Like Tree3Likes
Old 10-13-2013, 12:52 PM   #541
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
Sounds good...one less thing to think about.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 10-22-2013, 04:08 AM   #542
Default 12R5.2 rear widht with BSR tires
hi!
I got few parts from 12R5.2 to build other chassis.
Left side allu and engine mount, upper carbon plate, rear brace from L to R.
Now, when I try put bsr tires it is too width, 1mm .. over limit.
So my question is to 12R5.2 drivers, it is possible use bsr rear tires on 12R5.2 with 172mm limit?
Jaco, mobgums aka RB are perfect, but bsr which has very small ofset I can't use ...
Anyone can check bsr tires?
Thank you!
Michal
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-22-2013, 06:32 AM   #543
Trader Rating: 32 (100%+)
Originally Posted by M.Abramowicz View Post
hi!
Thank you!
Michal
Yes you can run BSR tires on the 12r5.2. Keven Hebert just won the IIC with BSR tires. You will not run any shims on the right side and will need to maybe flip the left rear hub around.
Monti
Monti is offline   Reply With Quote
Old 10-22-2013, 06:47 AM   #544
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Monti
I don't remember tech checking width at iic on 12th Monti
172mm with BSR, while keeping wheels centered on an R5 ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-22-2013, 07:07 AM   #545
I have run the past two ROAR nationals (carpet and asphalt) with my 12r5.2 and have passed tech there too. It can be done, I think it has to do with the LR hub and how it's turned.
Monti
Old 10-24-2013, 01:53 PM   #546
Spillertwo's Avatar
Anybody using the Savöx SH-1257MG servo in the R5.2 ?
Are there any mounting issues with this servo ?
What servo saver should i get for that servo ?
Spillertwo is offline   Reply With Quote
Old 10-24-2013, 08:39 PM   #547
durtbag's Avatar
Originally Posted by Rick Hohwart View Post
You can upgrade a little at a time. If you were to install the damper tubes you would have a very similar car to the 12R5.2. Then you can add the other items over time to bring it up to full spec.
Originally Posted by Grassy View Post
Just looking at the new parts list it would be possible to convert your 12R5.1 Inline Version with minimal parts needed.
From what i can see you will need
1 x 4700 Motor Mount Bulkhead
1 x 4701 LR Bulkead
1 x 4702 Motor Mount Brace
1 x 4703 Upper Pod Plate
1 x 4704 Chassis Brace
2 x 4705 Front Bulkhead
1 x 4707 Side Sprig Retainer
1 x 4708 Damper Tube
1 x 4709 Damper Tube Shaft
1 x 8828 Cup Set
1 x 31322 Arm Mount Bushing
I think that is all (someone correct me if there is anything missing)
Kind regards,
Chris
Can someone please confirm the minimum parts required to convert a 5.1 to damper tubes? I'm new to 1/12th and stripped the side shock cap already might be a good time to go to tubes.
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 10-25-2013, 08:46 AM   #548
If you only want the dampertubes, there is no need to buy the whole list. You only need the new top plate, tweak bar, dampertubes and ballstuds. I went with the dampertube conversion kit from Speedmerchant. If you are in spending mode, grab the Tamale pod from Speedmerchant site aswell.
I do not have the manual in front of me, but I think it will get you there. Or speedm smr6030
oddski is offline   Reply With Quote
Old 10-27-2013, 09:46 AM   #549
durtbag's Avatar
Thanks, oddski! AE parts ordered. The Speedmerchant Tamale pod looks the business, and will look at upgrading later
Old 10-30-2013, 02:43 AM   #550
Hi!
Im new to 1/12 scale and have some questions that i havent found any answers to yet.
-Im on 1s lipo with a 4.5t motor, whats a good roll out startin point?
-What parts should i stock up?
-I thought i might be able to use my saddle pakcs, but only a few had the right size, any good battery packs that will be a direct fit att a fairly low cost?
Any help is greatly appriciated
losi8_79 is offline   Reply With Quote
Old 10-30-2013, 08:05 AM   #551
EricF's Avatar
Originally Posted by losi8_79 View Post
Hi!
-Im on 1s lipo with a 4.5t motor, whats a good roll out startin point? don;t know
-What parts should i stock up?I've used upper arm, upper arm eyelet, steering block and front axle
-I thought i might be able to use my saddle pakcs, but only a few had the right size, any good battery packs that will be a direct fit att a fairly low cost?I like reedy packs and as of late aero model, not sure if this brand is only local or available everywhere
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 10-30-2013, 08:19 AM   #552
Default BSR tires
Hi All,
I have been running the BSR tires with great luck for the past few months.
My car is curently 171.75mm
I took all the shims out of my car, I am running the left hub on its regular side but I sanded about .4mm off of it and I am running 2 of the very thin ae axle shim on that side and 1 very thin shim on the right side and my car is even on both side and is 171.75mm !
Hope this helps.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 10-30-2013, 08:48 AM   #553
Hi!
Have 2-3 spare kits on hand
Old 10-30-2013, 10:05 AM   #554
Cool
Originally Posted by Keven H View Post
Hi All,
Hope this helps.
Good to know Kevin
Been a while since I've run that combo, thought there was more to it than simply bolting them on, and hitting the max width
Hi!
A 4.5t with a 730g foam tired land missile is a lot to handle, even for the best in the world
You might consider motoring down a bit, so you can enjoy the sweet corner speed, rather than piling up a parts bill
Old 10-30-2013, 05:15 PM   #555
jetnjme's Avatar
finished reading this thread today and realized I rushed my build. I missed / forgot a few key points, thank you to everyone on here.
Northern California Pan Car Revival
jetnjme is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
