Hot Bodies TCXX
#331
#332
LINK TO MY CARPET SETUP FOR FRED
https://www.box.com/s/stijxni2alxxdmqzm8dj
Fred if you can take a look and let me know your thoughts I would be very interested in your setup ideas
#333
#334
just let us know when HB USA website is updated. I want just a few parts to update my car to a full blown tcxx
#335
I'd go back to silver springs all round, shock tower pos 2 front 4 rear.
I see rebound has vanished off the sheet, 3mm is a good starting point on carpet if you aren't on that already.
I'd consider trying short camber links though I see different results with that at different tracks so just try it's not a given.
If you've measured the droop as per the sheet (to centre of the pin) there's way too much, about 9mm all round is a good starting point.
A thicker real roll bar would add stability.
I'm still undecided on wheelbase, but you're way off what most people seem to run. At the front running all the spacers in front of the arm seems to work well and at the rear 2mm behind the arm and 2mm behind the hub is quite common.
I've never seen anybody run the 2nd hole on the 3 hole knuckle, the 3rd hole should calm the car down a lot.
The TypeC shell is awesome if the car is working well, but it has a hell of a lot of front end so I'd recommend using a Speed6 until you've made the car easier to drive.
#336
I'm not being funny but I'd change almost everything on that setup, if I tried to run that on my TCX it'd be undriveable.
#337
Trust me the silvers all round are much safer than gold blue. The effect you felt was probably just the bite coming up on the track, I've tested it over and over and over again.
To get more throw use the upper hole in the servo saver, if you haven't done that already. (that in itself would make the car more twitchy so use some negative expo to counter it).
The shock positions will make a huge change also, it may seem backwards but leaning the fronts in makes the car turn in much smother, and standing the rears up gives more bite.
#338
#340
Thanks Fred, I will take this setup with me to the next round, ive got a few things to try now. The track is big even by our standards. Do you run the standard HPI/ HB servo saver than comes in the kit. I have been using an Xray servo saver. When I used the hb servo saver I couldnt get full steering lock when using the 3rd hole in the front hubs ?? not sure why. When the car is on the Hudy setup gauges how much left/right steering throw should I be getting ?
#341
With the standard servo saver you can make about 25 - 27 degrees of lock if you use one of the top corner holes on the servo saver, but make sure you rotate the saver and also sub trim if needed so that that position is then at 90 degrees to the link in neutral , thats with position 3 on the hub
Stef
Stef
#342
Stef
Stef
#343
#344
Hi Fred,
Just a quick question, your setup for the speedtech grandPrix you used the #68480 2 piece pivot block R/F at the front of your car can you sub that with the #75156 1 piece pivot block?
thanks for your time mate!
