Associated RC 12 R5.2
#886
The R5.1 and R5.2 use the same chassis plate. The original R5 did have a narrower front end.
#888
#889
Does anyone have Joe Trandell's set up from his ROAR 17.5 nationals winning car?
#891
Does anybody make a floating servo mount?
#892
#893
Where can u buy that floating servo setup?
#895
Gotcha, can't find a pic of it anywhere, on the reflex site there is no pic as well
#896
McFactory Motorsports RC12R5.2 aluminum chassis and rear pod ready to head out to it's new home.
This is a newer version of what Kevin Hebert ran at the ROAR Carpet Nats back in March. In fact 1&2 in Mod 12th scale both ran McFactory aluminum chassis and they were 3 laps ahead of everyone else.
For more info check out:
http://www.rctech.net/forum/electric...torsports.html
https://www.facebook.com/mcfactorymotorsports/
http://www.mcfactorymotorsports.com/
#898
Making Stuff Werk
I have been working on getting a couple of bodies mounted on the 12R5.2. Got myself a set of Protoform Crosshair magnetic mounts and the inside diameter is to large for the body posts from the kit
The fix? Make some sleeves from brass rod!
#899
So... I also got the ABC Hobby body post cutter/trimmer tool from ApexRC. In order to trim the length of my body posts I needed to make some sleeves for the tool. I got a bit fancy and machined them with a short collar with grooves to make it easy to pull them out.
