. This is what I thourt. I would of measured it but I need to get it orderd and I'm at work . It was more the length of the outdrive I was worried about. Ill order it now.
Old 11-12-2012, 08:45 AM   #501
tessty71's Avatar
Trader Rating: 16 (100%+)
Where do parts come from on the HB website? I ordered what I thought were in stock parts on the site last week. My card has not been charged yet or anything than conformation email very frustrating for a new customer of there product.
KSG SCX / C&M Mortorsports
Point R/C Raceway
tessty71 is offline   Reply With Quote
Old 11-12-2012, 12:23 PM   #502
If the item(s) say in stock on the site then they are in fact in stock. All product for North America ships from HB USA when ordered through the site. Last week was our month-end inventory, there is a notice of this on the account creation page. The "of" 11/8/12 should have been "after" 11/8/12. Give them office a call tomorrow to get more info regarding your order. Thanks
Monday - Thursday:7:30AM - 5:15PM PST
Friday: 7:30AM - 4:15PM PST
Our phone number is:
(949) 753-1099
(888) 349-4474(Toll free)
Old 11-12-2012, 01:30 PM   #503
tessty71's Avatar
lol who reads that stuff!!!! Sorry
Point R/C Raceway
Old 11-12-2012, 01:54 PM   #504
Texco's Avatar
Hi guys,
Just after some feedback from other racers on Ceramic Ball Bearings, i was thinking of getting my TCXX kitted out with these bearings is it really worth it you think over the standard ones?
Thanks for your time.
Texco is offline   Reply With Quote
Old 11-13-2012, 04:42 AM   #505
JonboyGB's Avatar
Hi
Does anyone have the internal ratio of a TCXX when using the optional centre pulleys 19t and 18t?
JonboyGB is offline   Reply With Quote
Old 11-13-2012, 06:03 AM   #506
Originally Posted by JonboyGB View Post
Hi
Just divide the number of teeth on the spool/diff by those on the centre pulley.
39/19 or 39/18
THancock is offline   Reply With Quote
Old 11-13-2012, 08:59 PM   #507
Fred,
Just wanted your input with the one piece FR and RF .5- 1.0 blocks. What does widening this part actually do to the handling of the car?
Old 11-14-2012, 03:25 AM   #508
Originally Posted by goots View Post
Fred,
Actually using those blocks (1.0FF & .5FR) will make the front of the car narrower than using the kit setup of 1.5FF & 1.0FR. That configuration will generate more initial steering and the .5* of arm sweep will give back some of the mid/exit steering you lose by making the front end narrorwer.
Old 11-14-2012, 08:08 PM   #509
So at the moment Im running 2.0FF & 0FR up front. Sweepeing the FR I will gain more mid/exit steering.
How will this apply to the rear blocks of the car? im currently running one piece 0RF & 2.5RR blocks
Also not to be impatient but, Yokomo got their spares up on amain. When will we get ours
Old 11-14-2012, 08:34 PM   #510
I don't understand the point of your question about how this would apply to the rear of the car because arm sweep doesn't apply. Let me ask if you understand the effect of running less rear toe? Guys I've said this a couple times before, everything is in stock at HB USA if you need something contact your LHS and have them order it unless you want to pay more by ordering directly from HB. If you just want to see what the parts look like then you can look at the HB Europe site but even then you can't order the parts from that site. So please support your LHS by having them order the product you are looking for, they will appreciate you for it The part numbers for all spares and option parts are in the manual
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Borr
