Like Tree19Likes
Old 12-24-2013, 02:27 AM   #631
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks for that bit of info MrTyson; that's what I was looking for
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-24-2013, 02:43 AM   #632
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
NP
Merry xmas fella..
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 12-24-2013, 07:23 AM   #633
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Whats the mohawk? Similar to blakemarket? I have run that in 10.5 and liked it
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 12-24-2013, 10:32 PM   #634
Me_MrTyson's Avatar
Mohawk is the blackart 005 body with a fin down the middle
Old 12-29-2013, 10:24 PM   #635
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
What do i need to change to run the crc spur gears that use the 3/32 diff balls?
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 12-30-2013, 04:39 AM   #636
Except balls(1/8 - 3/32), I think I read somewhere that you had to use a nonflanged bearing in the spur.
oddski is offline   Reply With Quote
Old 12-30-2013, 05:33 AM   #637
yes, when using a spur gear with 3/32 diff balls, a non-flanged bearing is typically needed in the spur gear. Also, it is sometimes necessary to add an axle shim or two between the outermost diff bearing and the diff cone. Those shims are sometimes needed so that the diff nut doesn't bottom out on the end of the graphite axle shaft before applying pressure first on the inner race of the outermost bearing.
vafactor is offline   Reply With Quote
Old 12-31-2013, 03:53 PM   #638
ToysRUsKid's Avatar
I noticed on Mike Ivy's setup he has 2mm shim in the upper arm mount spacer. What does that do to the car? Right now I have zero spacer.
Old 12-31-2013, 05:07 PM   #639
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Dorian
What that does is widen the the front. It makes the car more stable on really high bite conditions. But u loose a little steering .if u need more steering
you could start out with a half spacer and go up from there.
That setup I posted a few pages back is a starting setup for anyone running 17.5t blinky.
Hope this helps
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 12-31-2013, 05:47 PM   #640
JayBee's Avatar
Default Tweak!!
This may seem a silly question but figuring since I don't know, I might as well ask.
Screws loosened around the chassis and rear pod to let the car settle and re-tightened, new front springs (same height btw), center pivot loosened as well and re-tightened, and all pins given the Mother's treatment. With that being said, using the coin method to set tweek one side has almost 3 turns of the side spring & the other side 1.5. After this I double check the car on my Hudy tweak station and tweak reads correct.
I hate not having the symmetry of both sides but is this something I should be concerned with?
This is with my 10r5.1 but I figured I'd ask here being that its just a bigger 1/12th. Plus I might run into this on the 5.2; not to mention that this thread is more lively.
All thoughts appreciated
Old 12-31-2013, 08:37 PM   #641
haywood's Avatar
Trader Rating: 48 (100%+)
Looks like you covered everything. Did you lay the motor mount on a piece of glass to assure it's not bent?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-31-2013, 08:50 PM   #642
JayBee's Avatar
Thanks for chiming in haywood
The board I have is a 18"x 24" piece of 3/8" glass. But no I did not check for motor mount flatness.
I will get that done
Old 01-01-2014, 01:59 AM   #643
H I
H I's Avatar
Trader Rating: 18 (100%+)
I thought adding upper arm shim makes long arm set up, which should make little less camber gain, and adding lower arm shim make wide front set up??
H I is offline   Reply With Quote
Old 01-01-2014, 06:21 AM   #644
bigcracing's Avatar
Trader Rating: 32 (100%+)
That's what I thought when you look at the setup that how I would interpret it longer upper arm and narrow front end and if you add on the lower arm it would give you a wider front end
Does anybody have a Mazda 12th scale body that we ran in the early 90s
Thanks chris
bigcracing is offline   Reply With Quote
Old 01-01-2014, 06:41 AM   #645
The impact of changing to a long-arm set-up is very small. As the front of the car rolls less than 2mm, the camber change is very small.
Putting a spacer between the upper wishbone mount and the mounting block will give a long-arm set-up and less camber change. Putting a spacer between the mounting block and the lower wishbone will widen the the front width.
As H I says...
SlowerOne is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
