Old 04-02-2014, 11:49 AM   #1636
Very kind!
Originally Posted by Chrisgt2 View Post
You can make a center post by cutting one of the "H" style spur gear bearing supports. (Opposite of motor mount)
moraccio is offline   Reply With Quote
Old 04-03-2014, 05:11 AM   #1637
With the stock TCXX chassis I found running a centre post with no screws in the lay shaft holders to be very unpredictable.
I much preferred the normal configuration with 2 screws removed at the rear. It may be better with the stiffer aluminium chassis as I haven't tried this.
Is the aluminium chassis only good for carpet racing?
dvaid852456 is offline   Reply With Quote
Old 04-03-2014, 06:28 AM   #1638
SuperFastSnail's Avatar
Trader Rating: 77 (100%+)
ChrisGT2,
How can we obtain one of these aluminum chassis? I used my TCXX for a few VTA races but ended up adding over 12 oz of lead weight to make it legal weight. Maybe the aluminum chassis is the answer.
JU KE
Sponsor by Makita Li-Ion Brushless Power Tools. Eat the power!
Selling something but no pictures, goodbye.
SuperFastSnail is offline   Reply With Quote
Old 04-03-2014, 06:54 AM   #1639
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by SuperFastSnail View Post
ChrisGT2,
I believe rcmarket and arrowmax's websites have them
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-05-2014, 02:23 AM   #1640
Hi,
Here a picture of Andy's car at the Fai Ho hobbywing cup 2013:
We can see he used a Xray(?) diff at the rear, what the interest of that?
Beside he is still using TCX steering arms. Does he use it with a TCX or a TCXX chassis? What the interest of this?
I hope we could have pictures of his car during the world warm-up.
CoCoLapin is offline   Reply With Quote
Old 04-05-2014, 02:32 AM   #1641
Originally Posted by CoCoLapin View Post
Hi,
I asked the HPI team the very same question about TCX steering arms. I asked Stefan (he contributes on here), he told me it makes the car easier to drive. As I had a TCX I broke for spares, I used the steering arms on my TCXX. He was right!
Xfactory UK Team Driver
VBC Wildfire D06 13.5 tarmac boosted & 17.5 carpet blinky
Vampire- Exotek- Lunsford- RDRP- Team SR- Hiro Seiko
TC Travis is offline   Reply With Quote
Old 04-05-2014, 04:14 AM   #1642
k_bojar's Avatar
Hi,
can't see the image
Old 04-05-2014, 11:32 AM   #1643
An other one from Andy at the pre-world, look at the diff:
Beside he is using PRO4 rear arm..
Old 04-05-2014, 07:14 PM   #1644
k_bojar's Avatar
how many spacers are you using with the TCX arms?? 6mm?
Old 04-05-2014, 07:18 PM   #1645
Trader Rating: 25 (100%+)
Have you got any more pictures? Please post.
Gtr r34 m-spec is offline   Reply With Quote
Old 04-06-2014, 03:31 AM   #1646
Nuno Gancho's Avatar
Where may we by the pro4 arms, thanks.
Is he still using the same pully at forint spool and on the rear the X-ray diff
Nuno Gancho is offline   Reply With Quote
Old 04-06-2014, 05:27 AM   #1647
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
First day out with the aluminum chassis was great! Car was fast and I was able to drive it hard into the corners. Very predictable, and consistent.
Only real changes I made from my carbon setup was leaning the shocks in 1 hole, but I also ran at a different track than normal.
Also, I run a floating servo mount, so I cut the extra mounting tab off. It was dragging in the high speed sweeper and causing the car to be unstable. After that, it was perfect.
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 04-06-2014, 06:26 AM   #1648
theproffesor's Avatar
Trader Rating: 55 (100%+)
Amain has the pro 4 arms. They only have 2 mounting holes. You can get them in carbon or regular plastic that is more durable but not as stiff. I ran them on all my HB cars when I still had them. They wrere easier to get than the tcx/tcxx arms. They have the same geometry as the pro4 as do the hubs and knuckles, so why not run them?
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 04-06-2014, 05:03 PM   #1649
Can't find them at Amain do you have the part number. So did you feel any difference using them. Thanks.
Old 04-06-2014, 06:34 PM   #1650
Hpi73506
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
