Old 01-01-2014, 07:41 AM   #646
The impact of changing to a long-arm set-up is very small. As the front of the car rolls less than 2mm, the camber change is very small.
Putting a spacer between the upper wishbone mount and the mounting block will give a long-arm set-up and less camber change. Putting a spacer between the mounting block and the lower wishbone will widen the the front width. As H I says...
The bigger change in making the top wishbone 'long' is to lower the front roll centre. That reduces the tendency to grip roll, and reduces the 'bite' of the steering on high-grip tracks. I suspect that the change to roll centre is why this is done, and not so much the change to camber gain.
The lower roll centred will make the car softer in roll, and is usually accompanied by use of softer rear springs. Again, contrary to the usual thinking in On-Road, as the grip goes up making a 12th car softer helps.
Remember that 12th is the only car in the world with a hinge in the middle of the chassis. That means that a lot of the accepted wisdom of race-car set-up doesn't apply. When the main chassis rolls, it uses the centre spring to remain level. As the car turns, the front axle is levered around the centre pivot, the centre shock and the front springs - it's complicated! My experience is that roll centres and weight transfer (position of the rear pivot relative to the rear axle) play a bigger part in getting a car to handle than camber gain. HTH
SlowerOne is offline   Reply With Quote
Old 01-01-2014, 08:56 AM   #647
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Originally Posted by bigcracing View Post
That's what I thought when you look at the setup that how I would interpret it longer upper arm and narrow front end and if you add on the lower arm it would give you a wider front end
Does anybody have a Mazda 12th scale body that we ran in the early 90s
Thanks chris
Like this ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-01-2014, 04:41 PM   #648
bigcracing's Avatar
Trader Rating: 32 (100%+)
Not the same we use to race it in the early 90s it didn't have a separate wing I thought it was a Mazda
Thanks Chris
bigcracing is offline   Reply With Quote
Old 01-01-2014, 04:43 PM   #649
bigcracing's Avatar
Thanks Chris
Old 01-01-2014, 11:55 PM   #650
JayBee's Avatar
Trader Rating: 31 (100%+)
Damn...I have to wrap my brain around this
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-03-2014, 07:29 PM   #651
ToysRUsKid's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to ToysRUsKid
My car was "OK" compared to previous runs this past race. I made a few changes based on Ivy's setup but i think the car can be faster or more consistent if not faster.
One thing I did notice was the car ran it's fastest when the tires got around the diameter of the setup sheet. I also noticed the front tires coned outward by the time they wore down. is that normal for 12th scale?
Dorian Tisdale - Professional RC Driver Wannabe
RC America \ DeSoto Racing \ XRay \ Novarossi
www.tsrcar.com \ Red Mosquito raceway \ www.racersoftoledo.com \ www.midwestseries.com
ToysRUsKid is offline   Reply With Quote
Old 01-03-2014, 07:36 PM   #652
JayBee's Avatar
From my understanding of some 1/12th knowledge, coning is not acceptable. I'm sure someone will correct me if I'm wrong. And setups are cool and a nice base the majority of the time, but almost always they have to be tailored to what you like in the drivability of a car.
Old 01-03-2014, 07:41 PM   #653
ToysRUsKid's Avatar
It's hard to tell since sometimes coning is ok and other times it's not.
I only made a few changes based on the setup, didn't go 100% but the changes i made were positive so Ivy's onto something.
Old 01-04-2014, 10:05 AM   #654
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Dorian,
If Your Tires are coning you can Adj your camber + or Neg till your tires run flat.
Hope this helps
Mike
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 01-26-2014, 10:26 AM   #655
Trader Rating: 33 (100%+)
Josh Keller is offline   Reply With Quote
Old 01-31-2014, 05:32 AM   #656
Default body mount position
Does anybody know if the body mount positions are the same between a
RC12R5.1 (non inline ) and the RC12R5.2 chassis ?
I want to prep a body already but currently only have a RC12R5.1 ( non inline ) as a reference .
Thanks,
Erik
stical is offline   Reply With Quote
Old 01-31-2014, 07:30 AM   #657
Thanks,
Erik
same on front, about 1 cm back rear.
oddski is offline   Reply With Quote
Old 02-01-2014, 10:33 AM   #658
durtbag's Avatar
Questions??
Does anybody know if you can use the 5.2 (V2)lower arms on the 5.1 front bulkheads? Or do you have to buy the newer bulkheads?
durtbag is offline   Reply With Quote
Old 02-01-2014, 11:58 AM   #659
RacinJ's Avatar
You will need the new bulkheads with the new arms.
The old setup screws into the arms and the new setup screws into the bulkheads.
AE 12R5.2 / McFactory; Roche P12 '16; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 02-01-2014, 12:09 PM   #660
durtbag's Avatar
Doh! my bad. Didn't even think about that.
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 10:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
SEO by vBSEO 3.5.0
