Like Tree19Likes
Old 04-29-2015, 01:29 AM   #691
Originally Posted by Joost K. View Post
Hello everyone...
Anybody have an idea if Team Associated is working on a new 12th scale? With almost all others having new versions I was wondering if AE was coming with anything new soon...
Good morning
+1
I am ready to purchase a RC 12 R5.2 but if Team Associated is coming with new kit i can wait .
Please Advise
drover is offline   Reply With Quote
Old 05-08-2015, 10:56 AM   #692
RacinJ's Avatar
Originally Posted by drover View Post
Good morning
+1
Please Advise
+1
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 05-08-2015, 02:54 PM   #693
I have found the same thing as SLOWER ONE discussed previously. Often the two mating surfaces on the bottom of the plastic football (where it rests on the main chassis plate) are not quite flat and also not quite aligned with each other. The football's mating surface(s) can be easily aligned and flattened by rubbing the football gently on an Emory board or fine sandpaper. As a side benefit, doing so also roughens up the football's mating surfaces so they will "grip" the graphite better, making the football less prone to getting get knocked out of position so easily. It also helps to lightly skuff the shine off of the graphite plate just in the 2 areas right where the football rests in order to add a bit more friction and resistance to slippage there. After "fitting" the football to the chassis plate in this manner, it typically will take a really heavy impact to knock the football out of adjustment.
vafactor is offline   Reply With Quote
Old 07-09-2015, 04:50 PM   #694
My chassis plate will need replacing soon. What are some good options (OEM or aftermarket)?
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
Old 07-09-2015, 05:36 PM   #695
Madulla's Avatar
The Reflex Racing RR12 is a really great conversion kit. Comes with a floating servo mount and a floating adjustable rear axle. It's a little more than just a chassis, but everything you have will bolt right on. You can run your battery inline or transverse too.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 07-09-2015, 08:37 PM   #696
Castradamus's Avatar
Trader Rating: 53 (100%+)
C&M Motorsport CM12v2
I am building one now. It shaves some weight and gives you 3 battery positions. Also allows you to move the side springs to inward to and optional location.
Associated RC 12 R5.2-cm12_1.jpg   Associated RC 12 R5.2-cm12_2.jpg   Associated RC 12 R5.2-cm12_3.jpg
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 07-09-2015, 08:51 PM   #697
JimmyMac's Avatar
Looks nice!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-10-2015, 02:46 AM   #698
Thanks guys, that's the sort of info I was after.
Scott Tapsall
Old 07-10-2015, 04:22 AM   #699
Hey email [email protected] for info on thethe CM12V2
Old 07-10-2015, 05:27 AM   #700
Thanks Castradamus. I've also found their Facebook page for info.
Scott Tapsall
Old 07-18-2015, 12:51 PM   #701
Default Setup
Well I'm about to venture into some 1/12 scale onroad racing. Been a 1/12 scale oval guy for many-many years, but this will my first attempt at turning both ways. I picked up a nice R5.2.so any base line setup pointers would be greatly appreciated. Track is from what I can tell relatively new so grip level is between lose- med. Any help would be great.
Thanx
Scotty
jsz48 is offline   Reply With Quote
Old 07-18-2015, 02:54 PM   #702
Cosmo's Avatar
Thanx
Scotty
I'm assuming you're the same Scotty I think you are...
Grip has started to come up on the track. On my RC12 I was running blue center spring, silver side springs, 10k in the damper tubes, I think 40wt in the shock. It was just a bit loose with gray/graylow tires towards the end of the race. Now that the traction has come up and running green/blue I think it would be right where it should be.
Cosmo is offline   Reply With Quote
Old 07-18-2015, 03:34 PM   #703
Default Yep
Yep that's me thanx for info- hopefully see ya soon.
Old 07-21-2015, 09:53 AM   #704
How much is the conversion kit?
Bubonic-X is offline   Reply With Quote
Old 07-21-2015, 10:02 AM   #705
Is there a rear pod with CRC style adjustable ride height that can be purchased anywhere online?
Thanks in advance.
Ted Su(TW) is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
