Hot Bodies TCXX
#1561
Just adding to this motor mount thought: For those who are running TCXX's, who has gone to the "old style" TCX motor mount?
I was considering going to the TCXX motor mount since it would be easier to swap spur gears and move the motor around for proper gear mesh. With the old style TCX motor mount, it's pretty hard to change pinion or spur gears due to the location of the screws.
#1562
The TCXX is almost 2 years old...is there a new car coming that incorporates the many changes/ updates to it since it was introduce back in August 2012?
Or is there an updated TCXX kit with those changes in it?
#1563
There is an update kit that was announced, coming in a few months.
http://www.rcnews.net/2014/01/29/hot...nal-parts-set/
#1564
#1566
Just wondering. How many other drivers did you notice running Hot Bodies at the Snowbirds?
#1567
There may have only been 3 of us, maybe 4.
I finished 3rd in the A in Amateur 17.5 TC, 2nd in the C in 17.5 TC
Car was fast enough to TQ and win Amateur with the run I had in 17.5 TC, I was sitting in the B in TC till the 4th round. Car was also good enough for the A in that class.
My nerves held me back, I just came back racing a few months ago after a 7 year break. I get crazy nervous and need to chill!!
#1568
Anyone know where I can purchase the sway bar holder below?
#1569
You can buy them from jet racing website.
I prefer the standard ones though. They have a bit of slop in them.
#1573
I know in our case it's not nearly as dramatic.
#1574
I think I figured out that you can use the Cyclone TC single crank system in the TCX. I can't find info on exactly which parts you use from the 7508(pro4 servo saver set), but i have bits of it here and have ordered 2 more for my two tcxs, along with 75143s and 61321s. I think I'll be able to use bearings I have and I think the servo and remain where it's supposed to be! Any info on those things would be very awesome and gratefully received!!!
I measured it all up and just seems the ackerman will revert to that of a TC, so I just hope that feels ok as it felt fantastic with the original rack.
I will look at Ebay, I know I was looking before and the only ones I could see had buy it now prices of well over $120, thanks Chris, I will for sure check it out.
#1575
Hello,
Where can we found team drivers setup?
I just found 2/3. I'd like to found the TITC 2014 if it's possible.
Thanks.
Thanks.
