Like Tree19Likes
Old 05-30-2016, 12:04 PM   #916
nitro2be's Avatar
Originally Posted by JimmyMac View Post
Do you have a lot of front end droop/sag?
no, 4 shims on top then e clip. no droop or sag.
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 05-30-2016, 12:14 PM   #917
nitro2be's Avatar
Originally Posted by RedBullFiXX View Post
At TQ where you are running
I typically start at Fr 42.5, Rr 44
39mm front tires should still have 3mm RH
Sounds like a droop or assy issue
Can you post pics of your car ?
TQ is where Im running, these were left over tires that I cleaned up and size just came out best at 41 39.5 . I was hoping to get another run or two out of them. Its right there at the 3mm 2.9 your right. Im at work on this fine holiday and unable to get a photo .
How do people run this small of tire and get ride height of 3.5 and 3.2. I see set up sheets like this for associated.
Old 05-31-2016, 05:36 PM   #918
RacinJ's Avatar
Attached is a picture of my 12R5.2 that I ran at TQ two weekends ago. With 40mm tires I have 4.7mm of ride hight with no shims under the front bulkheads.
Post some pics of your frontend. Its gotta be something simple.
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 05-31-2016, 05:39 PM   #919
RacinJ's Avatar
Old 05-31-2016, 08:01 PM   #920
Check that your steering blocks are up the right way. If they're upside down, you'll lose a few mm of ride height.
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
Old 06-06-2016, 08:56 PM   #921
nitro2be's Avatar
Thank you. I've been kinda busy, but was able to get 3.7 with all shims removed and car ran great . I put a LRP 4T in this rocket and it was going like hell. Lol.
Old 06-07-2016, 03:33 AM   #922
NomadRacer's Avatar
Anyone tried the VBC Racing (D-05-VBC-0113) Ball Diff? I see it listed as fitting the R5, comes with bearings,TKO diff rings, etc. Looks to be a good deal price wise...
AE RC12R5.2/McFactory 12R5.2n/CRC GenX-10 SE WGT-R/AE RC10 Worlds
www.ashfordhobby.com
NomadRacer is offline   Reply With Quote
Old 06-08-2016, 11:55 AM   #923
aracefan's Avatar
Trader Rating: 38 (100%+)
^^ Yes, check this first, after you make sure you have no shims.
Shims are for cheap racers like me that run 43-44mm tires for a couple weeks before shaving them down - then the shims come out.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 06-13-2016, 12:01 PM   #924
nitro2be's Avatar
I check and they are correct. I do the the same thing with my tires. lol
I have new question , I have a light ticking noise in my rear Diff. I did my maintenance, lube balls cleaned everything and reassembled. Those concave shims are in correct , did not over tightened and balls and rings seem good. I can't find where that little ticking noise coming from.
Old 06-13-2016, 12:32 PM   #925
NomadRacer's Avatar
Originally Posted by boina View Post
You tried it bro ? how's the feelings
No man, did not go for it. I sent email to VBC with questions, never heard back from them. I found a nice $ on the IRS diff kit and bought that instead.
Old 06-13-2016, 12:58 PM   #926
Check your outer hub bearing.
Serzoni is offline   Reply With Quote
Old 06-13-2016, 05:12 PM   #927
nitro2be's Avatar
I just replaced bearings, but your right that is one thing I did not do , check the bearings i could of damaged one. Thanks
Old 06-19-2016, 04:35 AM   #928
Sinnin's Avatar
I own a 12r5.2 and a 10r5.1 both have been bought used. I have no idea what front springs are on either car, but would like to start trying different set-ups. Is there a way to identify the springs or should i just buy new ones and go from there? How do you guys keep track of the spares in your pit boxes?
David "Bart Man" Bartholomew
Sinnin is offline   Reply With Quote
Old 06-19-2016, 07:15 AM   #929
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Try new AE ,018" & 020" springs, each are identified by diameter of the coil
They don't last forever, replace the old ones with a fresh set, and keep new spares
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-19-2016, 06:21 PM   #930
Sinnin's Avatar
Thank you!
So i assume if you mix them up you can just use your digital calipers to figure out what is what.
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
