Like Tree19Likes
Old 11-17-2016, 05:42 PM   #976
azeroth's Avatar
Trader Rating: 20 (100%+)
could you give me a measurement across the bulkheads?
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 11-17-2016, 07:20 PM   #977
Originally Posted by RacinJ View Post
The Roche P12-2016 floating servo mount works. You'll need to use your AE ackermann shims to bring your tie rods back to correct alignment. (Move the servo forward.)
You may also want to order the Roche 16mm stand offs.
I've run it twice, so far, this way. Works fantastic.
Sweet! That's exactly what I needed to hear! It fits on the shock mount?
And they make a kit for that.....
Bubonic-X is offline   Reply With Quote
Old 11-17-2016, 07:53 PM   #978
chris moore's Avatar
Trader Rating: 87 (99%+)
There is no kit, you would have to buy the individual parts that J used.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 11-17-2016, 08:10 PM   #979
How do bolt the shock mount to it?
Old 11-17-2016, 09:18 PM   #980
RacinJ's Avatar
Po
I mounted the shock directly to the servo mount. You may need to lengthen your shock a few millimeters for proper pod droop.
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 11-18-2016, 07:32 AM   #981
Po
Nice! So the outer most holes on the floating servo mount are the same location as the standoffs that are there now? So I just order the Roche graphite floating servo mt. and the aluminum servo posts?
Old 11-18-2016, 07:49 AM   #982
RacinJ's Avatar
Yes. The floating servo mount lines up perfectly.
That would be the simplest solution. I'm using Tuning Haus 15mm standoffs with 1mm AE shims under the plate.
Old 11-18-2016, 08:16 AM   #983
Tried Rocheusa out of stock any other place you know of that would have it in stock?
Old 11-18-2016, 08:52 AM   #984
RacinJ's Avatar
The only other site I know of that handles Roche products is Apex RC.
Old 11-18-2016, 12:35 PM   #985
Send a message via ICQ to MattW
2mm wider per side. Most people then space the top arm mount back so it's in the same position as 5.0 and use the 5.0 upper brace.
I "think" the chassis is 2mm longer as well.
MattW is offline   Reply With Quote
Old 11-18-2016, 01:58 PM   #986
azeroth's Avatar
ok hmm the 5 and 5.1 use the same brace # 4606 so if that's the case I need to space the lower arms out 2mm per side to get to the same front width at kingpin as a kit 5.2
Old 11-18-2016, 02:05 PM   #987
azeroth's Avatar
oops my bad to many windows
Old 11-18-2016, 02:11 PM   #988
RacinJ's Avatar
The 12R5.1 and 12R5.2 use the same chassis plate. (4691) This chassis requires the longer, 12r5.1 Lipo Hinge Pin Brace. (4698) The 12R5 used the shorter, FT Hinge Pin Brace. (4606)
If you use the shorter 4606 you can shim your upper arm mounts in and have longer upper arms.
Old 11-18-2016, 02:28 PM   #989
azeroth's Avatar
I am running the original 4600 chassis plate with transvers battery not the 4691
Old 11-18-2016, 03:16 PM   #990
Shim your lower arms out 2mm, and you'll be the same as the 5.2 in front width.
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
