Like Tree19Likes
Old 01-26-2016, 10:54 AM   #826
I picked up a used R5.2 for some light racing, and while I was giving it a once-over for dirt/damage/slop, I noticed that the aluminum part of the tube dampers is flared slightly. It looks like a repair was attempted as well, but that could just be from aluminum fatigue or something.
I don't really understand how the tubes could have sustained damage in this way, as the open ends are mounted inboard.
It's my first time racing 1/12th anyway, but is this something I should be concerned about?
"Speak only if it improves upon the silence."
http://goo.gl/MFfbzr - My ever-updating comprehensive spring rate chart
Bracket is offline   Reply With Quote
Old 01-26-2016, 11:17 AM   #827
Jorge T's Avatar
The tubes may have been damaged by hitting something and making the pod twist.
The aluminum tubes are $6 a pair, I would get new ones to be sure both side have equal dampening.
Also make sure the damper tube shaft part is not damaged or scratched.
RSD MS
Jorge T is offline   Reply With Quote
Old 02-02-2016, 06:07 PM   #828
Really nice 12r5.2 in the for sale section.
NEW 12r5.2 w/t Tamale adjustable rear pod
Guy also has some other stuff for sale also
NCOHOG is offline   Reply With Quote
Old 02-06-2016, 06:45 AM   #829
EDWARD2003's Avatar
I made a video on "How to polishing your kingpins". The kingpins used in the video were 12R5.2 kingpins
https://www.youtube.com/watch?v=DynVQfnG4-0
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 02-06-2016, 11:46 AM   #830
NomadRacer's Avatar
I followed your video, along with hand reaming the steering blocks 1/8". Huge improvement.
AE RC12R5.2/McFactory 12R5.2n/CRC GenX-10 SE WGT-R/AE RC10 Worlds
www.ashfordhobby.com
NomadRacer is offline   Reply With Quote
Old 02-06-2016, 08:09 PM   #831
NomadRacer's Avatar
I'll some packages to open in a week or so. Stuck in the hospital right now with all this waiting on the table to unboxed!
Reedy Blackbox 410R w/program box
Futaba 3PL
ProTek RC 1S LiPo 100C 3.7V/7400mAh Battery
Enough Lunsford Racing Titanium screws for everything above the chassis plate.
On order
RSD Transverse Conversion Kit
I have another week to gob so hopefully the RSD stuff will be there too!
Old 02-07-2016, 01:55 AM   #832
EDWARD2003's Avatar
Futaba 3PL
On order
Hold on there, you have another week to go. Looks like you got an awesome package setup for your 1/12th scale. Best of luck!
                 VBC 12M - D08 - FX
Old 02-07-2016, 11:42 AM   #833
NomadRacer's Avatar
Yes mate, all's left to get is a couple of bodies,a charger,and get some tires truer.
I got one body but the right rear is messed up...like it was snatched from the mold to quick. I'm "anal" about perfect Lexan. Love to paint and have received many awards in 1/24 scale and HO in the past.
Old 02-10-2016, 06:55 AM   #834
Default Active Castor Settings
We have a small low traction club racing track.
I have to assume it is probably more bumpy than our wcics racing carpet and much less traction at the club level.
I thought about putting the active castor at 5 degrees as so indicated in the tips section. Usual is 10 degrees; good idea?
I am using the 3.25 degree castor adjustment as I feel the car has alot of steering already.
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 02-10-2016, 10:23 AM   #835
rc pete's Avatar
As a starting point for bumpy, lower traction conditions, I'd recommend to up your tire size to 43 rear/41.5 front as a minimum (you could go a little taller still: 44/42) and up your height to 4mm so that you're not bottoming out over the bumps. That will make the car driveable and you can tune from there.
Running less reactive castor will take away a lot of steering once you dive into the corner. If that's what you need, then go for it. I normally stick to 10 and tune with other adjustments. You could go with 1.8 degree castor or take camber down to 0.5 degrees to take away some steering.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 02-15-2016, 03:54 PM   #836
nitro2be's Avatar
I purchased one of these bad boys and Ill have the kit on Friday. Ive ran 1/10 off road indoor clay for couple of years now and thought these pan cars look real fast and harder to drive . I plan to pull my 6.5T LRP and ESC from one of my cars and use in the 12r5.2 until I decide If I really like or not onroad cars. What range of pinion would be good start at TQ racing track? I see some cars with huge gears and others with small.
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 02-15-2016, 04:05 PM   #837
Wow. A 6.5 is quite a hot motor for running in a 1/12th scale car, especially for someone who is new to running 1/12th. In the US, by far the most popular motor choice is 17.5 and even those can be a little much for someone who's brand new to the 1/12th scale arena. It is probably not a good idea to try learning how to drive a 1/12th scale car with the rip of a 6.5 strapped into it.
New Bern, N.C.
CRC, McFactory, Motiv
vafactor is offline   Reply With Quote
Old 02-15-2016, 05:43 PM   #838
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Start somewhere around 40 to 45mm rollout
So like
43mm rear tire
90t spur gear
27t pinion
RcRatio app is great for rollout maths
Old 02-16-2016, 02:24 PM   #839
nitro2be's Avatar
I know i know. I have a good throttle finger and been driving RC cars for many years, I just don't race anymore due to working weekends for last couple years. if Its to much I'd buy a smaller motor if I can't drive it. I figure I have Mod motor might as well try it. I LIKE GOING FAST.
Old 02-16-2016, 02:26 PM   #840
nitro2be's Avatar
So like
43mm rear tire
90t spur gear
27t pinion
thank you. I start there and check out the app.
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
