Like Tree19Likes
Old 11-25-2013, 07:28 PM   #586
303slowdown's Avatar
Trader Rating: 21 (100%+)
I would remove the front droop too, that could cause the front end to dive in 180's
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-26-2013, 05:52 AM   #587
Originally Posted by RedBullFiXX View Post
looks like the body is rubbing on that FAT wire you have. You can see the rub marks on the blue wire
I rewired it.
  • TQ 16 AWG for all wires.
  • TQ sensor wire.
  • Smaller transponder - RC4 Hybrid.
  • Removed the servo extension wire I was using for my old transponder (it allowed me to easily swap the transponder to another car).
  • Removed the front bulkheads and found them to be flat on my setup board.
  • Changed the front shims under the bulkheads to get 3mm of front ride height. It is even on both sides.
  • Disassembled the rear pod and checked the rear bulkheads. Rebuilt the pod flat on my setup board.
  • The rear pod has 3mm of height on both sides with 1mm of droop.
  • The car is flat on my MIP tweak station.
I think it is in better shape now and I lost 29g of weight.
Associated RC 12 R5.2-img_0863.jpg   Associated RC 12 R5.2-img_0864.jpg   Associated RC 12 R5.2-img_0865.jpg   Associated RC 12 R5.2-img_0868.jpg
rossb is offline   Reply With Quote
Old 12-02-2013, 05:01 PM   #588
Jerry P's Avatar
Trader Rating: 44 (100%+)
I am looking for a 12r5.2 complete shock. Does anyone know if associated sells it complete or am going to have to piece one together?
is the right part? http://www.amainhobbies.com/product_...CS-Micro-Shock
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 12-02-2013, 05:18 PM   #589
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Jerry,
Use this with either a blue or Silver Associated spring 27.5 to 30wt Oil
http://www.amainhobbies.com/product_...lete-Shock-Kit
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 12-02-2013, 05:21 PM   #590
mike ivy's Avatar
Hey rossb,
Car looks better. But please do something with those chunked tires Lol...
Originally Posted by rossb View Post
I rewired it.
  • TQ sensor wire.
Old 12-02-2013, 05:35 PM   #591
Jerry P's Avatar
Originally Posted by mike ivy View Post
Hey Jerry,
Thanks just ordered the shock set i found it after i posted. I need to get springs too..
Jerry P
Old 12-08-2013, 12:09 AM   #592
ClayRacer's Avatar
Hi Guys, would just like some quick advice to get started.
I have almost done building my 12R5.2 and would like to start with 17.5t on 1s With Speedmind foam tyres.
I will be running on a large out door asphalt track. Can any one suggest a starting point for Pinion and Spur selection (I only have the spur included in the kit right now so I guess I will need to change that?)
Thanks!
Dex210 - SC104X4-FT - TeamC T8E - TeamC T4 FT v3 - AE 12R5.2 - MTS T2 - LC Racing LMB1
TrackStar & Hobbywing Motors - TrackStar & Hobbywing ESCs - Turnigy nanotech batteries all round
Spektrum DX3C - Sanwa M12
JConcepts, Proline, GM, TeamPower, Speedmind & Louise Tyres
ClayRacer is offline   Reply With Quote
Old 12-08-2013, 05:25 AM   #593
bigcracing's Avatar
Trader Rating: 32 (100%+)
Default 12R5.2 alter ego
Has any body tried the 12R5.2 alter ego style with the battery turned 90 degrees old school. it seems to me the car would be balanced side to side better.
Just a thought
bigcracing is offline   Reply With Quote
Old 12-08-2013, 09:00 AM   #594
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Does making the rear wheel width wider make the rear of the car feel less stable. I feel that the rear of my car is too connected and bogging my corner speed and motor down mid corner. I am not sure what you would call this or if it is just a common effect with foam tires. It just appears that my car is not ripping out of corner like some other guys.
So I am just looking for some setup changes that I could try to see if it will help.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 12-08-2013, 09:17 AM   #595
Hey rossb,
And center the servo horn
RoyU is offline   Reply With Quote
Old 12-12-2013, 03:29 AM   #596
rosko's Avatar
On my 12 r5.2 i pit 2mm shim behind my castor blk to lenghthen my upper a arm , my question is does anyome know of a carbon brace that will fit
rosko is offline   Reply With Quote
Old 12-12-2013, 04:54 AM   #597
mike ivy's Avatar
Hello there,
You'll need the smaller length carbon brace off of the older version 12r5
Hope this helps
Mike
Old 12-12-2013, 07:07 AM   #598
I would increase castor. I am also assuming you are running the correct tires for your class. Increasing castor increases camber gain and increases weight jacking, which make the rear end feel like it is coming around. Here is what I suggest:
17.5 Blinky - Blue Rear and Black or Gray front, if high bite Green rear.
13.5 - Blinky Blue rear and Team Purple front.
Mod - longer conversation
If you are running the tire combo above then set castor at 4-5 degrees and go up or down from there. If you get to 6 degrees of castor something is probably wrong with the car.
Hope this helps.
Steve Dunn
Pro One R/C
sdunnmcp is offline   Reply With Quote
Old 12-12-2013, 10:26 AM   #599
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Switched out my center shocks last night for tc5 shocks ive had sitting around. This allows me to have 4 prebuilt center shocks and 4 side shocks between my 2 5.1 lipo cars.
Quedtion though; how do the center shock springrates compare to touring car springs? I was running gold ae center and sides for the 13.5 car and blue center black sides for the mod car. Now that im using a parger bore center shock, what kind of rates should i look for? I put ae green in the mod car and serpent white in the stock which i think are in the 11-13lb range.
Gonna pick up some ride springs 2-3nm ratings but not sure where to start.
I need those springs for the touring cars anyway, but typically nothing lower than 2.5nm.
My stuff
| Sanwa M12 - Team Associated - Reedy - ProAMPS RC - Novarossi |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/
valk is offline   Reply With Quote
Old 12-12-2013, 10:35 AM   #600
JayBee's Avatar
Trader Rating: 31 (100%+)
He does not need to change this per se. Let me clarify, as long as the links are parallel to the chassis (flat/no angle). If not, then use the Kimbrough mid.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
