Old 11-14-2014, 07:56 AM   #2011
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Originally Posted by John Wallace2 View Post
Thanks Chris At least I know I'm going in the right direction, you're just running a shorter wheel base in the front than me otherwise its just minor spring differences I'm using HPI Silvers. Only surprise is that you were not using the Arrowmax chassis in VTA. My USVTA legal car with the Arrowmax chassis and NO extra weights comes in at 1553 grams and that is with the big TEKIN ESC.
BTW Which HPI spring is closest to the Yokomo Blues?
I just never ordered one for the VTA car, plus I figure the carbon flex helps in VTA.
Yokomo Blue springs are rated 14.8lbs
HPI silver are rated at 16.9lbs
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 11-14-2014, 09:13 AM   #2012
So the Yokomo blues are just slightly softer that the HPI blues (15.3). I was thinking LOW CG with the Arrowmax Chassis and using the carbon fiber chassis with the floating servo mount for flex on my 17.5 car. I never ran the VTA car with the TCXX carbon fiber chassis, just switched from the TC chassis to the TCXX with the Arrowmax chassis and that was a big improvement. Let me know what you think of the VTA car with the arrowmax chassis.
John Wallace2 is offline   Reply With Quote
Old 11-14-2014, 09:24 AM   #2013
Chrisgt2's Avatar
I think you should try the aluminum chassis in 17.5, and the carbon in VTA with thin top deck.
The aluminum may work ok in VTA, but my car works so well I wouldn't change it. The VTA tires need the grip
I have my car set to roll and rotate thru the corners, it never squares off and loses momentum.
Hot Bodies Pro 5
*Sponsors*
Old 11-14-2014, 09:36 PM   #2014
Trader Rating: 20 (100%+)
can someone explain the use of the older TCX steering rack arms. I have never tried it and always used the TCXX +2 steering rack arms. Im just wondering why some setups call for it.
goots is offline   Reply With Quote
Old 11-14-2014, 11:19 PM   #2015
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
Default TCXX
anyone looking to unload a tcxx (hopefully with the upgrade kit). If yes send me a PM.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 11-15-2014, 05:03 AM   #2016
I might try that for the VTA and USGT cars (both TCXXs), just have to swap out motors and batteries and add mucho lead for to the VTA (that arrowmax chassis is ~60 grams heavier than the stock TCXX chassis). I also have the thin top plate and the floating servo pod on the USGT car already.
Old 11-15-2014, 11:02 AM   #2017
Is there a US source for the Hot Bodies DCJ V2 part (HPI111191)? I Googled it and only get European sources.
BTW I also Google that aluminum spindle and found two sources that indicate they have the part in stock HobbyQuarters and Hoobywarehouse. I know nothing about those sources so I suggest you call and make sure they have the part in stock before ordering.
Old 11-15-2014, 11:05 AM   #2018
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I actually found some on eBay - Phil's hobby shop - so personally, I'm good there if/when I decide to go that route. my TCXX works so well in its current layout, not sure how much I want/need to change
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-17-2014, 03:29 PM   #2019
Default CHRISGT2 SETUPs
FYI/SA Confirmed with Chris that the droop measurements on his TCXX setup sheets are measured "above ride height" not to the center of the outer hinge pin as might be interpreted from the diagram on the TCXX setup sheet.
Old 11-22-2014, 11:54 AM   #2020
I received an email from Amain that my backorder for those aluminum spindles has arrived. Anyone still interested might check back with A Main
Old 12-08-2014, 03:09 PM   #2021
Default More TCXX stuff
I had been playing with setups on my VTA car and built a TCXX with an Arrowmax aluminum chassis for VTA. As I was building the car I noticed ChrisGT2 posts and his setup sheets for carpet, which except for the front end wheelbase spacers was amazingly close to what I was using outdoors on asphalt. Anyway I shortened up the front end to be like his and wow. I'm using silver springs and the Arrowmax chassis, but the rest of the VTA setup is pretty much what Chris posted below. The TCXX with the Arrowmax aluminum chassis is pretty much spot on the USVTA weight limit without any additional weight (check out the picture below - 1553 grams ready to race except for body clips). So all the additional weight (~60grams) I used to glue on top of the stock main chassis is now in the chassis for a lower CG. So far great results. Here are some pics. PS my cat, Clancey, is making sure the little guy in the car doesn't move.
Old 12-08-2014, 03:16 PM   #2022
k_bojar's Avatar
that's awesome, John - you're really trying to convince me to get that aluminum chassis
Old 12-08-2014, 05:54 PM   #2023
Chrisgt2's Avatar
Default US Indoor Championships 2014
Last weekend was the 35th annual U.S. Indoor Champs
I was able to make all 3 A Mains in the classes I entered. 17.5TC, USGT, and USVTA
Track was tight, pretty bumpy, and super high bite.
Results:
VTA - Q'd 2nd, Finished 2nd
17.5 - Q'd 10th, Finished 7th
USGT - Q'd 3rd, Finished 3rd
Hot Bodies Pro 5
*Sponsors*
Old 12-08-2014, 06:04 PM   #2024
Results:
Great job!! Keep up the nice work.
Thanks for your continued support.
Hi-LowBlow is offline   Reply With Quote
Old 12-09-2014, 08:15 PM   #2025
+1 on Congrats Chris
PS on my setup I'm using the TCX motor mount in my VTA car, not sure what Chris is using.
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
SEO by vBSEO 3.5.0
