Hpi pro 4 brushless setup....
#16
Re: .......
Originally posted by TooLy
With which pack you use?
How much run time do you have?
Where I can find some details about this motor?
Thanks.
Thanks.
here you can find dimensions for basicxl
http://www.lehner-motoren.de/msbasic-xl_mas.php
i just took a look on my novak, novak is even longe with that plastic back on the motor.
this is the esc i will use...
http://www.schulze-elektronik-gmbh.de/ufo-e.htm
almost same size as novak
#17
it's the same as novak, so should be no big deal
My Setup:
Schulze U-Force75
Plettenberg Shadow
72/23 * 2.5 gearing on new tires (not sure what the diameter is)
Hurricane 1.165-1.169 packs
I get about 6.5 minutes of runtime on carpet
Here is the German page for the Shadow
http://www.plettenberg-motoren.com/Daten/HP220car.htm
#18
i was talking about the size of the motor not the power...
by the way, it's good thing that you explained all the stuff
