Old 06-04-2014, 10:01 AM   #1771
Trader Rating: 17 (100%+)
Originally Posted by goots View Post
So now that its out. Where can I get it?
Last I heard it was supposed to be out April/May. It has been promised for quite a while and still, no upgrade pack...
What's the deal HB?
*still waiting*
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 06-06-2014, 08:56 AM   #1772
In UK shop HPI/HB in stock:
http://www.hpiracing.co.uk/piw.php?partNo=112285
gt10r5 is offline   Reply With Quote
Old 06-07-2014, 03:24 AM   #1773
Trader Rating: 20 (100%+)
Originally Posted by gt10r5 View Post
stock status is, "still waiting for shipment"
where can we get the upgrade when it is available in the US?
goots is offline   Reply With Quote
Old 06-08-2014, 02:44 PM   #1774
tc3 racer sc's Avatar
Default setting droop the righ way on the tcxx
there are so many ways to set droop but cn some one give or show correct way of setting droop on the tcxx i see some do it by ride height some do it on blocks some do it with chassis on set up board and measure to pin can some one show how to do it with on the setup board
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 06-08-2014, 03:15 PM   #1775
Ive been using the blocks for years, but the easiest way I do it now.
1. Set your ride height first, chassis is race ready.
2. Take off your wheels and lay it flat on your setup board.
3. Take a small ruler and measure from the setup board to the center of the hinge pin.
Put your wheels back on and check how many mm does the chassis lift. Depending on the surface you race on up travel is usually 1-3mm.
So when you are looking at the setup sheets for example if the front says 9mm, they are measuring from the setup board to the center of the hinge pin.
Remember if you change your ride height to another setting afterwards your droop settings need to change also.
Old 06-09-2014, 08:38 AM   #1776
Hey Goots,
I used the carpet set up you gave me and the tcxx handles really good. Thanks Brotha.
fx35rc is offline   Reply With Quote
Old 06-09-2014, 03:33 PM   #1777
Originally Posted by fx35rc View Post
Hey Goots,
Nice. Did you follow it exactly? Or as much as you could
Old 06-09-2014, 04:28 PM   #1778
Follow it exactly and adjust a little bit to get more rear bite to suit my driving style
Old 06-10-2014, 09:01 AM   #1779
EvaldasD's Avatar
Hello,
Have anyone noticed that "#68833 - GEAR DIFFERENTIAL SET 39T" isn't available any more. No more diffs for TCXX?!
Hot Bodies - HPI - LRP - Sanwa
EvaldasD is offline   Reply With Quote
Old 06-10-2014, 11:10 AM   #1780
Just bought a couple the other day online.
Old 06-10-2014, 11:10 AM   #1781
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
and amain hobbies had them as well, last I looked
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-13-2014, 05:11 PM   #1782
stinky cheese's Avatar
Trader Rating: 21 (100%+)
OK. Had my first run of my new TCXX. Had some initial problems. I was running V1 dcj's and one broke. I see the new V2's are rebuildable. I asked around the pits to see what other brands dcj would fit but I could not seem to find any. The TCXX shaft [part that goes through bearings and knuckle] seemed to be longer. May I ask what other brands fit until the arrival of the the upgrade kit. Thanks
Cheese
My racing is supported by the following companies
AKA Tires. http://www.ryperhobbies.com.au/
TKO Competition Development. http://premiermodelsupplies.com/
Tornado RC Chargers
Schelle Racing Innovations.
stinky cheese is offline   Reply With Quote
Old 06-13-2014, 05:43 PM   #1783
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Tamiya fits
Chrisgt2 is offline   Reply With Quote
Old 06-13-2014, 06:20 PM   #1784
Originally Posted by Chrisgt2 View Post
Tamiya fits
I got a pair of Tamiya ones off my mate and measured the length and the pin hole that holds the hex on was different length compared to the V1 TCXX ones. The Tamiya one being shorter in length.
Tornado RC Chargers
Old 06-13-2014, 06:41 PM   #1785
ShaunMac's Avatar
You have to run a different bearing. TCXX uses two 5x10x4 bearings. You need to change the inner bearing to a 5x10x3 for the Tamiyas to fit.
ShaunMac is offline   Reply With Quote
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
