Old 10-06-2012, 07:24 AM   #271
NolanP's Avatar
Just so you know for all the Hot Bodies, Spec-R, Ae noobs out there like me. If you feel some grit in the rear diff run the car. It breaks in super smooth.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-06-2012, 09:21 PM   #272
Fred Hubbard's Avatar
Told you so!
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 10-08-2012, 05:13 AM   #273
MUGEN_MAN_666's Avatar
Hi guys do you know of any other brand's of rear belt that will fit the car e.g. xray, yokomo, just rear belts for this car are hard to get in Australia atm
thanks
MUGEN_MAN_666 is offline   Reply With Quote
Old 10-08-2012, 05:39 AM   #274
Default TCXX Team Build Tips
Hi Guys, I have just got one of these and before I start building im wondering if there are any tips that I should now ?? Like should I build the shocks with 2 O rings ?? stuff like that
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 10-08-2012, 06:24 AM   #275
NolanP's Avatar
My biggest tip for the car is make sure you have something where you can fully organize the "bag of plastic parts" vs the normal bags.
I know that's not a pro tip. But this kit can be very confusing. As well as make sure you align the arms on the correct side during the install.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-08-2012, 07:19 AM   #276
Default steel front drive shafts 88914
A few people have told me that the front ally driveshafts were a weak spot on the TCX so they use these steel drive shafts 88914. Will these still fit the TCXX as the drive shafts on the TCXX have a 2mm pin compared to a 2.5 mm pin on the Steel drive shafts
Old 10-08-2012, 07:35 AM   #277
NolanP's Avatar
If you buy the dcj's make sure you buy the optional out drives.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-08-2012, 08:12 AM   #278
Thanks, but do the steel drive shafts I mentioned fit the TCXX they are 46mm long ?? is that to big ??
Old 10-08-2012, 08:23 AM   #279
The Teacher's Avatar
Trader Rating: 46 (100%+)
Can someone tell me where you can get parts for the TCXX at...??? I'm looking to get the chassis, motor mount, servo mounts and the steering rack.
The Teacher is offline   Reply With Quote
Old 10-08-2012, 08:45 AM   #280
TCXX Build Tips
I will find out and get back to you since I only run our 44mm shafts.
Look here
We did have a bunch of spare and option parts come into the factory over the past 2 weeks so if the HS doesn't have them in stock they will need to call and check to know when the part(s) will be in the system for ordering.
speedtechhobbies.com
tqrcracing.com
stormerhobbies.com
amainhobbies.com
Old 10-08-2012, 10:14 AM   #281
Hi, don't use 88914, the fit isn't perfect and they need to bed in. I have some in my TCX now but I wouldn't buy any more.
Instead use 68794 much better fit with the TCX steel outdrive 68769 or 61087 whichever you can get hold of works fine.
cyclonetog is offline   Reply With Quote
Old 10-08-2012, 10:22 AM   #282
Thanks, Those you mention are 46mm long but on the new TCXX the front drive shafts are 44mm long. Does it matter switching between the 2 ?? what other changes will I need to make in order to run 46mm front drive shafts/ dog bones
Old 10-08-2012, 10:54 AM   #283
AGNO's Avatar
46mm work well on the front TCXX
I use Spec-R double cardan 46mm, strong and no chattering, need to use the old steel joints 61087 or joints POM 68770.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 10-08-2012, 11:10 AM   #284
The other advantage of the 46mm shaft is that you can use either spool cup. If you use a 44mm shaft then you'll have to use the long one, which is a pain if they go out of stock. I actually think the shorter cup is stronger too.
Old 10-08-2012, 11:39 AM   #285
Thanks for all the replys, but I have to ask. Why do I need to change the spool cups when I change the front drive shafts / dog bones from 44mm to 46mm ??
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
