Like Tree19Likes
Old 11-19-2016, 10:10 AM   #991
Looking at Hebert's worlds pics. He is not using the stock shock. Where the shaft goes through the the cap. What shock is he using? I bought a silva shock hopefully I can use it just not sure of what cups and size ballstuds to use and what overall length the shock should be
Bubonic-X is offline   Reply With Quote
Old 11-19-2016, 10:17 AM   #992
The silva shock not very good. The shaft stick because of the rubber o-ring. I think Keven uses a Hot Bodies which are hard to find, you might want to try the xRAY, mcPAPPY or replex racing sells one I cant remember the name.
Steve
sdunnmcp is offline   Reply With Quote
Old 11-19-2016, 11:51 AM   #993
RacinJ's Avatar
Reflex Racing has the Team Prime shock. From what I've heard, it's a copy of the Hot Bodies shock.
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 11-19-2016, 09:36 PM   #994
azeroth's Avatar
Trader Rating: 20 (100%+)
Thanks for the help tomorrow i go and give it a try see if the mods work
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 11-19-2016, 10:41 PM   #995
I'm racing medium to hi bite asphalt I'm trying to find out what goes in the damper tubes for that surface? What is a associated part number?
Old 11-20-2016, 07:20 AM   #996
Rugspin's Avatar
I would start with 10,000 wt diff lube..... Depending on traction you might need to go to 15,000wt
Steve Burgess
Rugspin Graphix http://www.rugspingraphix.com
FB http://facebook.com/rugspingraphix
Email [email protected]
Rugspin is offline   Reply With Quote
Old 11-20-2016, 05:03 PM   #997
azeroth's Avatar
aaarg i hope every one else's race day went better than mine. time to spend more money i hate electrical failures.
Old 11-20-2016, 07:50 PM   #998
What do you think I should start as a length of the shock end to end? If I use Hebert's shock setup?
Old 11-20-2016, 08:14 PM   #999
EDWARD2003's Avatar
Do you mean 10,000 cst and 15,000 cst?
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 11-20-2016, 08:15 PM   #1000
EDWARD2003's Avatar
Just set the length of the shock to give you 1.0~1.5 mm of droop.
                 VBC 12M - D08 - FX
Old 11-21-2016, 03:17 AM   #1001
Hebert's shock looks to be standard length, about 66mm centre to centre (my last 12R5.2 had the same shock). You'll notice at the Worlds though he has shortened the rear pod top plate so the shock is mounted further back than normal.
If you mount the front of the shock straight to the chassis like Hebert, you may have to find the right length by trial and error, or make custom mounts. Instead of cutting the pod plate on my latest, I just made a custom front mount.
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
Old 11-21-2016, 10:30 AM   #1002
Talking
Can only tell so much from the pics.. But I used the aluminum and CF shock mount from a old rc125.1 when it was mounted to the chassis and raises it approximately to where it needs to be. Ill take a second look to find out where to mount the back of the shock. If drilling another hole is all I have to do that will be easy. Thanks for that measurement that helps alot
Old 11-23-2016, 11:27 AM   #1003
Fran's Avatar
Trader Rating: 155 (100%+)
Can anyone share what the advantages the Xenon front end are on the 12R5.2 over the stock front end. Is it just strength of materials? Thanks
Fran is offline   Reply With Quote
Old 11-23-2016, 05:33 PM   #1004
EDWARD2003's Avatar
The Associated lower arms shifted (tweaked) under a hard impact and required you to reset the arms. You want the arms to be at the same height left and right. Whereas the Xenon has a bushing insert setup which prevents this from happening. That's pretty much it.
                 VBC 12M - D08 - FX
Old 11-24-2016, 04:18 AM   #1005
Send a message via ICQ to MattW
With Xenon you also have the option to use stiffer plastics, as Xenon do both soft and stiff plastics. I generally use their stiff plastic arms, as I prefer the way they hold up under load.
MattW is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
