Old 09-21-2014, 08:56 AM   #1921
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
What will you be switching to?
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 09-21-2014, 12:23 PM   #1922
Trader Rating: 20 (100%+)
I have two TCXX, I might need to get rid of one after IIC.
goots is offline   Reply With Quote
Old 09-21-2014, 12:26 PM   #1923
Chrisgt2's Avatar
I'm up to 3 now, one updated so far, next update kit on its way. Prob leave my vta car as is. Has the smokem chassis and short cso shocks.
Hot Bodies Pro 5
*Sponsors*
Old 09-21-2014, 01:23 PM   #1924
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
Where did you get the update kits from? I can't find one under 350.00. I've wanted to try the tcxx but I think I'm going with the A700L.
Access Hobbies,CRC, Detc410,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 09-21-2014, 01:28 PM   #1925
Chrisgt2's Avatar
I'm on the HB Infantry Team. They have the upgrade kit in stock, I'm not sure why it's not available anywhere else yet?? Maybe I can ask tomorrow.
Hot Bodies Pro 5
*Sponsors*
Old 09-22-2014, 05:17 AM   #1926
MUGEN_MAN_666's Avatar
Originally Posted by frk View Post
Sorry for the late response.
I said that now turning the wheels to the right and left steering I have symmetrical steering. Finally, both wheels turn 24 degree externally and internally max 17 degree max. The arm of the servo saver beats on the steering columns, and limiting these values. I am aware that even affects ackermann, but I wanted to get at least 26 degrees of steering maximum, like many other models ..
I think that removing thickness above the steeringarms and using a shorter arm (of the servo saver), I could have more maximum angle.
How thick you have over the steering arms ? And how long is the servo lever from hole to hole?
I use the HB alloy servo horn and space the ball joint 3mm out from the servo horn so the arm is straight and took a 2mm shim out from the steering crank. The turnbulkle will get close to the top deck but is clears ok. Like I said earlier I get 32degs each way.
Hot Bodies PRO5
Xray RX8
Sanwa MX11
MUGEN_MAN_666 is offline   Reply With Quote
Old 09-29-2014, 11:17 PM   #1927
Finally! two kits for 2 of my TCXX's
lots of cool changes. short shocks, towers shorter, lower deck is actually thicker than TCXX option chassis, and the motor mount is comparable to old tcx motor mount. Motor is raised higher and there is an extra mounting position. I have not tried it yet but it seems I can set pinion mesh without taking off the top deck.
Old 09-30-2014, 11:36 AM   #1928
Chrisgt2's Avatar
I was a bit shocked that the shocks are actually the same size. They just have shorter caps!!
Overall the the car with updates seems better and faster.
I'll be working on active rear tow next. I want to try what the XRay and Serpent have been toying with.
Basically running front arms/hubs/spindles in the back linked to the bulkhead.
Old 10-01-2014, 07:25 AM   #1929
If you will be able to reproduce the the xray and serpent ARS for our tcxx, please post a pic. That would be great! :-)
moraccio is offline   Reply With Quote
Old 10-01-2014, 05:33 PM   #1930
Chrisgt2's Avatar
Here's my first attempt, seems to work well. Looks like a good 1/2 degree of outward movement at least. More or less action depending on the chosen hole in the knuckle.
I tried to video it but can't really see the action.
I only did the Right side so far.
Hot Bodies Pro 5
*Sponsors*
Old 10-02-2014, 07:52 AM   #1931
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
are you running a 0* c-hub in the back? if not, won't the caster effect handling?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-02-2014, 07:56 AM   #1932
Chrisgt2's Avatar
I don't have any "0" C hubs so I put a L side "4" on for now. Not sure what the 4 degrees will really affect in the rear.
One issue I noticed is that the shock mount isn't as far out on the arm so you would need a softer spring. I normally run Yokomo Blue
Hot Bodies Pro 5
*Sponsors*
Old 10-02-2014, 10:53 AM   #1933
Chrisgt2's Avatar
Well... this just happened...
http://www.hpiracing.com/en/article/view/2014100201
Hot Bodies Pro 5
*Sponsors*
Old 10-02-2014, 10:54 AM   #1934
k_bojar's Avatar
yeah.. they could have at least included a smudged CAD drawing or something...
guess all the HPI/HB fans will be glued to the IFMAR Worlds pics next weekend
Old 10-02-2014, 12:01 PM   #1935
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
shaft or belt?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
