Like Tree19Likes
Old 10-31-2013, 06:08 AM   #556
Originally Posted by RedBullFiXX View Post
Good to know Kevin
Been a while since I've run that combo, thought there was more to it than simply bolting them on, and hitting the max width
A 4.5t with a 730g foam tired land missile is a lot to handle, even for the best in the world
You might consider motoring down a bit, so you can enjoy the sweet corner speed, rather than piling up a parts bill
Damn! even on 1s.. thats going to be entertaining with my 1/8 scale buggy throttle finger
losi8_79 is offline   Reply With Quote
Old 11-09-2013, 07:28 PM   #557
Tron's Avatar
Trader Rating: 16 (100%+)
Anyone have a list of PNs that are required for the complete 12r5.2 front end?
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 11-09-2013, 07:39 PM   #558
#4686 is the complete front end kit w/v1 bulkheads and lower arms.
#4705 front bulkheads v2 #4706 lower arms v2
RoyU is offline   Reply With Quote
Old 11-09-2013, 07:47 PM   #559
Tron's Avatar
Nice. Quick. Thank you sir.
Brett
"Slow Sportsman"
Old 11-09-2013, 08:05 PM   #560
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
Page 15 of the manual has what you need as well.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 11-10-2013, 05:34 PM   #561
I weighed my 12R5.2 this weekend at a race and it seemed to be much heavier than everyone else at 805g. It is a stock build with the following:
Novak 17.5
TrakPower LiPo 1S 3.7V 6400mAh
Airtronics Mini Digital Fast BB Servo
Protoform AMR-12 Light Weight
Jaco 1/12 Prism Front and Rear Wheels
Futaba R204GF-E
LRP Flow Works
Novak 1S LiPo Booster
AMB PT on a Venom 4" Servo/Battery Extension.
I am running the stock 12 AWG Motor and Battery Wires. I have a set of 16 AWG TQ wires, but I don't see those reducing my weight by much. Any ideas on reducing weight?
rossb is offline   Reply With Quote
Old 11-10-2013, 05:59 PM   #562
geeunit1014's Avatar
The wires will make a big difference actually, id guess at least around 20g if you do motor and power wires. Beyond that, youll want the aluminum screw set, and ceramic bearings. Keep all your wires as short as functionally possible, including your servo leads. Id guess if you shorten your servo leads to as short as possible youd pick up another 5-10g.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-10-2013, 08:15 PM   #563
Trader Rating: 49 (100%+)
from the looks of it, you have pretty large foams too. I never could wrap my head around it, because they seem so light, but truing the foams down farther helps with the weight too
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 11-11-2013, 07:00 AM   #564
EricF's Avatar
Originally Posted by rossb View Post
I weighed my 12R5.2 this weekend at a race and it seemed to be much heavier than everyone else at 830g. It is a stock build with the following:
I run 17.5 & 13.5: switched all my wire to 16 awg and changed to almost all alum screws and a 2 color paint and low cut high traction race foams I was able to get my car down to 740g or so. I'll post a pic (if I remember) when I get home tonight.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 11-11-2013, 11:39 AM   #565
I was actually mistaken, it is 756g w/o the body and 805g with the body. Please see the attachments.
Old 11-11-2013, 11:53 AM   #566
oeoeo327's Avatar
Trader Rating: 70 (100%+)
A single color paint scheme would help with weight, as would truing down the tires. 16 AWG wire is all that's needed to conduct current properly, so you'd see a significant improvement in weight by wiring the car using 16 gauge. Aluminum/Titanium screws would also cut a few more grams. Each part doesn't make a huge difference, but it all adds up.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 11-11-2013, 12:09 PM   #567
gazza's Avatar
All the above posts are great suggestions. One other is the motor itself. I switched from a Reedy to an Orca and found myself under weight by 2 or 3 grams
Kyle Majikas E-Town posse, Pro One R/C, TQ wire, SpeedMerchant, MC² Racing, Hobbywing North America
gazza is offline   Reply With Quote
Old 11-18-2013, 11:03 AM   #568
This may be a silly question.
Is there any way that I can convert from damper tubes on the R5.2 back to the older side shock that the R5.1 used. Im think that i will need a new top plate (the one from the lipo conversion) and shock
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 11-22-2013, 05:18 AM   #569
Trader Rating: 32 (100%+)
If you are looking to cut weight try the Red Mosquito Racing products 12R5.2 2mm chassis and bottom plate. This chassis cuts 12 grams off of the total weight of the car and also provides a smoother feel.
Monti
Monti is offline   Reply With Quote
Old 11-24-2013, 03:07 PM   #570
I was running my car on a track yesterday that had a long straight followed immediately by a 180 degree turn. I ran the car wide open for 3/4 of the straight and coasted for the last 1/4. When I went to make the turn off the throttle at the end of the straight the car had a very strong tendency to snap into a very quick 180 and come to a complete stop facing the opposite direction. The car seemed to handle properly for the rest of the track. I did not notice any other cars exhibiting this behavior. Is this a setup issue or was I driving it improperly?
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
