Like Tree19Likes
Old 02-21-2016, 10:03 PM   #856
EDWARD2003's Avatar
First race weekend with the Associated 12R5.2 and second time racing modified(Yokomo R12 for the first time). Good fun and clean racing by all.
I managed to sneak in for the TQ and ended up 2nd. Good fun
https://www.facebook.com/edward.pick...01349103742891
The second video is 21.5 2 cell. This was my second outing with this Associated 12R5.2 chassis.
https://www.facebook.com/edward.pick...01349103902571
Qualified 2nd and ended up 1st <----? I still don't remember the first place driver crashing. I was confused when I saw the results. Lol.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 02-21-2016, 10:34 PM   #857
Gravity Dodger's Avatar
Does anyone have a good setup sheet for 17.5 1s on the new crc carpet? Have a big race coming up in a couple weeks and was curious what others are finding works well with the high bite.
Team Destiny, Power by TSR
Gravity Dodger is offline   Reply With Quote
Old 02-22-2016, 12:12 PM   #858
Trader Rating: 44 (100%+)
With this kit being discontinued at the AE site anyone have any insight on whether or not a new version is in the works?
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 02-22-2016, 01:39 PM   #859
AE-Reedy
The kit is not discontinued. Where did you see that?
Sean Cochran is offline   Reply With Quote
Old 02-22-2016, 04:24 PM   #860
That's odd for a while on the RC10 site I had to go to the discontinued models page to access any parts and info on it and it was listed out of stock in a number of places. I just checked and it looks like it's back in stock and on the normal page. Odd?!?
Aaron Moore
Old 02-22-2016, 06:06 PM   #861
nitro2be's Avatar
im confused on the side dampers. Manual shows diff grease same grease you would use on ball diff. Set up sheet shows 20,000 cst which I assume would be same as 20k diff oil for gear diff in off road buggy, and another source shows rear oils 30wt/30wt. So what am i going to use in the side dampers ? diff grease, diff oil, or shock oil. Sorry this is very dumb but I just can't grab the idea of these dampers!
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 02-22-2016, 06:11 PM   #862
JimmyMac's Avatar
If you are talking about damper tubes, I would suggest 10k, 15k, and 20k. Go with 15k and go up or down depending on track conditions (for carpet).
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 02-22-2016, 06:25 PM   #863
EDWARD2003's Avatar
You can use differential oil from your buggy for the side tubes. Make sure it's either 10,000, 15,000 or 20,000. 10K, 15K, 20K are the same thing.
The kit oil 30wt will be for the center damper. However, you can use other damper oils. However, please keep in mind on the choice of oil you use for tuning your damper. There are two kinds of oil viscosity measurements used in the hobby "WT" and "CST". Personally I run CST in all my cars, because most on-road setups follow this. Not all, but most.
                 VBC 12M - D08 - FX
Old 02-22-2016, 06:26 PM   #864
nitro2be's Avatar
I did put 15k in so Im good. I was doing some reading and started getting confused. thanks.
Old 02-24-2016, 04:37 PM   #865
Racermac73's Avatar
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
Old 02-24-2016, 05:49 PM   #866
Racermac73's Avatar
7075t6 for the 5.2
File Type: jpg _20160224_193346__1456364770_73_251_183_223.jpg (177.5 KB, 222 views)
Old 02-24-2016, 06:34 PM   #867
EDWARD2003's Avatar
Drool...
                 VBC 12M - D08 - FX
Old 02-25-2016, 05:19 AM   #868
NomadRacer's Avatar
Originally Posted by Racermac73 View Post
7075t6 for the 5.2
IN!
AE RC12R5.2/McFactory 12R5.2n/CRC GenX-10 SE WGT-R/AE RC10 Worlds
www.ashfordhobby.com
NomadRacer is offline   Reply With Quote
Old 02-27-2016, 12:47 PM   #869
nitro2be's Avatar
help me, which battery is better for this car, IE weight , run time, quality, I will be using a 6.5t LRP. SMC 5800 or protek 7400 both are 100c ?
Old 02-27-2016, 12:57 PM   #870
nitro2be's Avatar
also trying to figure out sping package to start with at TQ which I believe to be a med grip track. I was thinking silver sides with blue center or blue sides with gold center.
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
FISHNFOOL9, vr6jett
