Old 02-09-2014, 06:58 AM   #1546
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Idk, I rarely break anything on my tcxx's, even during the time I was using aluminum knuckles because they came on one of the cars I purchased.
There is a complete rack on eBay right now for $75, you could also contact HPI, they may help you out.
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 02-09-2014, 01:00 PM   #1547
I think I figured out that you can use the Cyclone TC single crank system in the TCX. I can't find info on exactly which parts you use from the 7508(pro4 servo saver set), but i have bits of it here and have ordered 2 more for my two tcxs, along with 75143s and 61321s. I think I'll be able to use bearings I have and I think the servo and remain where it's supposed to be! Any info on those things would be very awesome and gratefully received!!!
I measured it all up and just seems the ackerman will revert to that of a TC, so I just hope that feels ok as it felt fantastic with the original rack.
I will look at Ebay, I know I was looking before and the only ones I could see had buy it now prices of well over $120, thanks Chris, I will for sure check it out.
stubaxle is offline   Reply With Quote
Old 02-10-2014, 01:01 AM   #1548
Hey guys,
I attended the Snowbirds 2014 and I have to say, it is a crazy but super fun race. I have learned a lot throughout this race and I have tried many different setups on my car. The tires this time was a bit harder than usual so it was difficult to get the grip we wanted. The track conditions kept on changing everyday so that also made it hard for me to find the ideal setup I wanted. However, I am very happy with the cars performance throughout the weekend and I have attached the setup that I used at the snowbirds.
Thanks,
JJ Wang
JJwang is offline   Reply With Quote
Old 02-10-2014, 05:04 PM   #1549
Can anyone tell me if the Tamiya 416/417 "Steering Bridge" fits directly on a TCX?
I see there are carbon fibre braces which fit both so it suggests to me that the geometry must be very similar...Also are the bearings in it the same size?
Old 02-11-2014, 03:49 AM   #1550
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
are there any available chassis (stock or aftermarket) that doesn't need to have another hole drilled for a floating servo mount?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-11-2014, 03:53 AM   #1551
Chrisgt2's Avatar
I'm using the floating mount from eBay, $13.99 and works great. No drilling required
Hot Bodies Pro 5
*Sponsors*
Old 02-11-2014, 04:08 AM   #1552
k_bojar's Avatar
with which chassis?
Old 02-11-2014, 04:13 AM   #1553
Chrisgt2's Avatar
Stock
Hot Bodies Pro 5
*Sponsors*
Old 02-11-2014, 04:21 AM   #1554
k_bojar's Avatar
Stock
really?? I can't see where the 2nd screw on the mount attaches
and this mount - http://cgi.ebay.com/ws/eBayISAPI.dll...m=151225773682
any chance you can take a pic of the bottom on your chassis?? granted, I'm trying to use this on a TCX, which is why I asked about which tcxx chassis works. but looking at the pics of the tcxx chassis in the manual, I can't see where the 2nd screw on the mount attaches
and this would be the 2nd screw on the side the attaches to the chassis
Old 02-11-2014, 04:30 AM   #1555
Chrisgt2's Avatar
The 2 screws directly behind the center steering rack hole
Hot Bodies Pro 5
*Sponsors*
Old 02-11-2014, 04:36 AM   #1556
k_bojar's Avatar
thanks. I guess that's what I get for looking at the manual trying to figure it out...that hole isn't included on the manual's drawings
Old 02-11-2014, 07:30 AM   #1557
Chrisgt2's Avatar
The new option parts may work for you when they release. Pretty sure the new HB floating mount uses a wider bolt pattern.
Hot Bodies Pro 5
*Sponsors*
Old 02-11-2014, 08:13 AM   #1558
ShaunMac's Avatar
My original TCX chassis doesn't have that hole drilled.
ArrowmaxRC has a couple chassis options that are drilled for the use of their floating servo mount. I'm still using standard mounts. I did put a small 0.5mm spacer under each mount to help the chassis flex more around the servo. You can see the chassis flexing under the servo as you twist it in hand.
ShaunMac is offline   Reply With Quote
Old 02-11-2014, 04:29 PM   #1559
k_bojar's Avatar
that's my issue.. i'm trying to use a floating mount made for the tcxx, so I guess i'll need to drill a whole to mount it, or buy a new chassis
Old 02-13-2014, 09:24 AM   #1560
Nipple's Avatar
I understand using the TCX motor mount which move the motor inwards makes the car roll faster.
But is it okay for low traction situtations?
Or making the car roll faster is better for any conditions, low or high traction.
Please advise, many thanks.
Nipple is offline   Reply With Quote
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
