Old 12-09-2014, 08:18 PM   #2026
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Thanks guys!
I am running the new motor mount. It's the only part I updated on the VTA car.
I am happy to help whenever I can, I'll try to answer any questions you have
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 12-09-2014, 11:33 PM   #2027
Trader Rating: 20 (100%+)
Originally Posted by Chrisgt2 View Post
Thanks guys!
ok. So what is the purpose of the V2 knuckles and how many shims should be used on the steering rack? Also, What is the purpose of using the older -2 steering arms on the TCXX chassis?
thanks
goots is offline   Reply With Quote
Old 12-10-2014, 04:41 AM   #2028
Chrisgt2's Avatar
thanks
The V2 knuckles change the Ackerman to a more "updated" angle, in fact you can use the BD7 knuckles as a direct replacement in a pinch.
I run 1mm shims on the rack most times that way I can add or remove for feel.
Same with the older rack, it just allows for more of an Ackerman adjustment, but I can't comment on that because I onlybuse the TCXX rack. I know JJ uses it sometimes.
Hot Bodies Pro 5
*Sponsors*
Old 12-19-2014, 07:30 AM   #2029
I liked the TCX motor mount (moves the motor more inboard) in my TCXX based VTA car so much (despite it being a real PITA to change the gears), I'm trying one in my TCXX based USGT car this weekend. Weather permitting I'll report back Sunday after two days of racing at two different tracks.
Chris What is the part number of the motor mount you are using in your VTA car? How is it different than the TCX and TCXX mounts?
John Wallace2 is offline   Reply With Quote
Old 12-19-2014, 09:21 AM   #2030
The newest mount raises the motor 2mm, brings the motor in like tcx mount, and extra screw mounting for motor which is easier to set gear mesh.
Old 12-19-2014, 03:33 PM   #2031
Part number for that please? or is that what they call the heavy duty motor plate/mount?
Old 12-19-2014, 03:57 PM   #2032
Chrisgt2's Avatar
111197 ONE-PIECE MOTOR MOUNT
There ya go guys
Old 12-19-2014, 04:36 PM   #2033
There ya go guys
Thanks Chris. Does this get the motor even closer to the center line than the TCX motor mount? Doesn't look like it fixes the gear change problem with VTA and USGT sized spurs and pinions, still going to be a PITA. Only good thing at least for me is I don't change those FDRs very often.
Old 12-19-2014, 04:38 PM   #2034
Chrisgt2's Avatar
Same as the tcx mount except it raises the motor for more roll. If anything it makes the gear harder to change cause it's closer to the top deck.
Old 12-19-2014, 04:55 PM   #2035
Perhaps the next time I get something from RCMart I'll order one. Right now I'm trying to get the CG as low as possible and playing with roll centers for roll. Our tracks usually have long straights with a fast full throttle sweeper at about the 130 to 160 ft point. Usually I have too much roll.
Old 01-02-2015, 02:25 PM   #2036
EvaldasD's Avatar
I will be trying out how this mod works. It shows potential on the setup station.
Hot Bodies - HPI - LRP - Sanwa
EvaldasD is offline   Reply With Quote
Old 01-02-2015, 05:34 PM   #2037
Chrisgt2's Avatar
Real proven potential on the track as well.
Hot Bodies Pro 5
*Sponsors*
Old 01-02-2015, 06:47 PM   #2038
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
looks good chris - I'm not sure how I feel about going backwards to this 'old' technology setup, but it looks good
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-02-2015, 06:53 PM   #2039
Chrisgt2's Avatar
It's about something more than that.... It's adding a new feature.
Rear steer, the car really rotates and carries corner speed. I literally shaved .5 seconds a lap. It was astonishing to say the least.
Hot Bodies Pro 5
*Sponsors*
Old 01-02-2015, 06:56 PM   #2040
k_bojar's Avatar
makes you wonder why the manufacturers went away from this kind of setup - or maybe schumacher had the right idea all those years ago
hmmm... guess I'm going to have to take some time and do it to mine I'm guessing 4* camber c-hubs? and L-hub on the R-rear?
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
