Old 10-08-2012, 11:50 AM   #286
The original TCX cups were the short ones, the kit came with 46mm drive shafts.
There was a shortage of 46mm shafts and the 44mm ones were too short to fit the spool cups.
In the end HB brought out the long cups (68769) so people could use 44mm shafts in the front.
The upshot is that the long cup works with both length shafts and the short cup has to be used with 46mm shafts.
If you mean why can't you use the TCXX cup, it's because the drive pin is a different diameter.
cyclonetog is offline   Reply With Quote
Old 10-09-2012, 01:34 AM   #287
Texco's Avatar
Does the Spec-R's HB-TCX spur gear adapter and pulley set fit the new TCXX?
thanks guys
Texco is offline   Reply With Quote
Old 10-09-2012, 01:56 AM   #288
The mounts are the same, and they are spaced the same, so I'd have to assume that they will fit both cars.
Old 10-09-2012, 02:32 AM   #289
AGNO's Avatar
thanks guys
Yes, you can use, but it needs, the TCX center shaft #68727.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 10-09-2012, 05:06 AM   #290
Texco's Avatar
Thanks AGNO for the info!
I tried to use the Spec R's C.V. Universal Swing Shaft Version 2(For Tamiya TRF416/417) 44mm thinking it would fit but knuckle hits the C Hub when you turn it left or right, would getting the Spec R's C.V. Universal Swing Shaft (For Hot Bodies TCX)Version 2 46mm fix the problem?
thanks guys for your time..
Old 10-09-2012, 06:23 AM   #291
AGNO's Avatar
No problem in the use of double joints Spec-r 46mm, remember for to use the shafts Spec-R, require the Spool cap TCX #61087, #68770 or #68769.
Old 10-09-2012, 09:18 AM   #292
Dusttt's Avatar
Trader Rating: 116 (100%+)
Fred,
Do you have an option parts list yet? I dont see one on the sites.
I got the Tamiya rear hubs mounted and it did require shorter ball studs or drilling out the plastic so it wouldnt hit the pin retainer. Do you mind telling us the advantage of these?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 10-09-2012, 09:25 AM   #293
Fred Hubbard's Avatar
Originally Posted by Dusttt View Post
Fred
Page 32 of the manual.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 10-09-2012, 10:16 AM   #294
bvoltz's Avatar
Trader Rating: 44 (100%+)
Does any one have a source for the 6 hole pistons? Or even 3 hole, I will drill out the other 3 holes if needed...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 10-09-2012, 10:19 AM   #295
They are instock at the HB factory:
68768 - 6 Hole Pistons
Old 10-09-2012, 10:22 AM   #296
Dusttt's Avatar
Thanks! Just didnt know if that was all stuff that was out.
Old 10-09-2012, 11:14 AM   #297
Trader Rating: 77 (100%+)
Nice work Fred at IIC. Looks like you like the new ride.
goin2drt is offline   Reply With Quote
Old 10-09-2012, 04:10 PM   #298
Texco's Avatar
Thanks again AGNO!
I ordered the #61087 so the Spec R's C.V. Universal Swing Shaft (For Hot Bodies TCX)Version 2 46mm should be right to use now!
Old 10-09-2012, 04:16 PM   #299
Thanks Todd, it was a good result but I'm a bit of an overachiever and didn't quite measure up to my own standards
Old 10-09-2012, 07:22 PM   #300
haywood's Avatar
Trader Rating: 48 (100%+)
Default Tcxx
Car looked great at the IIC! Was cool to talk to the Hot Bodies guys at the meet and greet taco bar! Fred is a great guy and was very helpful all week!
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
