Old 10-13-2012, 06:30 AM   #316
NolanP's Avatar
Originally Posted by cyclonetog View Post
Ideally the angle between the servo arm and the turnbuckle should be 90degrees. I almost always find that setting the trim to zero and then moving the servo saver 1 tooth from vertical gets it about right, then adjust the length of the turnbuckle to set the rack central.
Yeah Ideally of course. But not everyone car allows for the clearence to do so. So some cars actually state be off center.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-13-2012, 10:53 AM   #317
Default TCXX INTERNAL GEAR RATIO ????
Ive looked through the manual and cant find it any where, Im guessing its the same as the TCX ??
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 10-13-2012, 01:12 PM   #318
Big pulley / small pulley.
39/20 = 1.95:1
cyclonetog is offline   Reply With Quote
Old 10-13-2012, 01:48 PM   #319
39/20 = 1.95:1
thanks
Old 10-14-2012, 08:18 AM   #320
Jim_1987's Avatar
I need a new chassis for my tcx, I was wondering will a tcxx chassis fit, do all the holes line up?
Team MMR Flux - www.mmrflux.co.uk
Jim_1987 is offline   Reply With Quote
Old 10-14-2012, 12:04 PM   #321
Trader Rating: 20 (100%+)
Yes they do, but steering posts are moved 2mm back on the tcxx. So if you want the same ackerman change as the tcxx you need bottom deck, new long steering posts, and 3 hole steering hubs.
goots is offline   Reply With Quote
Old 10-14-2012, 12:17 PM   #322
I've been running my TCX on my TCXX option chassis. If you add 2mm to your ackerman spacers you get the same arc as when it's on the TCX.
As goots says, it won't mimic the TCXX arc without the longer arms.
You won't be able to screw the rack brace to the top deck, but I've never seen anybody do that anyway.
All that said, I think my TCX feels better on the narrow TCX chassis than on the TCXX option chassis.
Old 10-14-2012, 03:29 PM   #323
Default 1ST Run With the TCXX
Well today was the 1st race meeting with the TCXX, In practise and the 1st qualifier the cars front end was very aggresive, the back end of the car could'nt handle it and was very loose. I had started the day on the kit setup and kit springs. I tried hpi gold springs on the front which helped abit. Next I tried making the rear wheel base longer which again made it abit better but I still couldnt keep up with the front runners. For the final I tried Hpi blue spings on the rear and leaned the rear spings in one hole. For the last qualifier and the final I also ran new tyres (sorex 28 JB blue insert) which to be honest was the best thing I did all day. In the final I was able to keep up with the TQ man untill my bodyshell caught up and I dropped back a bit. I was fairly happy with the car for its 1st run but found the car way to aggresive for my liking. Also I dont like the idea of having to bolt on new rubber to sort the car out every other run. Im running 13.5 boosted on indoors on carpet at the moment. Im thinking of trying thicker rear geardiff oil maybe 2000 cst to try and sort the on power push. If any one has a good carpet setup I would be interested in seeing it.
Old 10-14-2012, 11:51 PM   #324
Airwave's Avatar
Interesting feedback!
I'm gonna try my TCXX in few weeks...
Could you please publish your Hobbywing setup for 13.5 boosted? These setups are far harder to find than chassis ones!
Thanks in advance...
Airwave is offline   Reply With Quote
Old 10-15-2012, 10:38 AM   #325
Fred Hubbard's Avatar
Like with any new car you will have to figure out the setup that works best for your driving style. So although you don't sound discouraged if you are don't be Please give me your complete setup so that I can make some suggestions.
All: Just a reminder that 95% to 100% of TCXX spares and options parts are in stock at HB USA so if you are looking for something please speak with your LHS and ask them to call/email their HB distributor for ordering.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 10-15-2012, 02:21 PM   #326
AGNO's Avatar
Also for me, the first race with TCXX!
Good race, third place, race on asphalt, 13.5 boost, Sorex 36 tires, semi-standard setting excellent performance of TCXX with cold track and low traction.
Less constant performance with higher temperature ... (not so high)
Fantastic gear diff!: nod:
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 10-15-2012, 02:46 PM   #327
AGNO's Avatar
I use Hobbywing V3 and 13.5 HW , excellent performance on the medium track with these settings.
Old 10-15-2012, 02:48 PM   #328
Originally Posted by AGNO View Post
...Less constant performance with higher temperature ... (not so high)
How so?
Old 10-15-2012, 03:46 PM   #329
AGNO's Avatar
Originally Posted by Fred Hubbard View Post
How so?
With high ambient temperature, it seemed that the tires front / rear, early in the finals manche, they are heated at different times, the drive was difficult, not constant, from the middle, the end of the manche the drive was better.
Maybe too thick oil shocks? standard oil 500...
Excuse my bad english...
Old 10-15-2012, 08:28 PM   #330
Hi Fred, I tried to upload my setup onto here but it said the file was to big ?? Any ideas ?
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
