Like Tree2Likes
Old 09-13-2014, 01:41 AM   #1906
Originally Posted by frk View Post
Well
after the adjustment I have 24 and 17 degree. The delta between the steering angles sides it' few only 4/5 degrees!
FRK I've been reading your posts and I'm not clear on what your problem is. If you are saying that when you turn the wheels left and you get 24 degrees on the left wheel and you turn right and get 17 degrees on the right wheel that's a problem that is fixed with linkage adjustments, offsetting the center point of he servo, and/or EPA adjustments on the radio. However, if you turn left and get 24 degrees on the left wheel and turn right and get 17 degrees on the same wheel , that may just be the ackerman (turning the inside wheel more in a turn for the tighter turning radius) and is normal. To me anyway, it not clear which of these two situations you are talking about.
But in any case with full travel on the radio (on my radio that's 150 not 100), you should be getting full steering lock or there is something wrong; either something is binding and not preventing the wheels to move freely or perhaps a bad servo. Seems like I remember one screw in the chassis that if you used one that was too long it caused a problem with the steering, you might check that.
John Wallace2 is offline   Reply With Quote
Old 09-17-2014, 12:50 AM   #1907
frk
frk's Avatar
Sorry for the late response.
I said that now turning the wheels to the right and left steering I have symmetrical steering. Finally, both wheels turn 24 degree externally and internally max 17 degree max. The arm of the servo saver beats on the steering columns, and limiting these values. I am aware that even affects ackermann, but I wanted to get at least 26 degrees of steering maximum, like many other models ..
I think that removing thickness above the steeringarms and using a shorter arm (of the servo saver), I could have more maximum angle.
How thick you have over the steering arms ? And how long is the servo lever from hole to hole?
frk is offline   Reply With Quote
Old 09-17-2014, 12:56 AM   #1908
Trader Rating: 20 (100%+)
the linkage from servo horn to steering bell crank. I measured the gap between ball cups 11.5 mm. I have 27 degrees left and right on the setup station.
goots is offline   Reply With Quote
Old 09-17-2014, 07:04 AM   #1909
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Using a shorter servo saver would limit overall travel.
I just set my limits in the radio, do some circles, adjust till even and run it.
I think you're overthinking things a little.
Chrisgt2 is offline   Reply With Quote
Old 09-17-2014, 03:29 PM   #1910
Send a message via AIM to racer034life
How does the tcxx compare to some of the newer cars?
Access Hobbies,CRC, Detc410, Xray T4 15,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 09-18-2014, 07:09 AM   #1911
Chrisgt2's Avatar
Personally I think the TCXX was ahead of its time and with the update kit it's just as capable as anything out there. I have no problem keeping up.
Any deficiencies in my lap times I wouldn't blame on the car
I also run an aluminum chassis plate which seemed to really help out.
Old 09-18-2014, 09:31 AM   #1912
Will I can't find a used one anywhere anyone selling one. Also where can you buy the updated parts at?
Old 09-18-2014, 09:35 AM   #1913
+1 I was able to get my tcxx better than my ARC last saturday at TQ raceway. I don't have the upgrade kit on my TCXX. Actually my tcxx with 17.5 kept up in the infield with my friend's ARC with a 13.5
www.ActivRc.com ARC
fx35rc is offline   Reply With Quote
Old 09-18-2014, 06:31 PM   #1914
Chrisgt2's Avatar
Damn good car.
Few used ones available, I bought all 3 I've seen listed in the past year. The update kit could be ordered I believe.
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Old 09-18-2014, 10:46 PM   #1915
I want to try one out at my local track but can't find one used nor can I find the update kit for sale anywhere!
Old 09-19-2014, 05:17 AM   #1916
Trader Rating: 25 (100%+)
Rc-market have the upgrade kit in stock, and on special.
Still around $330 though!!
Gtr r34 m-spec is offline   Reply With Quote
Old 09-19-2014, 09:00 AM   #1917
Yea right 350.00 for any updated parts on top of trying to find a used chassis. That's crazy to me! Your 200.00 bucks away from a A700 or even a new xray,yokomo!
Old 09-19-2014, 09:07 AM   #1918
Chrisgt2's Avatar
I do agree it's pretty expensive for the update kit. Really, all of the high dollar parts are included in the update.
New chasssis, motor mount, shocks and towers, dcj's, floating servo mount.
I could have chosen many other cars, but I like the purple, and have always been a HPI/HB fan.
Plus I like to be different.
Hot Bodies Pro 5
*Sponsors*
Old 09-19-2014, 11:17 AM   #1919
SpidarX's Avatar
HPI should have just come out with a new kit. I don't see many people buying a TCXX knowing that they would then have to put 300 into it for the upgrades to have a current car. The upgrade kit would only appeal to previous owners of the TCXX. New drivers are not going to come onboard.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 09-20-2014, 12:49 AM   #1920
Well if its any hope. I'll have my tcxx for sale after iic. If anyone can wait that long ��
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
