Old 10-02-2014, 01:02 PM   #1936
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by bigb11 View Post
shaft or belt?
no idea, marvet
nothing more then a few lines about the next step blah blah blah
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-02-2014, 01:26 PM   #1937
Trader Rating: 20 (100%+)
Pro4 and ProD were shaft. I would assume the Pro 5 would be shaft
goots is offline   Reply With Quote
Old 10-02-2014, 02:24 PM   #1938
theproffesor's Avatar
Trader Rating: 46 (100%+)
Makes you wonder why they waited so long to update the TCXX with an over priced upgrade instead of just realeasing the pro5
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-02-2014, 02:28 PM   #1939
k_bojar's Avatar
most likely because they can't decide which arm is going to be the racing chassis side
Old 10-02-2014, 02:34 PM   #1940
I know right. I just finished putting together the upgrade packs. Now a new car lol. At least I'll have a collection of hb cars
Old 10-02-2014, 02:34 PM   #1941
Well right now it seems HPI side you can get parts, but its still hit or miss on the HB side.
Also did anyone ever confirm if newer TCXX kits were being produced with the update?
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 10-02-2014, 11:39 PM   #1942
I have a feeling XX will be discontinued not after the pro5 comes out. But I have a question, what is the length of the shock need to be set at with the upgrade packs low towers and short shocks.
Old 10-03-2014, 03:39 PM   #1943
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
I built mine by cutting 2mm off the shock ends and threading on till they stop.
I tried building without cutting and could not use my yokomo springs. They were too long. Had to lower the spring perch
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 10-03-2014, 09:50 PM   #1944
Do you have an exact total shock length. With the 2mm cut ball ends. Also do you have to cut all 4 shocks? The front seem to be the one with ride height problems
Old 10-03-2014, 09:52 PM   #1945
Chrisgt2's Avatar
Do you have an exact total shock length. End to end with 2mm cut off the ball end. I want to get this right since I only get one shot to cut
I didn't measure. Total length didn't change by cutting. It only allowed the spring perch to lower to allow the longer springs to fit better.
Just thread the shock end on until it bottoms out.
Hot Bodies Pro 5
*Sponsors*
Old 10-06-2014, 10:58 AM   #1946
endurohero's Avatar
Default first race of the year
I had my TCXX out this last weekend for our first race of the winter season. I had recently installed a smokem 2.25 chassis and floating servo mount. From my last post I had started with the recommended pink/blue yokomo springs and only changed front inner ball stud height to get the car in the ballpark. Thanks to everyone on this thread for helping me get my car sorted and competitive.
endurohero is offline   Reply With Quote
Old 10-08-2014, 01:32 AM   #1947
Here's my first attempt, seems to work well. Looks like a good 1/2 degree of outward movement at least. More or less action depending on the chosen hole in the knuckle.
I tried to video it but can't really see the action.
I only did the Right side so far.
Interesting, so what is the idea behind doing this? More toe only when you need it so there is better straight line speed, rear steer, or what?
I'm still using the fixed servo mount on my TCXX but would like to try the floating servo mount. Any recommendation on which to get (need part number too) Thanks in advance.
John Wallace2 is offline   Reply With Quote
Old 10-08-2014, 04:37 AM   #1948
Chrisgt2's Avatar
More of a rear steer action, lessens toe of the outer wheel thru the corner.
The best floating servo mount would be the new HB version. Part #111196
Otherwise there's one on eBay that works well. I used it. I actually have one of those I could sell cheap.
Hot Bodies Pro 5
*Sponsors*
Old 10-08-2014, 09:09 AM   #1949
k_bojar's Avatar
i have the ebay one that Chris mentioned and it works pretty well. haven't seen the HB one anyplace, so can't comment on that
arrowmax has one, but you need to use their chassis
Chris - where can you actually get one of the HB servo mounts?
Old 10-08-2014, 11:10 AM   #1950
Apex RC I think has a couple of 2014 upgrade kits. That's where I got 2 of my kits.
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
