Like Tree19Likes
Old 12-08-2015, 02:36 PM   #751
JimmyMac's Avatar
Originally Posted by Cosmo View Post
No. I tried that too. It was better, but the battery would still slide around.
Change the standoffs to something lower. TQRCRacing sells lower standoffs.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 12-08-2015, 03:27 PM   #752
Send a message via ICQ to MattW
You don't really need any parts to convert to transverse. You can just move everything around and be careful about how you tape the battery in, i've played around on and off with it like this. The only real advantage that I can come up with is that you have the flexibility to move the battery forward and back depending on how you fit your electronics in. I want to try it inline, but with the connectors toward the back at some point. I have a gut feeling that if you have a lot of direction changes in your track, inline might be better, but if you have a lot of sweeping corners then transverse might be better.
MattW is offline   Reply With Quote
Old 12-08-2015, 03:40 PM   #753
Cosmo's Avatar
Thought about it but sold the car and got a Rev8
Cosmo is offline   Reply With Quote
Old 12-08-2015, 07:01 PM   #754
Thanks Cosmo, this should give me a good starting point.
I sold the car this past weekend, but if you take the car as it is currently set up and look at where the back of the battery touches the piece that the side tubes are mounted on, that's where the edge of the battery sits in the transverse configuration.
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
Old 12-09-2015, 08:36 AM   #755
I was asking because I have a 12r5.1 which is the transverse battery kit. And really the only thing I want to convert to is using the side dampers instead of the side shock. RSD makes the conversion to make a transverse battery location. Then add the side dampers and drill the holes for the dampers on the top motor plate.
You think this would work?
Bubonic-X is offline   Reply With Quote
Old 12-09-2015, 08:46 AM   #756
Cosmo's Avatar
It sounds like it would work. Not having tried it I can't say for sure though.
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Old 12-09-2015, 09:03 AM   #757
RacinJ's Avatar
I've built a 12R5.1 with the 12R5.2 damper tube setup. It works very well.
You will need the 5.2 crossbrace, upper pod plate, damper tube assemblies and hardware. Use the 12R5.2 kit manual and catalog to confirm the part numbers.
The 5.2 upper pod plate bolts on the the 5.1 pod without issue and you may want to trim the battery support tabs to allow the battery to be moved back further in the car.
RacinJ is offline   Reply With Quote
Old 12-09-2015, 10:09 AM   #758
ScottE1776's Avatar
I was able to do this as well. I actually cut the length of the damper tubes and pistons a bit but it worked pretty well
ScottE1776 is offline   Reply With Quote
Old 12-10-2015, 07:25 AM   #759
Parts on order. Just concerned about the shock length coming off the new upper pod. Way longer than the 5.1. And I will mounting that shock on the chassis not on that stand off like the 5.2 will this affect the handling or is everthing relative?
Old 12-26-2015, 07:06 PM   #760
EDWARD2003's Avatar
Looking forward to running this chassis this year. A few changes I'll be making, running transverse battery position and Yokomo X-Shock for central dampening.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 12-26-2015, 07:57 PM   #761
choisan's Avatar
hey, ed. the new yokomo r12 is coming this march, right? why not wait? heard anything about it except it will use the no offset rim?
trg112 N & W; bd7 2015 black; yokomo r12c3.1; mugen mrx4, 5wc; sanwa m12s; yokomo 114duo; icharger 406s
choisan is offline   Reply With Quote
Old 12-26-2015, 08:51 PM   #762
EDWARD2003's Avatar
Yes, the new Yokomo is coming. I'm just looking for something different and I'm a huge fan of the Associated front end. The Yokomo front end can be a little difficult at times, but when setup correctly, its fast. Buying an Associated is basically the same thing I have right now. The only difference is parts availablity for the R5.2. There are some Yokomo parts that they no longer produce anymore and I'm in need of them. The Associated is a nice change and the price was right. It was silly cheap, thanks RC Champ!
                 VBC 12M - D08 - FX
Old 12-27-2015, 02:31 AM   #763
G-rem's Avatar
If someone is interested, I sell mine: 12th scale pan car Team AE 12R5.2
G-rem is offline   Reply With Quote
Old 01-04-2016, 01:11 PM   #764
So are the chassis brace standoffs the same length as the 12r5.1 noticed they have a different part number
Old 01-04-2016, 02:27 PM   #765
Trader Rating: 136 (97%+)
what gearing would you recommend for 17.5
jasontraci is online now   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
