Like Tree19Likes
Old 06-19-2016, 06:29 PM   #931
Fran's Avatar
Trader Rating: 150 (100%+)
Originally Posted by Sinnin View Post
Thank you!
So i assume if you mix them up you can just use your digital calipers to figure out what is what.
That's exactly what he was saying. Plus they will come in handy when they wear out, or "collapse" as was mentioned. At a couple of bucks a set, they're worth throwing in before a race!
Fran is offline   Reply With Quote
Old 06-20-2016, 04:10 AM   #932
NomadRacer's Avatar
You might be able to figure out what springs you have by measuring the wire diameter and length with calipers and posting what you get. I notice that some manufacturers code there springs with a stripe of paint (color)... Associated not being one of them.
AE RC12R5.2/McFactory 12R5.2n/CRC GenX-10 SE WGT-R/AE RC10 Worlds
www.ashfordhobby.com
NomadRacer is offline   Reply With Quote
Old 07-11-2016, 05:04 AM   #933
ogreasurada's Avatar
Planning to get into 12th, does this car use universal wheel hub? What spare part should I stock for regular maintainance? thx
ogreasurada is offline   Reply With Quote
Old 07-12-2016, 08:54 PM   #934
I'm having tweak issues on the left side of this car. Rear rh is 3.2, where you measure sag is 3.2, front is 3.2ish. Seems very close but I don't think I can shim my way to 3.2 at the front. It is almost 3.2 left and right at the front but i don't think they are the same. But really close.
But on certain spots like around where the trailing arms meet the chassis it can vary by as much as .2mm maybe sometimes .3mm.
Maybe .2mm is hardly losing sleep over; Ride side of the car seems very consistent. When I put a straight edge on the bottom chassis it seems square.
Any thoughts?
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 07-14-2016, 03:51 PM   #935
snopro31's Avatar
Trader Rating: 36 (100%+)
You got pm
Any thoughts?
snopro31 is offline   Reply With Quote
Old 07-15-2016, 02:47 PM   #936
nitro2be's Avatar
Originally Posted by snopro31 View Post
You got pm
I had same thing. Ive crashed mine pretty hard couple of time and found that the screws that go into the bulk head were bent. replaced screws with new ones and replaced lower arms and car was straight again.
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 07-17-2016, 01:02 AM   #937
gee-dub's Avatar
Greetings All,
Fair warning, wall of text incoming...
Just bought an r5.2 this afternoon (editor's note: I'm sure this means a new version will be coming out in the next few weeks > >) and looking for input on electronics options. Looking for something that will support 3.5t.
ESC: I would like something with an external, portable programming box. My first choice was going to be the Reedy 410r 'black box', however I see it has been discontinued and the replacement models do not appear geared as suitable replacements. I then looked at the Orion R410 pro, which also appears to have an embedded voltage booster (a plus), however it appears out of stock everywhere (US). Thoughts on something similar that meets the above criteria would be appreciated.
Servo: Low profile, super fast @6v. Preferably something that will work in the highest frame rate with an Airtronics M12.
Voltage booster (if needed): ?
gee-dub is offline   Reply With Quote
Old 07-17-2016, 07:58 AM   #938
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
ORCA VX3 esc, will run 3.5T with no fan.
Sanwa SRG-HR (the HS is for low voltage but I have been running one on higher voltages for years, and is faster, both support SSR mode)
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 07-17-2016, 08:51 AM   #939
EDWARD2003's Avatar
Programming box? Just get a LRP flow with a booster and run the 5.0 firmware 0,1,1,1,1,1,0, and run a rollout of a 35 mm with either a LRP 4.0 w/ 12.0 mm rote or Muchmore 3.5 1/12 edition.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 07-17-2016, 08:14 PM   #940
nitro2be's Avatar
Yup. LRP flow with LRP 4.0t and perfect for me. I have not even needed a booster. I have one waiting but has not been needed .
Old 07-27-2016, 02:16 AM   #941
RC MARKET's Avatar
Xenon VSS Front End Kit
RC MARKET is offline   Reply With Quote
Old 08-10-2016, 11:40 AM   #942
SMC sells a 1s ESC with a programmer check it out
Bubonic-X is offline   Reply With Quote
Old 08-10-2016, 08:41 PM   #943
Rugspin's Avatar
Hobby wing has a very good ESC for 1s
Steve Burgess
Rugspin Graphix http://www.rugspingraphix.com
FB http://facebook.com/rugspingraphix
Email rugspinner@aol.com
Rugspin is offline   Reply With Quote
Old 08-11-2016, 04:28 AM   #944
NomadRacer's Avatar
I just picked up a HW 1S ESC. It comes with 12awg wires, soldered with silver content solder. Make sure you have a good soldering iron (50 watt+) to swap out to "12th scale friendly size wire).
Old 08-11-2016, 05:31 AM   #945
Racermac73's Avatar
For removing the big wires I've found if you take side cutters and clip the wires off close to the solder tabs it takes far less heat and time to remove what is left. Trying to remove the wires in full generates a lot of unnecessary heat on the circuit board. Once removed TQ brand 16ga wire and TQ sensor wire are perfect to the motor as they flex very easily. TQ 1000 wire to the battery.
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
