Old 11-01-2012, 11:37 AM   #421
Fred Hubbard's Avatar
Originally Posted by Kensei View Post
- what brand of spurs best to use on this car for stock racing?
- are double jointed front axles available?
Originally Posted by NolanP View Post
Yes you can get dcj's although you do need a different outdrive
I've heard that the RW gears will work as well. We have both the 2.4mm and 2.0mm pinned DCJ's available now.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 11-01-2012, 12:16 PM   #422
NolanP's Avatar
Fred you going to Cleveland for thanksgiving.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 11-01-2012, 12:25 PM   #423
Partnumbers for 2.4mm and 2.0mm pinned DJC's?
Partnumber for the outdrives needed for these?
Partnumbers for RW spurs?
MACH Heemstede worlds 2012 piston 6x1.3 and 6x1.1 were used.
These are not in the kit.
Partnumbers?
Kensei is offline   Reply With Quote
Old 11-01-2012, 12:25 PM   #424
Yes if I want a divorce
Old 11-01-2012, 12:32 PM   #425
You guys still sand the edges of graphite parts and treat with CA?
Frankly, lately I don't bother anymore. But hey, maybe that's is all wrong....
Old 11-01-2012, 02:13 PM   #426
Originally Posted by cyclonetog View Post
Depends where you're running. On carpet a little rebound (about 3mm) seems to help make the car more easy to drive and feels like it has a little more forward traction. On tarmac, generally no rebound seems to give the most grip.
For no rebound, fully compress the shock then fit the bladder and cap before you pull the shaft back out.
No rebound gives the most grip on tarmac ?? are you sure this is right. I always thought it was no rebound for carpet and half to full rebound for tarmac.
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 11-01-2012, 02:17 PM   #427
NolanP's Avatar
So your going to Cleveland and your gonna be single? Nice....Clubbin
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 11-01-2012, 02:45 PM   #428
Yep, I did say "generally".
More rebound helps on bumpier tracks and riding curbs so you can end up running more.
I'd expect to run some rebound at say, Cotswolds and Bedworth. None at Snetterton for example.
You could probably do a faster lap on carpet with none, but it's just too hard to drive.
cyclonetog is offline   Reply With Quote
Old 11-01-2012, 03:55 PM   #429
Originally Posted by AGNO View Post
With pistons 6x1,1 I use oil 500 Much More and work very well... at the last race with 13.5 Boost I scored the two best best lap of the race, the ambient temperature was 32 c(90f).
Tyres Sorex 36
Track medium grip
So that would bel 500Cst? So that would be about 41WT.
What is Losi 90 in WT or Cst?
At the worlds 2012 in The Netherlands piston 6x1.3 with 2000Cst is used. Any comments on that?
What partnumber would that be?
Old 11-01-2012, 04:10 PM   #430
The only true way to know what 90wt may be in cSt is to try different oils to know what they feel like.
You can find the part number for our option 6 hole pistons at http://hotbodiesonline.com/ We only offer 1.1mm and you would have to drill them yourself to 1.3mm.
Old 11-01-2012, 04:18 PM   #431
Dusttt's Avatar
Trader Rating: 118 (100%+)
What is Losi 90 in WT or Cst?.
http://www.ptrcracing.com/Technical-Data.html
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 11-02-2012, 03:12 AM   #432
http://hotbodiesonline.com/piw.php?partNo=67699&lang=en
Thought of buying me the above. But now I am a bit confused as to 2.4mm and 2.0mm. Are these two different versions, or what?
Also looking for the spring set part number. Thought I saw it floating around somewhere on this thread. Been searching for almost an hour. Didn't find it. My bad.... Please help?
Do Corally HMX and RDX Phi'09 springs fit the TCXX?
Yeah I know HB springs are the best, but I still have all kinds of Corally springs and thought I might use them.
Where best to buy TCXX stuff when living in Western Europe?
Coming from RDXPhi`09 and Asso TC5 and TC6 I always sanded the chassisplate and sealed it with CA. I see more and more racers that don't bother anymore. I am considering going that direction also. Any comments?
Old 11-02-2012, 03:18 AM   #433
Originally Posted by wwddww34 View Post
The spur has to have a 4-hole pattern just like the Xray spur gears have. There are a handful of spur gear manufacturers (e.g. Xray, RW Racing, Kimbrough) that put this hole pattern in their spur gears.
Thanks.
Could one please provide me with part number?
(because it seems there are all kind of spurs, as I learned the hard way with RW Racing spurs....)
Recent information from UK distributor:"The TCXX is a normal spur gear fitting, so the RW ones should fit without a problem, although some of them will only fit with two screws rather than the four that the HB spurs use."
For sure I don't want the ones that only fit with two screws. It has to be four screws, as it was intended.
So the part number is important, in order to avoid wrong ordering.
FYI 48DP for stock racing FDR 3.5 to 4.5.
Old 11-02-2012, 07:59 AM   #434
Originally Posted by markrobinson View Post
I run X-ray spurs on my TCX.
Which partnumbers?
Fit also for TCXX I presume?
Has to be 48DP for stock racing FDR 3.5 to 4.5.
On these spurs you can use all four bolts?
Old 11-02-2012, 08:23 AM   #435
Default Spurs 48DP for HB TCXX
Do some of these fit?
http://www.the-border.com/Spurs-48DP/
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
