Old 09-26-2012, 05:30 PM   #91
Originally Posted by I.T.Guy View Post
Put it on AFTER you screw the set screw into the brace. The idea is; the retainer will spin super easy WITHOUT the threadlock, I honestly didn't even notice the picture to add it, I just did since it moved so easy. Also don't put a lot on, a little is all you need to "gum up" the threads a bit.
Thanks ITG. Makes sense. The retainer is meant to be adjustable so the set screw must be anchored. Got it!
DEACON is offline   Reply With Quote
Old 09-30-2012, 04:38 PM   #92
So I'm in the process of building my kit. I have read that 2 hours is the usual build time. It will probably take me at least twice that amount of time as I like to polish the hinge pins, pivot balls and ball studs to make sure everything moves freely. I also like to clean the bearings before installing them.
So far, I'm finding the build process relatively easy compared to a TC. I really like the cool shock design.
I have to admit that Part Bag numbering and identifying the correct screw size a bit challenging. The bags are labeled A-AA and B-BB but those letters don't seem to match up with the labels on the bags. I have one bag of screws with a label with numbers and letters that doesn't appear in the manual at all???
The other thing is the screws. They have what feels like a powder coated finish. I have built quite a few kits but I don't recall seeing screws like this before.
Overall, I'm enjoying building this kit and look forward to it's completion.
Old 10-08-2012, 04:37 PM   #93
bhambrent's Avatar
This will be my 1st. 1/12th scale car, what 64p spur should I get for 13.5 non boost track is 73x 42?
Any info on set-up and tires would be great.
Thanks guys,
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 10-08-2012, 04:43 PM   #94
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thanks guys,
I run a 78t spur, with pinions from 45 to 55, rollout from high 80's to low 90's
On that size track low to mid 80's should be more than enough
Some of the guys at IIC were rolling out in the mid 70's, so there really is a difference from motor to motor brand
Gearing will depend on motor, timing, and tire size
You can print a roll out chart at gearchart.com
Kit setup is a great base
Black Front, Yellow rear tires are very neutral to start with
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-08-2012, 07:04 PM   #95
bhambrent's Avatar
Thanks redbull,
One more thing,what rotors are you running in 12th 12.3 or 12.5.
Old 10-08-2012, 11:13 PM   #96
Thanks redbull,
I've run the supplied rotor with Thunder Power & Reedy Sonic
Old 10-11-2012, 05:54 PM   #97
Correct me if I'm wrong, so as I understand it the only thing they changed for the front end is how the lower arm mounts to the bulkhead. What did they change on the lower arm itself?
shaggy1 is offline   Reply With Quote
Old 10-11-2012, 06:04 PM   #98
The 5.2 lower arm does not use an insert, so it is a different piece with a 3mm hole for the screw
Old 10-11-2012, 06:30 PM   #99
So nothing in the geometry has changed, so it's not necessary to upgrade these pieces when converting from a 5.1 to 5.2.
Old 10-11-2012, 10:29 PM   #100
Yes
I believe the updates were made to improve durability
Old 10-11-2012, 11:11 PM   #101
EricF's Avatar
Originally Posted by RedBullFiXX View Post
Yes
Maybe ease of use (track width adjustment) also?
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 10-12-2012, 12:22 AM   #102
jsamarin's Avatar
Hey guys
what springs are recommended to have for 17.5 boosted on medium to high traction carpet?
front:
.014
.016
.018
.022
.024
side:
3.75 (black)
4.38 (green)
5.00 (silver)
6.25 (gold)
center:
4.0 soft (black)
6.0 hard (green)
Thanks for the help!
Justin Samarin
-4pk-
-TLR SCTE 2.0 - B4.1 W.C. - 12R5.2 -
"Cheap Fast Reliable. Pick Two"
jsamarin is offline   Reply With Quote
Old 10-12-2012, 05:31 AM   #103
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by jsamarin View Post
Hey guys
front:
.014
.016
.018
.022
.024
side:
3.75 (black)
4.38 (green)
5.00 (silver)
6.25 (gold)
center:
4.0 soft (black)
6.0 hard (green)
Run the Howart set up from the site.... seems to be working in all the classes..
.20 front, Black side and Blue center and 20k in the tubes....
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 10-12-2012, 01:03 PM   #104
bhambrent's Avatar
Would like to see the iic set-ups in 13.5.
Old 10-12-2012, 05:56 PM   #105
jsamarin's Avatar
okay, thats good to know about the howart setup....but i should rephrase my question. "what springs are good to have in your box for tuning".......if there is such a thing
Justin Samarin
-4pk-
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 10:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
SEO by vBSEO 3.5.0
