Like Tree19Likes
Old 04-18-2016, 05:56 PM   #901
NomadRacer's Avatar
Originally Posted by EDWARD2003 View Post
Awesome work!
Thanks man! I have an old Taig manual micro lathe and mess around a bit from time to time.
AE RC12R5.2/McFactory 12R5.2n/CRC GenX-10 SE WGT-R/AE RC10 Worlds
www.ashfordhobby.com
NomadRacer is offline   Reply With Quote
Old 04-21-2016, 06:50 PM   #902
Thinking about getting one of these to play around with. Kinda tired of all my 2wd buggys so trying some road cars. Started with a old touring car had fun with that so got a new Detc 410v2 what a nice car. Now thinking about one of these ?
sgtlt is offline   Reply With Quote
Old 05-19-2016, 09:09 AM   #903
aracefan's Avatar
Trader Rating: 38 (100%+)
I've got a 12R5.1 and love it. Foam tired cars on carpet is fantastic. You won't be disappointed with the speed and handling of these little rocket ships.
And really, any of the 1/12th pan cars, CRC, XRay, AE, VBC, etc., are competitive. We have at our track a R125.2, R125, CRC, XRay 2016 spec (and my 5.1) and we are all swapping the lead - it's a blast. I will say, if I had the money I would get the XRay. . . but really any of them are great, and I'm an Associated fan going back 25 years.
I will say, buy a good 1S specific ESC, seems to make a difference - maybe not. And I'm sure someone can chime in that has a lot more experience than me.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 05-23-2016, 12:23 PM   #904
NomadRacer's Avatar
What's the preferred brand of spur gear? I'm pretty much sold on CRC pinions.
Old 05-23-2016, 04:05 PM   #905
aracefan's Avatar
I've always liked and had good results with Kimbrough spur gears and pinions. I would say if you're gonna run CRC pinions, may as well run CRC spurs, too.
Old 05-23-2016, 04:14 PM   #906
Fran's Avatar
Trader Rating: 150 (100%+)
I think you have to use a non-flanged bearing on the CRC spur gear on the Associated axles & hubs if I remember correctly.
Roadrunnersrc.com
Team Associated 12R5.2
Team Associated 10R5.1
Team Associated TC7.1
Team Associated F6
Fran is offline   Reply With Quote
Old 05-24-2016, 04:00 AM   #907
NomadRacer's Avatar
I would rather avoid the need to change to a different type of bearing (already bought a bunch of spares for AE set-up).
Any opinions on the Xenon brand?
Old 05-24-2016, 04:11 AM   #908
Racermac73's Avatar
No need to even think twice.. if it says xenon on it than its top notch stuff. I've never had a bad parts from him and his springs are the best I've ever owned.
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
Old 05-24-2016, 04:32 AM   #909
Trader Rating: 33 (100%+)
Xenons are good along with PRS if you can find them in stock. I would stay away from CRC spurs unless you get the ones with 1/8 balls. When they went to the smaller diff balls it throws off the diff hub spacing and will end up shimming the diff cone and nut assembly.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 05-24-2016, 04:33 AM   #910
NomadRacer's Avatar
Cool, I'll order some. I've already got a set of Xenon front-end bulkhead for the McFactory chassis that I have on order.
Old 05-24-2016, 04:51 AM   #911
EDWARD2003's Avatar
McFactory chassis and Xenon front end... Nice combo!
Xenon spur gears are nice in the mean time, but Axon spur gears are .
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 05-30-2016, 11:10 AM   #912
nitro2be's Avatar
Im having trouble getting front end ride height to 3.2 . I finally bought a truer and cut my front tires to 41R 39.5F . I have removed all shims under bulkhead blocks , and all shims on kinpins are on top. Ride height in front is below 3mm more like 2.8 2.9 . What am I missing Im confused.
Also I watched your videos Edward and I understand how to lower car with front hubs , but how do I raise front of car?
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 05-30-2016, 11:30 AM   #913
JimmyMac's Avatar
Do you have a lot of front end droop/sag?
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 05-30-2016, 11:33 AM   #914
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Make sure there is no king pin shims between the knuckle and lower control arm for starters, and remove most, if not all droop in the front end. Do this by placing king pin shims on the top of the upper control arm. I find the softer the front spring, the less droop is needed, with .18's, I run 'e-clip preload' on the spring, 0.20's no droop/preload, 0.22's 0.2-0.4mm droop.
If this will not make ride height, start the fronts a tad bigger-40 to 39.7mm.
But really, in all but super high traction, you don't need to run the tires that small. Also, the bigger the stagger on the tires F/R, the less steering you will have, typical stagger is 1mm.
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 05-30-2016, 11:43 AM   #915
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
At TQ where you are running
I typically start at Fr 42.5, Rr 44
39mm front tires should still have 3mm RH
Sounds like a droop or assy issue
Can you post pics of your car ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
