Old 08-07-2014, 12:51 PM   #1846
Thanks for the answer. But:
- "wasting a lot of money on brand new parts" as you call it is of course mine to decide
- I've had second hand cars, long ago. Never again
- please be more specific as to the upgrade kit. Money is no issue here. My worries are the quality of the kit. Because I hear and read about wrong parts, wrong colour and so on. Please elaborate
- as to the spur gears: that question wasn't answered. Could you please do so
- as to the servo: that question also wasn't answered. Could you please do so
And yes, I also like the HB colour more than the XRay colour. But that isn't a dealbreaker, imho.
I also don't like the fact that at the end of a year you have a "dated" car. But one could say:"I don't give a rats ass... ;-)"
Nick Heldens is offline   Reply With Quote
Old 08-07-2014, 01:25 PM   #1847
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
yes, the TCXX comes with a panaracer spur - but any spur will fit the chassis.
as to which is better, that's more of a personal preference IMO
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-07-2014, 04:03 PM   #1848
theclutch's Avatar
I LOVE no budget issues! Having read that, if Xray was purple, then I'd be driving the Xray... But since I like purple, then HB it was for me!
I wouldn't worry so much about the upgrade kit having "wrong parts". I believe it was just a "wrong description" regarding the shock shafts. I didn't read anything about a wrong color.
For spur gears, I disagree that you can just "use anything". Depending on the motor mount that you use (I believe there are 3), setting the pinion mesh would be harder if you use the original TCX (not TCXX) motor mount. You would use the original TCX motor mount since it brings the motor closest to the center line of the car. Thus, for spurs, I would use the HB spurs which have holes cut out that would allow easier access to the motor screws. Having said that, I use various ones since I typically set the motor and pinion down once and leave it at that setting (I typically run 17.5 only). So it isn't too much of a bother for me unless I run modified where I would have to keep trying out various pinion ratios.
For servos, I would use the fastest SAVOX servos available.
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 08-07-2014, 04:18 PM   #1849
k_bojar's Avatar
I've made my statement because I've used kimborough, panaracer, leespeed, RW, 3Racing, and a xenon - all worked without issue.
then again, I'm using the TCX motor mount - but I've never had an issue setting the mesh, unless I'm using a super big pinion. are some easier to use then others, sure - but in terms of fitting, I've never had issues with all the brands I've listed above
I normally run USVTA or 17.5 with the car - so I typically have a smaller spur and larger pinion
Old 08-07-2014, 07:28 PM   #1850
ShaunMac's Avatar
To you that are racing a HB car. Do you have many others at your track running HB as well? Or do you find yourself alone in a sea of Xray, AE, Tamiya, Yokomo and others? I haven't seen another HB car in GA, TN or AL in many years. I've been rollin' Han's style a long time. SOLO!
My last race at ThunderRC in Nashville was a complete XRAY-fest! lol
ShaunMac is offline   Reply With Quote
Old 08-07-2014, 07:53 PM   #1851
k_bojar's Avatar
same where I am there's one other TCXX in the area, but he usually uses his xray over the HB chassis
if you're going to be at the southern nats, there'll be at least 1 more TCXX there - mine
Old 08-07-2014, 10:17 PM   #1852
tc3 racer sc's Avatar
may be 1 more
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 08-08-2014, 12:49 AM   #1853
Trader Rating: 20 (100%+)
same thing with me. I have an old timer as a team mate because I can help him with his car. I think running solo helps you fine tune and understand the car much more, since you are the one trying all the setup changes. Rather than a bunch of racers just telling you what to change.
I still think all high end cars are the same speed, just different handling characteristics.
goots is offline   Reply With Quote
Old 08-08-2014, 03:27 AM   #1854
Same here, not many people run the TCXX but I love it. I think it is definitely true regarding tuning setups as you try something and see what effect it has rather than always copying someone else's setup.
I've only ever used HB spurs and I always use the TCX mount as I feel the handling is sharper and more consistant. I believe the panaracer spurs or the Xenon VSS spurs would have the necessary cut outs to make meshing easier.
I use the Savox SC-1251MG Low Profile servo which is very good and a great price:
Dimensions: 40.8 x 20.2 x 25.4mm
Weight: 44.5g
Speed (sec/60): @4.8v 0.1, @6.0v 0.09
Torque (kg-cm): @4.8v 7, @6.0v 9
Gear: Metal
Case: Aluminium Heat Sink
I upgraded to CSO low profile shock towers, Tamiya DCJ's, Roche Floating servo mount and T-Shox short shocks. The TCXX official upgrade kit looks very expensive and I got bored of waiting
In this guise it is the best handling touring car I've driven to date. Very stable, rotates well and I find it easier to place where I want it on the track.
dvaid852456 is offline   Reply With Quote
Old 08-09-2014, 10:51 PM   #1855
Weight: 44.5g
Gear: Metal
I upgraded to CSO low profile shock towers, Tamita DCJ's, Roche Floating servo mount and T-Shox short shocks. The TCXX official upgrade kit looks very expensive and I got bored of waiting
my cso front tower is a defect it off centered i may get another on i want to install my new shocks
Old 08-09-2014, 11:20 PM   #1856
Which short shocks are you using
Old 08-10-2014, 07:15 AM   #1857
Airwave's Avatar
RW spurs are definitely the best for me, but they are quite hard to find in 116T in my area.
I'm using KO RSX10, fast, solid, reliable. I'm also using OMG servos, which are a little bit heavier but faster than everything else...
Airwave is offline   Reply With Quote
Old 08-10-2014, 02:53 PM   #1858
ShaunMac's Avatar
Not many racers left running HB cars anywhere these days it seems. I've had good luck with my Cyclone, TCX and TCXX cars over the years. Some parts availability issues at times, but I feel no need to switch to anything else. The A-Matix is the only car that has peaked my interest for it's performance. Those car's really do behave differently than the current crop of belt cars. And for 17.5-type classes on smaller high-bite tracks they are an advantage in the right hands. Corner-speed and RIP out of the hole are turned to 11 on this car! lol
Wish I could make the S.Nats race in September. The TC class has some real talent signed up already. But even the club races at Thunder are stacked. There were 4 heats of 17.5 alone yesterday. Plus VTA, USGT and 12th scale. 50 or so entries. Good times.
Good luck at the Nats. If I'm able to make this race somehow I'll be sure to stop by and introduce myself.
Old 08-10-2014, 08:56 PM   #1859
cso shocks the front tower is not right it off centered
Old 08-10-2014, 09:10 PM   #1860
Default measuring droop with shocks or without
i have seen folks measure droop with shocks and sway bars attached and some not attached, which one the best way and also i know yall notice the tcxx book never gave a droop measurement on arms i just cant get my tcxx planted enuff i want to feel it when im driving and right now i dont
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
