Old 03-28-2014, 02:15 PM   #1621
AGNO's Avatar
Originally Posted by Airwave View Post
where is your center axle support coming from (on the carbon car)?
Is an modified Jet motor support
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-28-2014, 03:29 PM   #1622
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Here's my new Arrowmax aluminum chassis. Just arrived today.
Weighs in about 50g more than the stock chassis pictured and roughly twice as stiff.
I will weigh the stock non cut-out chassis plate when I remove it from the car.
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 03-29-2014, 06:07 AM   #1623
Chrisgt2's Avatar
Here's a few pics after install. The non cut-out chassis was about 68g, cut-out was 64g, the aluminum was around 110g.... Can't remember exact number now.
So it added about 50g to the car. Not thrilled with that, but it's low weight.
Hot Bodies Pro 5
*Sponsors*
Old 03-29-2014, 07:20 AM   #1624
tc3 racer sc's Avatar
tell me it perform any different did u use the arrow max shock tower
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 03-29-2014, 07:24 AM   #1625
Chrisgt2's Avatar
It'll be a few weeks till I can test I think. This car has the stock towers on it, my other car is running the lowered cso shocks and towers.
Both have been performing equally well.
My cars have been dialed. No complaints.
Hot Bodies Pro 5
*Sponsors*
Old 03-30-2014, 10:22 PM   #1626
SuperFastSnail's Avatar
Trader Rating: 76 (100%+)
Default TCXX Updates from HotBodies
Thanks KenTech for sharing this with us:
http://kentech.blogs.se
JU KE
Sponsor by Makita Li-Ion Brushless Power Tools. Eat the power!
Selling something but no pictures, goodbye.
SuperFastSnail is offline   Reply With Quote
Old 03-31-2014, 01:48 AM   #1627
Airwave's Avatar
I know that these shocks are shorter than the original ones, but will they need short springs to work properly?
Airwave is offline   Reply With Quote
Old 03-31-2014, 09:50 AM   #1628
theclutch's Avatar
Can someone comment on the new motor mount? I know 2 motor mounts for the TCXX so far: the original TCX, the new one which allows easier access to the screws (but moves the motor away from the centerline compared to the original TCX mount). So what does the new motor mount do? Any part numbers?
Also, those "V2 DCJ's... what's new about them?
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 03-31-2014, 09:55 AM   #1629
Most of shock springs (regular size springs, short springs) will with those shorter shocks.
Hi-LowBlow is offline   Reply With Quote
Old 03-31-2014, 01:43 PM   #1630
Hi,
Where can I find the same upper deck i see in the pictures? It seems you are already able to put the center screw without the 4 screws in the rear part
Thank you.
moraccio is offline   Reply With Quote
Old 03-31-2014, 04:43 PM   #1631
Chrisgt2's Avatar
Moraccio, it is a standard top deck with a center post. There is a hole in the lower chassis that lines up perfectly.
Hot Bodies Pro 5
*Sponsors*
Old 03-31-2014, 08:07 PM   #1632
Trader Rating: 20 (100%+)
nice! finally we see the upgrade kit. time to save up my pennies. Any official release date?
goots is offline   Reply With Quote
Old 04-01-2014, 04:01 AM   #1633
Hey,
The new motor mount is similar to the original TCX mount except that it is raised by 2mm and is compatible with the new chassis and the old chassis.The new DCJ's are now using the thin bearings in the steering knuckles and it is now rebuildable so that it will be more durable.
JJ
JJwang is offline   Reply With Quote
Old 04-01-2014, 12:01 PM   #1634
Ok Chrisgt2,
thank you so much for the explanation.
Ciao
Old 04-02-2014, 07:22 AM   #1635
Chrisgt2's Avatar
Originally Posted by moraccio View Post
Ok Chrisgt2,
Ciao
You can make a center post by cutting one of the "H" style spur gear bearing supports. (Opposite of motor mount)
Hot Bodies Pro 5
*Sponsors*
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
