Like Tree19Likes
Old 02-16-2016, 03:03 PM   #841
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by nitro2be View Post
thank you. I start there and check out the app.
6.5 is fairly mild for 1s 1/12
Shouldn't be too hard to hang onto with the correct tires
Old 02-16-2016, 03:14 PM   #842
nitro2be's Avatar
Thats what I was thinking. I hold on with a 5.5t 2s 1/10 on clay just fine and would like more power. Tire Tire Tires what I alway say. Thank You I feel better
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 02-18-2016, 01:09 PM   #843
nitro2be's Avatar
When using sticky icky magic sauce on foam tires do we just put light layer on top or use and let soak in? Foam tires like a sponge and I'm use to rubber off road.
Old 02-18-2016, 01:11 PM   #844
Just SXT for TQ
Soak 10m 1/2 front, full rear
If you need more steering 3/4 front or more as needed
Old 02-18-2016, 01:27 PM   #845
nitro2be's Avatar
Just SXT for TQ
Thanks, I did buy the STX to add to my sauce collection.
Old 02-19-2016, 05:29 AM   #846
NomadRacer's Avatar
Back home from the hospital and digging into some packages!
Huge thanks to Christian Tabush at Reflex Racing RSD for help with the transverse conversion kits mounting and tuning tips.
I have a charger ( Hitec X1) and what I hope is the rest of the odds and ends to get me started on order. I still want some bodies and pinion gears...
AE RC12R5.2/McFactory 12R5.2n/CRC GenX-10 SE WGT-R/AE RC10 Worlds
www.ashfordhobby.com
NomadRacer is offline   Reply With Quote
Old 02-19-2016, 03:56 PM   #847
nitro2be's Avatar
after doing a little reading i am now concerned about esc I planned using with a 1s 6.5t . LRP spin
http://www.amainhobbies.com/rc-cars-...p80250/p291941
Will this still work with 1s? I already have it
Old 02-19-2016, 04:11 PM   #848
WesRaven's Avatar
Pretty much any ESC will work with 1S, but you need to use an external voltage booster for the receiver/servo to work properly. I use the Novak unit with an old Tekin RS in my 12th scale.
Just make sure you either set the ESC voltage cutoff to 3.7 volt or off if that ESC doesn't have that option. If the default cutoff of 2S batteries are set it may not even try to work when you turn it on.
Wes Raven - ActivRC.com
Ventura Roadrunners - RoadrunnersRC.com
WesRaven is offline   Reply With Quote
Old 02-19-2016, 04:36 PM   #849
nitro2be's Avatar
If Im not racing and just running on carpet track for fun how would this car be if I use my 2s shorty packs with a higher turn motor like at 17.5t? at this point its seeming cheaper to buy higher Turn motor? trying to keep my initial investment down.
Old 02-19-2016, 05:51 PM   #850
RacinJ's Avatar
You can definitely run a 2s shorty pack and a 17.5 or 13.5 motor. Last month Paul, James and David Banta from Arizona ran this set up in 1/12th mod. The speed will be comparable to your current mod motor.
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 02-19-2016, 09:52 PM   #851
nitro2be's Avatar
Decisions decisions. Hmmm 55 to 60 grams more , must run battery sideways I assume. I can see having the extra weight to move around would help in mod. Dave, I think I even was reading somewhere you did 21.5 2s in your car = est. 10.5
Old 02-20-2016, 11:47 AM   #852
AZ Wolfie's Avatar
I've seen a regular shorty run in a transverse setup, but I think they had to run the body a touch higher.
The shorty packs that RacinJ has seen in my car were the "Low Profile" Shorty batteries, which have the same dimensions of a regular 1s pack.
As far as speed in concerned, running the 2s pack with a 17.5t on boost will give you plenty of speed. According to my telemetry top speed was just over 40 mph. If that isn't fast enough, then run a 13.5t and hold on!
AZ Wolfie is offline   Reply With Quote
Old 02-20-2016, 01:50 PM   #853
nitro2be's Avatar
thank you for the information cause Im still building the car and was wondering if the regular orion shorty was gonna fit.
Old 02-21-2016, 04:27 AM   #854
EDWARD2003's Avatar
Had an awesome weekend with both of my 12R5.2's in modified and stock. I'll post some race info and my setup for both classes.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 02-21-2016, 08:18 AM   #855
NomadRacer's Avatar
Looking forward to your post as I hobble around with my carbon fiber crutch
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
