Old 08-22-2013, 07:41 AM   #526
dr_hfuhuhurr's Avatar
Trader Rating: 69 (100%+)
Originally Posted by Mach10_shooter View Post
How's the durability of those?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 08-22-2013, 09:56 AM   #527
TeamCody's Avatar
Originally Posted by Monti View Post
It's pretty good out of the box. I never run stiffer than silver side springs most times it's green or black. I most always use 10k in the side tubes and a protoform AMR body.
The car is a bit on the heavy side, I would recommend getting aluminum screws from fastener express.
I also cut a 2mm thick chassis for the 12r5.2. It saves 12 grams of total weight on the car. I still sell them if you are interested at a later point.
Monti
Great, I will keep that in mind. Thanks for the info.
"Its just a hobby!"... or so I'm told.
TeamCody is offline   Reply With Quote
Old 09-05-2013, 02:23 AM   #528
Trader Rating: 23 (100%+)
Delete
bmcallister is offline   Reply With Quote
Old 09-10-2013, 01:22 AM   #529
Spillertwo's Avatar
Which body are you guys using ? When i look at the setup sheets i see mostly the Protoform AMR ? The Profotorm TR-12 apparantly is not so popular ?
Spillertwo is offline   Reply With Quote
Old 09-10-2013, 05:37 PM   #530
Trader Rating: 77 (100%+)
AMR here.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 09-13-2013, 01:09 PM   #531
jetnjme's Avatar
picked mine up from Speedworld last week, i love new kits.
jetnjme is offline   Reply With Quote
Old 09-25-2013, 06:56 PM   #532
Are the 12r5.1 and 12r5.2 rear pods the same? I am wanting to put a team tamale pod on my 5.2 and the pod they list says 5.1. Thanks
Old 09-26-2013, 12:52 PM   #533
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Yes...it will fit.
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 10-03-2013, 04:04 PM   #534
Has anyone balanced their rear pod? Anyone have a write-up on how to do it?
Saw this on the Speedmerchant Rev8 thread:
http://www.rctech.net/forum/12601011-post50.html
What's needed to balance the rear pod?
Old 10-03-2013, 07:53 PM   #535
chevtech23's Avatar
I use the AMR, i run 17.5 stock. i have a tr12 but havent tried it yet, friends who have tried it report that its too much drag and the car is too "stuck" with it where we race
chevtech23 is offline   Reply With Quote
Old 10-07-2013, 01:41 PM   #536
I took a couple good hits to the front left side. That side has developed some extra "droop" you could say. There's more play in that side of the car. Nothing broken, nothing is bent, what I think happened was the plastic balls in the front arm and upper link have been "stretched".
Anyone else experience this in the past? I'm going to replace the upper link first to see if that fixes it.
Old 10-07-2013, 02:45 PM   #537
Pulse_'s Avatar
anyone using a kimbrough servo saver (white) and s9650 servo?
I'm trying to figure out what type of screw I should use to fix the servo saver on the servo considering the head of the stock screw caming with the s9650 is too large for the hole..
thanks!
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 10-07-2013, 06:04 PM   #538
Sounds like a collapsed spring, if your track is running clockwise the left front spring tends to collapse and cause it to have more droop.
Joe Trandell is offline   Reply With Quote
Old 10-12-2013, 03:54 AM   #539
Is it necessary to balance the rear pod? It will not transfer uneven wheight to the chassis. On the other hand, a balanced pod is useful when you put the whole car on spikes...
oddski is offline   Reply With Quote
Old 10-13-2013, 11:46 AM   #540
It is not necessary to balance a rear pod. There was a whole discussion about this on a thread here that I can't find now. Lots of people gave lots of theories... until Mike Blackstock wrote that he had tried this and his car handled better with the standard set-up than with a balanced pod! The conversation then stopped...
As the weight of the whole pod and motor sits on three points it will distribute the weight pretty much evenly across the tyres and the centre pivot. In any event, all the weight goes to the chassis goes through the centre pivot into the chassis, and so any uneveness in the balance will only affect rear tyres, not chassis balance. If the car takes off straight, and pulls evenly out of left and right turns then the motor torque is getting evenly to the tyres and all is well. Modern cars are very good on pod balance as standard, so don't worry. HTH
SlowerOne is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 10:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
SEO by vBSEO 3.5.0
