Like Tree2Likes
Old 01-02-2015, 06:22 PM   #2041
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Originally Posted by k_bojar View Post
makes you wonder why the manufacturers went away from this kind of setup - or maybe schumacher had the right idea all those years ago
hmmm... guess I'm going to have to take some time and do it to mine I'm guessing 4* camber c-hubs? and L-hub on the R-rear?
Yes, front end parts on the rear, you want the 4* c hubs to stay on the correct side so they lean back like the fronts.
I screwed long ball studs into the bottom side of bulkheads in the forward hole, no shims. I didn't want to drill the chassis.
You can change the action of the rear steer depending on what hole you mount the links and how low you shim them in the steering knuckles.
(Photo on xray site explains)
ALSO I drilled and tapped the arms so I can mount the shocks out where they need to be
I set the wheels up to be square with the arms, using only the toe blocks to adjust toe.
The car really feels different to drive...It feels like the rear end will snap around but it doesn't. It's actually more like throwing a lasso at the apex and swinging around.
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 01-02-2015, 06:29 PM   #2042
Chrisgt2's Avatar
Oh btw, I went to the NORCAR Hangover Dash yesterday.
VTA TQ & Win
USGT TQ & Win
17.5TC TQ & Win
Hot Bodies Pro 5
*Sponsors*
Old 01-03-2015, 01:27 AM   #2043
EvaldasD's Avatar
Originally Posted by Chrisgt2 View Post
Real proven potential on the track as well.
Nice that it works for you. Have you put it on setup station? If so, what toe angle differences do you get? I'm getting 3 when fully compressed (0mm ride height), 1 before wheels leaves the ground, about 1.8 at normal ride height.
And about c-hubs, is there a noticable difference regarding sides? I have put L c-hub on R rear, R c-hub on L rear, it's like "X" front/rear.
Hot Bodies - HPI - LRP - Sanwa
EvaldasD is offline   Reply With Quote
Old 01-03-2015, 05:15 AM   #2044
Chrisgt2's Avatar
So you are gaining toe as the suspension loads? That's not good if so. From the way your links are mounted in the chassis, it looks like the case.
The inner link needs to be higher than the outer to reduce toe when the car loads in the corner.
As for the c hubs, you wouldn't want them leaning forward, the Awesomatix car runs 4* caster in their rear steer
I haven't had mine on a setup station.
However my lap times instantly dropped .5 sec on a 9-10 sec track.
Hot Bodies Pro 5
*Sponsors*
Old 01-03-2015, 05:46 AM   #2045
EvaldasD's Avatar
My predictions were wrong then. Though I saw some pictures of Awesomatix car that inner link was lower than outer. Shouldn't the car become twitchy on acceleration when rear toe reduces at that moment? In modified I suffer alot from that behavior
Old 01-03-2015, 05:56 AM   #2046
Chrisgt2's Avatar
My links are nearly level at ride height, just a slight angle. it's when the suspension loads that the angle pushes the wheel out at the outer wheel.
It does feel a little sketchy accelerating out of the corner but it was easy to adapt to. I don't run much modified, but you would run more rear toe. I'm at 2*, so I actually have toe out in the corner at the outer wheel.
Running less front droop would help keep the car more stable for you?
Here is what I found on the xray site.
Hot Bodies Pro 5
*Sponsors*
Old 01-03-2015, 07:08 AM   #2047
EvaldasD's Avatar
Thank you for info, I will try that at the track soon.
Old 01-04-2015, 03:49 PM   #2048
Of course the picture addressed only what happens to TOE of the right wheel as a car turns left. With the inner link higher than the outer link,(on both sides of the car) the left rear tire gains toe with chassis roll in a left turn (or in words both rear wheels will steer to the outside of the turn - causing rear steer). We did this with oval pan cars equipped with independent rear pods and some even figured a way to do it with T bar cars. Works well but it becomes very critical to controlling the roll of the car to keep it from getting too free in the rear. A little bit of rear steer goes a long way.
John Wallace2 is offline   Reply With Quote
Old 01-18-2015, 12:33 PM   #2049
EvaldasD's Avatar
Last night I tried out that "active toe" thing on track. I tried both rear steer effects (outer link higher and inner link higher). It was really nice to see that it gives something new, though the track I was at was quite small, slow. Both steer effects are good and drivable, it depends on what you need from your car. With outer link higher car was very calm and predictable, super smooth, not too much steering. Inner link higher - opposite, loads of mid corner steering, twitchy at the exits so smooth throttle control should be in mind.
Next weekend I will be giving another shot, this time in modified at huge carpet track.
Old 01-18-2015, 12:39 PM   #2050
Chrisgt2's Avatar
Yes, I found that once I got used to the false feeling that the car was spinning out and realized that I could drive it hard into the corner I really killed some hot laps.
Old 03-03-2015, 02:06 PM   #2051
LKF
great to see you in developing active toe systems for tcxx
here some facts and summary about tcxx update kit / tcxx 2014 kit and a german report about these kit.
LKF is offline   Reply With Quote
Old 03-03-2015, 08:42 PM   #2052
Trader Rating: 20 (100%+)
that's a very detailed article with all the measuring done. I am glad I purchased the update packs on my 2 cars.
goots is offline   Reply With Quote
Old 03-17-2015, 06:31 PM   #2053
Chrisgt2's Avatar
I am going to list one of my TCXX's for sale tonight! Just a heads up
Old 03-17-2015, 06:48 PM   #2054
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
VTA TQ & Win
USGT TQ & Win
17.5TC TQ & Win
What motor did you run in the vta and usgt?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 03-17-2015, 06:52 PM   #2055
Chrisgt2's Avatar
Novak Boss in VTA
Team Scream 21.5 in USGT
Team Scream 17.5 in 17.5 (obviously)
Hot Bodies Pro 5
*Sponsors*
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
