Old 10-09-2012, 07:31 PM   #301
Fred Hubbard's Avatar
Originally Posted by haywood View Post
Car looked great at the IIC! Was cool to talk to the Hot Bodies guys at the meet and greet taco bar! Fred is a great guy and was very helpful all week!
Thanks for the kind words, they are appreciated. Embarssingly enough I forget your name
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 10-09-2012, 11:32 PM   #302
MUGEN_MAN_666's Avatar
Default Rear Belt
Hi guys do you know of any other brand's of rear belt that will fit the car e.g. xray, yokomo, just rear belts for this car are hard to get in Australia atm
thanks
MUGEN_MAN_666 is offline   Reply With Quote
Old 10-10-2012, 04:31 AM   #303
Default TCXX drive shafts
Im not sure why Hotbodies supply ally front drive shafts and steel rear drive shafts, but can I run the ally shafts in the rear and the steel shafts up front. This would make more sense to me like on the Xray's
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 10-10-2012, 05:56 AM   #304
No, you can't run the new shaft in the front, it's too thin.
Using the thin steel shaft actually has less flywheel effect than a thicker alloy drive shaft but the ball on the steel one lasts much longer than the alloy one, so you get the best of both worlds.
The front shaft has to be thicker, so the alloy one gives the best performance, which is why you get it in the kit. For longevity over performance you'll need to get hold of a steel shaft and TCX spool cup.
cyclonetog is offline   Reply With Quote
Old 10-10-2012, 01:16 PM   #305
Why does the geardiff on the TCXX have a grub screw in the side of it ? Ive been told to glue it in ?? Why was the grub screw put there if it isnt used. I assumed it was to release some oil when over filled.
Old 10-10-2012, 01:22 PM   #306
I was thinking this. I built one for my tcx last night (bearing in mind iv never ownd a gear diff befor) its got 2 grub screws in it one each side and again I glues it with the ruberish glue. But when I filled it up I want realy sure where to fill it too (again never had or used one befor) so I filled it to just over the gears, then took the grub screw out put the cap on screwd the 4 screws up,a bit came out the grub screw hole. Then I put a tad of glue on the grub screw and put it back in. Will this be ok or am I wrong lol.
bob33 is offline   Reply With Quote
Old 10-10-2012, 01:22 PM   #307
I've run it both ways without any leaks. If you want to use it to remove excess oil then you don't have to glue it
Old 10-10-2012, 03:15 PM   #308
Thanks Fred, But how much oil should we put in the new Geardiff ?? Im comming from an Xray T3 12 and I used to weigh my diff while filling with oil. Do the Hotbodies team do this ??
Old 10-10-2012, 06:22 PM   #309
trigger's Avatar
Hey Fred, miss your expertise on the xray forum. I gotta come out and run so i can hang with you more. Seems like yesterday when i was the noob coming into Socal raceway and ruining your runs(Probably about 13 years ago).I hope you are enjoying your new ride. Who am i kidding, i know you are.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 10-11-2012, 05:09 AM   #310
It says in the manual, fill to just over the cross pin. I glued mine it prevents any leakage, if u over fill then pour a little back out. By the time it needs refilling ( which I doubt it will amazing design they only need refilling when they leak this diff don't leak) u will change the oil for fresh any way.
Jampot is offline   Reply With Quote
Old 10-11-2012, 08:18 PM   #311
<PsOp>
Guest
Posts: n/a
Gear diff available yet? where can I buy one thanks.
Old 10-12-2012, 12:49 AM   #312
Thanks Minh, LOL it does seem like yesterday, time flies I am extremely happy with the new ride
Spare and optional parts are in stock at the HB USA, I just received a bunch of blocks, gear diffs, etc yesterday. I just don't know how long it will be before they are put into the system for viewing/ordering from the website or by your LHS.
Old 10-12-2012, 03:42 PM   #313
Default TCXX servo horn question
Iam using the kit servo horn, should it be vertical to the chassis ?? Im finding it difficult to get even steering throw left to right. Ive got to say the TCXX instruction manual is crap !
Old 10-12-2012, 08:28 PM   #314
NolanP's Avatar
I agree building the kit was like bashing my head against the wall with the instructions and bag location and lack of specifications.
Thank god the car is easy to drive.
Try lowering the ball and going offset. So don't put it 90 degrees.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-13-2012, 04:48 AM   #315
Ideally the angle between the servo arm and the turnbuckle should be 90degrees. I almost always find that setting the trim to zero and then moving the servo saver 1 tooth from vertical gets it about right, then adjust the length of the turnbuckle to set the rack central.
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
