Like Tree19Likes
Old 02-01-2014, 12:39 PM   #661
hanzo3's Avatar
Trader Rating: 55 (100%+)
Hey. What is the best way to fill the side tubes? And how much to put in there?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 02-17-2014, 06:29 PM   #662
Trader Rating: 32 (100%+)
Check out the new Magnesium parts and Snowbirds win for RMR!
You can email me at Red_mosquito7@rocketmail.com for information
Monti
Monti is offline   Reply With Quote
Old 04-16-2014, 11:44 PM   #663
Here's my build so far.
More photos on my blog: apexattitude.blogspot.com.au/
-Jeremy
www.apexattitude.blogspot.com.au
Silberpfeil is offline   Reply With Quote
Old 04-28-2014, 01:58 AM   #664
About to buy a pan can and this will be my first wanting to buy a AE pan car, any tips when building it ?? What ran touring car all my life.
____________________
TC6.2 MUCHMORE FLETA PRO MUCHMORE FLETA ZX 4.5
HITEC SPEKTRUM RSD
onroad racer is offline   Reply With Quote
Old 08-03-2014, 06:19 PM   #665
CristianTabush's Avatar
Default RSD Does the R5.2
With the carpet season just around the corner, we have just released our transverse battery conversion kit for the AE Pan Car. The conversion kit makes the car easier to drive and more consistent over 8 minutes. It also allows you to play with your forward shock position a bit. You can move the front mounting position really far forward or really far back. We found the furthest most position gave the most stability.
Use the conversion in combo with our Team Prime 12th scale shock and our springs to get the most out of your AE Car.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 08-20-2014, 01:40 PM   #666
Rugspin's Avatar
So Question on the Side Dampeners. Does it matter which way they are ran? I've seen some guys run the alum to the outside the instructions show them on the inside. I would think on the outside would keep dust and debris from getting in them quite as much.
Steve Burgess
Rugspin Graphix http://www.rugspingraphix.com
FB http://facebook.com/rugspingraphix
Email rugspinner@aol.com
Rugspin is offline   Reply With Quote
Old 08-20-2014, 10:26 PM   #667
AZ Wolfie's Avatar
I've run the side dampers in both configurations, and have preferred having the aluminum on the inside like the kits says. Main reason is I found that the plastic area is going to get dirty regardless, so I like it outside where it can be easily cleaned off after each run.
My other reason is purely a theory. Since any excess fluid in the tube will want to go down hill, I want the aluminum part at the high point of the car which is the inside. This way that excess fluid will want to flow out of the tube, giving the plastic part a constant fresh supply. So in theory this could allow the damper tube to work properly over a longer period.
Again my second reason is just a theory, and could easily be hogwash. However, the ease of cleaning is what really has me sold on the kit method.
AZ Wolfie is offline   Reply With Quote
Old 08-21-2014, 05:10 AM   #668
I turned it around as although it's slightly harder to clean, it gets a lot less dirty as it's not in line of the tyre junk.
Andrew S is offline   Reply With Quote
Old 09-05-2014, 12:24 AM   #669
Geberit's Avatar
Hello 12th scale lovers,
For this winter season I decided to try the 1/12 Pan Car category. I got myself the RC12R5.2 with all the stuff needed accept some spare parts. What do I need if Id really like to go safe and what would be the minimum of spares to have for the car?
I have no one to give me advice here at my local track so Ill try my luck here.
Thanks for help!
Geberit is offline   Reply With Quote
Old 09-05-2014, 01:16 AM   #670
Trader Rating: 20 (100%+)
Thanks for help!
ride height shims for front and different adjusters for rear ride height. Different springs. Side links and the plastic parts up front. 1/12 is really simple.
goots is offline   Reply With Quote
Old 09-05-2014, 07:48 AM   #671
Rugspin's Avatar
CRC makes this great set of rear ride height adjusters.
Thanks for help!
Steve Burgess
Old 09-19-2014, 10:57 AM   #672
Rick Hohwart's Avatar
Default New setups posted
With the Worlds around the corner, here are two new setups from Keven Hebert and Mike Haynes:
Mike Haynes - Worlds Testing - 12R5.2
Keven Hebert - Worlds Testing - 12R5.2
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 10-27-2014, 11:09 AM   #673
Default 12R5.1 build question?
Hello everyone,
I'm building my first 1/12 pan car and need some help with gearing.
I have a*12r5.1*running a 7200mah 1s lipo, 46mm tyres front and rear, 6.5t trinity D4, and 1s hobbywing xerun esc
I will only be running this car in front of my house on smooth asphalt paved street. Not really into carpet tracks or racing.
My question is what would be a good pinion / spur combo for this setup? I was thinking 86t spur/40t pinion? Also, what timing should I run on the esc AND the motor can?
Thanks for your thoughts
Losi 8ight T 2.0 Slash platinum 4X4 Tekno NB-48
coastiehelimech is offline   Reply With Quote
Old 12-05-2014, 06:14 AM   #674
If any 12r5.2 owners out there are looking to make some up grades check out my 2mm chassis, magnesium pod plates, and magnesium hubs.
Red Mosquito Racing 12r5.2 associated 1/12 hop up parts!
These parts have become a popular choice to 12r5.2 owners around the world.
For questions you can contact me at red_mosquito7@rocketmail.com
Monti
Old 12-15-2014, 08:24 AM   #675
Great Job to Jim Spencer! He was able to TQ by a lap and take the win Sunday at the BRCA 1/12 nationals running a RMR chassis and light weight parts.
http://www.redrc.net/2014/12/brca-11...rt/#more-90336
Hats off to Keith Robertson for taking the TQ and win on Saturday with a AE 12r5.2.
Monti
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
