Like Tree19Likes
Old 01-05-2017, 11:29 PM   #1081
MontanaMaxx's Avatar
Are they running the new team scream 17.5 on 2s? Its crazy fast on 1s on 2s would be like running a mod I would guess
MontanaMaxx is offline   Reply With Quote
Old 01-05-2017, 11:38 PM   #1082
some87's Avatar
Trader Rating: 16 (100%+)
Btw thank you for the info Edward I really appreciate all the work you do on YouTube and the help you provide on here. I would still be lost on what to do with my car if it wasn't for you.
some87 is offline   Reply With Quote
Old 01-05-2017, 11:44 PM   #1083
some87's Avatar
It's all club racing so nobody is setting timing on their motors for max power. Although I did just pick up a super cheap motor so I could get a motor analyzer for everyone at the track.
Old 01-07-2017, 12:31 AM   #1084
EDWARD2003's Avatar
You're quite welcome! I'll admit 1/12th scale was steep learning curving for me. I came from an all touring car racing background. One thing I did learn over the years is TC and 1/12th scale setup theory are not the same, not one bit.
Persistence and patience is key for 1/12th scale and always ask questions. I've been racing 1/12th for 3 years and I've learned and continue to learn something new each day I'm at the track.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 01-13-2017, 05:08 PM   #1085
Damn 2s 17.5. What roll out are you guys using
Felix v.
Ae sc10.2, xray t4 2016 usgt,wrc f-one 016, Tamiya m05 mini
Expensive is not always faster
Scionara05 is offline   Reply With Quote
Old 01-16-2017, 08:42 PM   #1086
AZ Wolfie's Avatar
I experimented with that setup a while ago at roughly 50mm, and the motor came off the track quite cool. Would have gone higher, but went boosted instead. Was running an old Reedy Mach 1.
Since then tried 2s 13.5 boosted for a bit, but wanted more punch. I settled on 2s 8.5t boosted and love it.
AZ Wolfie is offline   Reply With Quote
Old 01-17-2017, 05:32 PM   #1087
Do they make the ballstuds that are used in the spindles in a longer length?
Bubonic-X is offline   Reply With Quote
Old 01-23-2017, 04:20 PM   #1088
gee-dub's Avatar
Chassis balance question.
I will preface this by saying the car has about an hours runtime on it. I just recently went back thru everything to ensure there is no binding and change the ESC wiring. Even with the ESC/receiver out and only the steering servo, motor and transverse battery installed, I find the below to be the case.
With the tweak mounts backed-all the way off, the right-rear seems to carry quite a bit more weight than the left-rear. To the point of a 230/175 split (approximately). While the point of the tweak adjustment is to get equal balance, this seems to be a bit far off, at least from a 1/12 noobies assumption, for a neutral setting given the off-set pod and whatnot.
Does the above sound about right or should I be looking at fixing something (what)?
Thanks in advance.
Last edited by gee-dub; 01-23-2017 at 04:55 PM. Reason: spelling and grammar are hard ;)
gee-dub is offline   Reply With Quote
Old 01-23-2017, 04:42 PM   #1089
azeroth's Avatar
Trader Rating: 20 (100%+)
most will balance the chassis when in 2 pieces the main chassis is the most important part for handling purposes due to the light springs up front some will balance the rear pod as well with motor spacers ect. but it no where near as important as the main chassis because the pod being non suspended it will not add any tweak the running chassis on trued tires of equal size
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 01-24-2017, 09:48 PM   #1090
some87's Avatar
I'm not sure. I haven't finished building my car yet but the last of my parts are going to be here tomorrow. From what I know most of the guys are only running about 70% throttle. I'm not sure why they didn't just use a 21.5 which would have been better on our small track. I'm not even sure what gearing I need to run.
Old 02-08-2017, 06:39 PM   #1091
Error
Old 02-08-2017, 07:22 PM   #1092
http://
I modded my shock using a Silva shock. Removing all the lipo Standoffs in front and modifying the long shock CF mount. And mounted it to the chassis. I drilled out the top of an old shock and screwed the shock into it keeping the ball mount. Then just cut a ball cup to fit on the back ball.
I have adjustability for different tracks for droop and ride height. What you think?
Old 02-08-2017, 07:36 PM   #1093
Originally Posted by Bubonic-X View Post
http://
That looks good, I want to do something like that, but I am in a point series, and have no time for test and tune, for a modification like that.
Plus my car is running the best it has ever ran.
eazy70 is offline   Reply With Quote
Old 02-08-2017, 07:43 PM   #1094
EDWARD2003's Avatar
Highly suggest the shock modifications for the 12R5.2.
https://www.youtube.com/watch?v=I1IOctQ_CSk
                 VBC 12M - D08 - FX
Old 02-09-2017, 08:06 AM   #1095
jetnjme's Avatar
very nice Edward.
question - Where are we able to get the team bomber front aluminum caster blocks. I not fluent on the team bomber web site
Northern California Pan Car Revival
jetnjme is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
